Colour not working
Colour not working
Now when I have bought a colour camera I just can't get it working. I'm on MDK 10.1 OE and all cameras are working on grey-palett, but not on any other settings, zmc just craches with err=255.
I've a BT878 board with 4 input, running zmu gives:
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 640
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 384
Height: 287
Picture Attributes
Palette: 1 - Linear greyscale
Colour Depth: 8
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 3 - AUTO
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
The only way it works it with GREY and device format = 3. It should I think work on device format=0 since it's a PAL camera, any ideas?
cheers, tord
Video Capabilities
Type: 171
Can capture
Can tune
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 640
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 384
Height: 287
Picture Attributes
Colour Depth: 8
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 3 - AUTO
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
cheers, tord
yes I've tried them all, every one with different device format as well, it just don't give a colour Most of the pallets crashes zmc. When I try to send USR1 to the zmc deamon some more pallets works without crash, but still no colour.
thanks for your help!
thanks for that Cordel, I've manged now to set the board type to 77 (it works for my first board, but the second board still loads on card=0. I don't know how to pass the parameters to my second board)
Still no colour zmc just crash with exit=255 when I try setting anything outside grey.
For a PAL camera on composite video, should it not just be RGB24, device format=0 (PAL) and capture with in my case 384x287?
Cheers,
tord
Cheers,
tord
the dogs mate! it's getting closer, only thing missing now is colour
my modprobe.conf now looks like:
options bttv radio=0 tuner=0 pll=0 gbuffers=8 card=77,77
On the good side, I now get colours from another application, 'camstreams'. That must mean that the capture board is working, problem back to ZM. Any ideas?
cheers,
tord
cheers,
tord
Yes it can. If the settings you have in ZM don't match what the card can deliver ZM will crash. But I think ZM will give you an error that will suggest that maybe the issue but I'm not sure.
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
