I have a basic configuration for a Vivotek 7142. There is no password on the Vivotek (because I'm testing).
The monitor screen is just black, no image. In source, the source is red.
I a browser it works perfectly, i.e. when I do WWW://192.168.0.253/video.mjpg I see the image and everything works perfectly. When I do the WWW command the window title is video.mjpg (720x480).
My parameters are:
First tab:
- Monitor
- Remote
Second tab:
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: 192.168.0.253
Remote Host Port: 80
Remote Host Path: /video.mjpg
Remote Image Colours 8 bit greyscale
Capture Width (pixels): 720
Capture Height (pixels): 480
/etc/init.d/zoneminder status shows ZoneMinder running
What am I doing wrong that causes ZoneMinder to just see a black screen?
Vivotek IP7142 stream /video.mjpg not working / black screen
Re: Vivotek IP7142 stream /video.mjpg not working / black sc
I think the problem is that ZM cannot read the MPEG-4 stream.eugenevdm wrote:I have a basic configuration for a Vivotek 7142. There is no password on the Vivotek (because I'm testing).
See if you can read the second MJPEG stream from the camera.
The path will be something like /image.jpg.
You may have to have a look at the source to get the path. Do this by right click on the webpage (outside the image) that is showing the image and select 'View Source.
Algenon
