Problem with SUSE 9.2 and ZM 1.20.1
rrichards_gnaps
Post by rrichards_gnaps »
I'm installing ZM on SUSe 9.2 with PHP 4.3.8 when I go t the weblink I get the following error:
Fatal error: Call to undefined function: session_start() in /home/peephole/zm.php on line 148
zoneminder
Site Admin
Post by zoneminder »
That's very strange and I've never heard of this before. AFAIK session support doesn't have to be compiled into PHP. Can you create a file, say called 'debug.php' and just put
<?php
phpinfo()
in it then access it and post what you see.
Phil
rrichards_gnaps
As requested:
PHP Version 4.3.8
System Linux peephole2 2.6.8-24-smp #1 SMP Wed Oct 6 09:16:23 UTC 2004 i686
Build Date Dec 21 2004 00:34:25
Configure Command './configure' '--prefix=/usr' '--datadir=/usr/share/php' '--mandir=/usr/share/man' '--bindir=/usr/bin' '--libdir=/usr/share' '--includedir=/usr/include' '--sysconfdir=/etc' '--with-_lib=lib' '--with-config-file-path=/etc' '--with-exec-dir=/usr/lib/php/bin' '--disable-debug' '--enable-inline-optimization' '--enable-memory-limit' '--enable-magic-quotes' '--enable-safe-mode' '--enable-sigchild' '--disable-ctype' '--disable-session' '--without-mysql' '--disable-cli' '--without-pear' '--with-openssl' '--with-apxs2=/usr/sbin/apxs2-prefork' 'i586-suse-linux'
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php.ini
PHP API 20020918
PHP Extension 20020429
Zend Extension 20021010
Debug Build no
Thread Safety disabled
Registered PHP Streams php, http, ftp, https, ftps, compress.zlib
rrichards_gnaps
(Actually, this is Robrichards_gnaps' evil twin "Darrell" updating - Rob is running around frantically today and needed an assist)
(this) Problem solved.
Note to SUSE 9.2 users - OOB install of SUSE 9.2 did not install the session extension by default. A quick search for "php4-session" in the SUSE package manager (yast) will take you to the appropriate Extention Module.
bt
SUSE 9.2 and Shared memory problem
Post by bt »
Hello
I Have a problem with the shared memory.
OS := SUSE 9.2
zm Version := 1.20.1
internal memory :=192 MB
cat /proc/sys/kernel/shmall := 2097152
cat /proc/sys/kernel/shmmax := 33554432
tail /var/log/message
Mar 1 20:13:30 lapux zmc_d0[7429]: INF [Debug Level = 0, Debug Log = <none>]
Mar 1 20:13:30 lapux kernel: pwc set_video_mode(160x120 @ 10, palette 15).
Mar 1 20:13:30 lapux kernel: pwc decode_size = 1.
Mar 1 20:13:30 lapux kernel: pwc Using alternate setting 1.
Mar 1 20:13:30 lapux zmc_d0[7429]: ERR [Failed to set picture attributes: Invalid argument]
Mar 1 20:13:30 lapux zmc_d0[7433]: INF [Debug Level = 0, Debug Log = <none>]
Mar 1 20:13:31 lapux zma_m1[7435]: INF [Debug Level = 0, Debug Log = <none>]
Mar 1 20:13:31 lapux zma_m1[7435]: ERR [Shared memory not initialised by capture daemon]
Mar 1 20:13:31 lapux zma_m1[7438]: INF [Debug Level = 0, Debug Log = <none>]
Mar 1 20:13:31 lapux zma_m1[7438]: ERR [Shared memory not initialised by capture daemon]
Mar 1 20:13:31 lapux zmc_d0[7433]: ERR [Failed to set picture attributes: Invalid argument]
Mar 1 20:13:37 lapux zma_m1[7468]: INF [Debug Level = 0, Debug Log = <none>]
Mar 1 20:13:37 lapux zmc_d0[7469]: INF [Debug Level = 0, Debug Log = <none>]
Mar 1 20:13:37 lapux zma_m1[7468]: ERR [Shared memory not initialised by capture daemon]
Mar 1 20:13:37 lapux kernel: pwc set_video_mode(160x120 @ 10, palette 15).
Mar 1 20:13:37 lapux kernel: pwc decode_size = 1.
Mar 1 20:13:37 lapux kernel: pwc Using alternate setting 1.
Mar 1 20:13:37 lapux zmc_d0[7469]: ERR [Failed to set picture attributes: Invalid argument]
Mar 1 20:13:47 lapux zmc_d0[7474]: INF [Debug Level = 0, Debug Log = <none>]
Mar 1 20:13:47 lapux zma_m1[7473]: INF [Debug Level = 0, Debug Log = <none>]
maybe the problem is somewhere else
if i take a look in the zmdc.log
Server starting at 05/03/01 20:13:27
'zmc -d 0' started at 05/03/01 20:13:30
'zmc -d 0' starting at 05/03/01 20:13:30, pid = 7429
'zmc -d 0' crashed at 05/03/01 20:13:30, exit status 255
'zmc -d 0' starting at 05/03/01 20:13:30, pid = 7433
'zma -m 1' starting at 05/03/01 20:13:31, pid = 7435
'zma -m 1' started at 05/03/01 20:13:31
'zma -m 1' crashed at 05/03/01 20:13:31, exit status 255
'zma -m 1' starting at 05/03/01 20:13:31, pid = 7438
'zmc -d 0' crashed at 05/03/01 20:13:31, exit status 255
'zmfilter.pl' starting at 05/03/01 20:13:31, pid = 7441
'zmfilter.pl' started at 05/03/01 20:13:31
'zmaudit.pl -d 900 -y' starting at 05/03/01 20:13:32, pid = 7445
'zmaudit.pl -d 900 -y' started at 05/03/01 20:13:32
'zmwatch.pl' starting at 05/03/01 20:13:32, pid = 7450
'zmwatch.pl' started at 05/03/01 20:13:32
'zmupdate.pl -c' starting at 05/03/01 20:13:33, pid = 7454
'zmupdate.pl -c' started at 05/03/01 20:13:33
Starting pending process, zma -m 1
'zma -m 1' starting at 05/03/01 20:13:37, pid = 7468
Starting pending process, zmc -d 0
'zma -m 1' started at 05/03/01 20:13:37
'zmc -d 0' starting at 05/03/01 20:13:37, pid = 7469
'zmc -d 0' started at 05/03/01 20:13:37
'zma -m 1' crashed at 05/03/01 20:13:37, exit status 255
I hope this is enough information to help me
Bas
rmo
shared memory
Post by rmo »
shmmax is set by default to 33554432 .
echo 132217728 > /proc/sys/kernel/shmmax will set 128 MB shmmax
To set 128 MB shmmax as default just write
kernel.shmmax = 132217728
into /etc/sysctl.conf
rmo
