Email notifications not sent (more or less solved)
olki
Post by olki »
I'm struggling with the set up of emails: after an event, when I look at the log, I can see the "Creating notification message" + "Sending notification message" but that's it. I don't see any "Can't send email:" or "Notification message sent". I looked at the zmfilter.pl script and I dont understand how it can be. Does anybody can tell me a way to debug the email feature from the command line?
Please help.
PS: the server is running an exim4 agent who is doing well at sending logwatch messages (for instance)
olki
Re: Email notifications not sent
Post by olki »
Perhaps I see no log because the warn() function in the perl script is not working.
I've added on top of the script the following code:
Info( "Starting modified zmfilter\n" );
warn( "Warning Starting modified zmfilter\n" );
Error( "Error Starting modified zmfilter\n" );
Only lines 1&3 are displayed in the log. Do you see any reason for that?
edit: I did some research (it the first time I look into perl scripts), and I think that the warn function is writting a message to the STDERR device, which I assume to be the console. So how the zm warnings are written to the log files?
olki
Re: Email notifications not sent (more or less solved)
Post by olki »
I've modified the zmfilter.pl script to be able to see the warn log by changing the warn() function by the Info(). It's a little bit odd (as the warn is used everywhere in the scripts), but it works... So I could debug and I had to untick the NEW_MAIL_MODULES option + set as EMAIL_HOST the FQDN of my zoneminder server.
Then I see in the logs the "Notification email sent" message, but in receive nothing in my mailbox and the exim log file show no entry for any message from zm.
I this point, I'm lost and I don't know what to do to debug my system further.
olki
Post by olki »
Finally, I managed to get the emails sent by changing the "smtp" method in the zmfilter script by "sendmail" and ticking the NEW_MAIL_MODULES option.
The warn() function that does not display anything in the logs still kills me!
