I'm getting the black screen and these errors in my logs:
zma_m2[22871]: ERR [Shared data not initialised by capture daemon]
zmdc[22798]: ERR ['zma -m 2' exited abnormally, exit status 255]
zmc_m2[22872]: INF [Starting Capture]
zmc_m2[22872]: ERR [Invalid response status 401: Unauthorized]
zmc_m2[22872]: ERR [Unable to get response]
zmc_m2[22872]: ERR [Failed to capture image from monitor 2 (0/1)]
zmdc[22798]: ERR ['zmc -m 2' exited abnormally, exit status 255]
zmwatch[22830]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
zmwatch[22830]: last message repeated 5 times
zmdc[22798]: INF [Starting pending process, zma -m 2]
zmdc[22798]: INF ['zma -m 2' starting at 11/06/04 13:32:28, pid = 22909]
zmdc[22798]: INF [Starting pending process, zmc -m 2]
zmdc[22798]: INF ['zmc -m 2' starting at 11/06/04 13:32:28, pid = 22910]
zmdc[22910]: INF ['zmc -m 2' started at 11/06/04 13:32:28]
zmdc[22909]: INF ['zma -m 2' started at 11/06/04 13:32:28]
zmc_m2[22910]: INF [Debug Level = 0, Debug Log = <none>]
zma_m2[22909]: INF [Debug Level = 0, Debug Log = <none>]
zma_m2[22909]: ERR [Shared data not initialised by capture daemon]
zmc_m2[22910]: INF [Starting Capture]
zmc_m2[22910]: ERR [Invalid response status 401: Unauthorized]
zmc_m2[22910]: ERR [Unable to get response]
zmc_m2[22910]: ERR [Failed to capture image from monitor 2 (0/1)]
/etc/sysctl.conf currently reads:
kernel.shmall = 167772160
kernel.shmmax = 335544320
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 327680
max total shared memory (kbytes) = 671088640
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 1705
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
Another forum suggested adding these lines to /usr/bin/zmdc.pl:
$ENV{LD_PRELOAD} = '/usr/lib/libv4l/v4l1compat.so';
$ENV{LD_PRELOAD} = '/usr/lib/libv4l/v4l2convert.so';
Still no good.
I've added the www-data user to the video group as suggested on one forum but no luck.
I'm completely stuck now. Any help is greatly appreciated.
