I keep failing at upgrading to 1.24.4.
Current attempts fails with an error "Starting ZoneMinder: Bareword "ZM_SERVER_HOST" not allowed"
I access the console page with ZM stopped and there is now a new column called "Server Host" which is blank...
Pull up a monitor dialog and you get:
name
server host
source_type
function
(But it displays in this order on the webpage):
name
function
server host
source
What is this new field? (Is it a new field?) In my working ZMLarch version 1.24.2 there is no "server host" field.
I don't see it in any screenshots or mentioned in instructions....
EDIT--No responses yet...maybe this visual will help?
What is "Server Host" and what does it mean in 1.24.4?
Re: What is "Server Host" and what does it mean in 1.24.4?
I solved my problem by dumping that install and starting over according to this guide:
http://www.cshenry.net/installing-zonem ... -centos-56
It worked perfectly.
I now have analog and ip cams working perfectly on hardware I have struggled with for weeks!
(I am still in shock!)
I'm seeing the same issue. A new column has appeared on the home page called "Server Host". What does this mean?
- zoneminder
- Site Admin
- Contact:
Where are you installing from? This is not present in ZM available from here.
Phil
Wow thats a strange one.
mastertheknife
mastertheknife
Kfir Itzhak.
it's coming from the ppa for ubuntu natty that is in this forum: http://www.zoneminder.com/forums/viewto ... 21&t=17863
People who have tried various approaches to updating to 1.24.4 are trying that too.
- zoneminder
- Site Admin
- Contact:
Ah ok. Can't help much with that then.
Phil
