Deleting events older than 30 days
yosepht
Post by yosepht »
I know this question has been asked and answered many times before.But all my searches
keep taking me back to the Wiki which is a bit more reading than I like to do.
How do I set up filters to delete events over 30 days old? My system load goes above
1.0 consistently when my Disk is about 15% full which is usually in about 30 days.
I am using ZM 1.24.2
Thanks for taking the time.
Yoseph
PacoLM
Re: Deleting events older than 30 days
Post by PacoLM »
Filters, add a filter by Date, less than or equal, -30 day. Remember to check the Delete all matches and leave the field Limit to first XX results in blank. Save it to run in background.
yosepht
Post by yosepht »
Thanks.I did greater than 30 day and it deleted all the events.I will have to wait 30 days and find out how
your suggestion works. Why is there "-" before the 30 day and do I have to do this for every monitor ?
thanks
Yoseph
PacoLM
Post by PacoLM »
The filters could be set for all the monitors or just for one, depends on the filter you use.
