marculin
Posts: 58 Joined: Fri May 11, 2007 8:12 pm
Post
by marculin » Tue Mar 01, 2011 6:46 pm
Hy,
I've 5 camera and openSuse 11.1.
Randomly, I find which one zma process don't exists. With "ps aux | grep zma" I show only 4 process.
I've see a log but I don't find a problem.
I've see only this line
zmdc[6116].INF ['zma -m 18' stopping at 11/03/01 08:43:02]
zmdc[6116].INF ['zma -m 18' exited normally]
How I can find because zma stopping automatically?
Thank you.
marculin
Post
by marculin » Sat Mar 12, 2011 4:10 pm
No idea?
Today it's stopped zma number 20 (another camera).
marculin
Post
by marculin » Fri May 06, 2011 3:13 pm
Today I've another camera with not record always.
The camera it's "Enabled" with function "Record".
In main windows it have a "orange" color. Zma for this camera not running.
No idea?
Thank you
mastertheknife
Posts: 678 Joined: Wed Dec 16, 2009 4:32 pm
Post
by mastertheknife » Fri May 06, 2011 3:58 pm
zma is only running for enabled cameras not in "Monitor" mode. for "Monitor" mode, only zmc is running.
mastertheknife
Kfir Itzhak.
marculin
Post
by marculin » Sat May 07, 2011 8:09 am
All my camera are in Function "Record".
I don't use Function "Monitor"
marculin
Post
by marculin » Wed Jun 08, 2011 9:02 am
No news?
The problem exsists too.
mastertheknife
Post
by mastertheknife » Thu Jun 09, 2011 11:52 am
You can try enabling debugging level 6 or 7 and restarting ZoneMinder.
This will create many debug files in /var/log/zm, look for the one for zma for the correct monitor and upload it to here or to
http://pastebin.com and link us.
mastertheknife
Kfir Itzhak.
marculin
Post
by marculin » Mon Jun 13, 2011 7:48 am
Hi, I've debug level = 7.
In zmdc.log
06/12/11 02:37:19.119098 zmdc[7659].INF ['zma -m 16' stopping at 11/06/12 02:37:19]
06/12/11 02:37:19.130038 zmdc[7659].INF ['zma -m 16' exited normally]
06/12/11 02:37:19.227746 zmdc[7659].INF [Starting pending process, zma -m 16]
06/12/11 02:37:19.246063 zmdc[7659].INF ['zma -m 16' starting at 11/06/12 02:37:19, pid = 1767]
06/12/11 20:23:47.534829 zmdc[7659].INF ['zma -m 16' stopping at 11/06/12 20:23:47]
06/12/11 20:23:47.547323 zmdc[7659].INF ['zma -m 16' exited normally]
in zmwatch.log
zmwatch.log:06/12/11 20:23:47.023902 zmwatch[7750].INF [Restarting analysis daemon for camera1, time since last analysis 2 seconds (1307903027-1307903025)]
Do you have a idea?
Thank you
mastertheknife
Post
by mastertheknife » Mon Jun 13, 2011 11:45 am
zmdc.log is not the correct logfile.
Look in /var/log/ for files called zm_debug*, look for the one for zma for monitor 16.
mastertheknife
Kfir Itzhak.
marculin
Post
by marculin » Wed Jul 20, 2011 8:15 am
this is log (with debug level 7)
07/19/11 19:40:02.015982 zma_m16[-1].DB1-zm_event.cpp/528 [Adding frame 5 to DB]
07/19/11 19:40:02.502312 zma_m16[-1].DB4-zm_monitor.cpp/1055 [RI:11, WI: 12, PF = 1, RM = 39, Step = 1]
07/19/11 19:40:02.502343 zma_m16[-1].DB1-zm_event.cpp/516 [Writing capture frame 6]
07/19/11 19:40:03.728992 zma_m16[-1].DB1-zm_event.cpp/528 [Adding frame 6 to DB]
07/19/11 19:40:03.867735 zma_m16[-1].DB4-zm_monitor.cpp/1055 [RI:12, WI: 14, PF = 2, RM = 38, Step = 1]
07/19/11 19:40:03.867763 zma_m16[-1].DB1-zm_event.cpp/516 [Writing capture frame 7]
07/19/11 19:40:03.884010 zma_m16[-1].DB1-zm_event.cpp/528 [Adding frame 7 to DB]
07/19/11 19:40:03.888681 zma_m16[-1].DB4-zm_monitor.cpp/1055 [RI:13, WI: 14, PF = 1, RM = 39, Step = 1]
07/19/11 19:40:03.888702 zma_m16[-1].DB1-zm_event.cpp/516 [Writing capture frame 8]
07/19/11 19:40:03.904902 zma_m16[-1].DB1-zm_event.cpp/528 [Adding frame 8 to DB]
07/19/11 19:40:04.176695 zma_m16[-1].DB4-zm_monitor.cpp/1055 [RI:14, WI: 15, PF = 1, RM = 39, Step = 1]
07/19/11 19:40:04.176730 zma_m16[-1].DB1-zm_event.cpp/516 [Writing capture frame 9]
07/19/11 19:40:04.195563 zma_m16[-1].DB1-zm_event.cpp/528 [Adding frame 9 to DB]
07/19/11 19:40:04.394525 zma_m16[-1].INF-zm_signal.cpp/43 [Got signal 15 (Terminated), exiting]
07/19/11 19:40:04.394570 zma_m16[-1].INF-zm_monitor.cpp/515 [cam16: 28575 - Closing event 375966, shutting down]
Thank you
marculin
Post
by marculin » Mon Jul 25, 2011 10:34 am
no idea?
Thank's
