All but one camera feed went blue after 1.24.4 Upgrade
rotohammer
Re: All but one camera feed went blue after 1.24.4 Upgrade
Post by rotohammer »
I've applied the patch to 1.24.4 and it is working fine now. I'll continue to be testing today.
NokSuKao
Post by NokSuKao »
for me it doesn't change anything. still the same problem.
NokSuKao
zoneminder
Site Admin
Post by zoneminder »
Can you post debug as bukowski did earlier in the thread in case you have a different issue.
Phil
NokSuKao
Post by NokSuKao »
no problem, here is the debug output:
07/29/11 13:44:36.086720 zmc_m1000[-1].DB1-zm_monitor.cpp/347 [mem.size=36865524]
07/29/11 13:44:36.086743 zmc_m1000[-1].DB1-zm_monitor.cpp/371 [Unable to map file /dev/shm/zm.mmap.1000 (36865524 bytes) to locked memory, trying unlocked]
07/29/11 13:44:36.130463 zmc_m1000[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
07/29/11 13:44:36.265698 zmc_m1000[-1].DB1-zm_monitor.cpp/2509 [Loaded monitor 1000(sped1), 1 zones]
07/29/11 13:44:36.265714 zmc_m1000[-1].INF-zmc.cpp/191 [Starting Capture]
07/29/11 13:44:36.276629 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/106 [Connected to host, socket = 4]
07/29/11 13:44:36.276674 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/128 [Request sent]
07/29/11 13:44:36.303487 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 17 bytes]
07/29/11 13:44:36.303523 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 17 bytes]
07/29/11 13:44:36.303531 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [HTTP/1.1 200 OK
07/29/11 13:44:36.303540 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/653 [Got http header 'HTTP/1.1 200 OK
07/29/11 13:44:36.303549 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/806 [Unable to extract entire header from stream, continuing]
07/29/11 13:44:36.305094 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 198 bytes]
07/29/11 13:44:36.305113 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 198 bytes]
07/29/11 13:44:36.305120 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Date: Fri, 29 Jul 2011 20:00:49 GMT
Server: ver2.4 rev0
Connection: Close
Content-Type: image/jpeg
Set-Cookie: Session=0
Accept-Ranges: bytes
Cache-Control: no-cache
Content-Length: 41310
07/29/11 13:44:36.305127 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Date: Fri, 29 Jul 2011 20:00:49 GMT
Server: ver2.4 rev0
Connection: Close
07/29/11 13:44:36.305134 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Server: ver2.4 rev0
Connection: Close
07/29/11 13:44:36.305140 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Server: ver2.4 rev0
Connection: Close
07/29/11 13:44:36.305145 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Connection: Close
07/29/11 13:44:36.305187 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/658 [Got connection header 'Connection: Close
07/29/11 13:44:36.305195 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Type: image/jpeg
07/29/11 13:44:36.305201 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/668 [Got content type header 'Content-Type: image/jpeg
07/29/11 13:44:36.305206 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Set-Cookie: Session=0
07/29/11 13:44:36.305212 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Set-Cookie: Session=0
07/29/11 13:44:36.305218 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Accept-Ranges: bytes
07/29/11 13:44:36.305223 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Accept-Ranges: bytes
07/29/11 13:44:36.305229 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Cache-Control: no-cache
07/29/11 13:44:36.305234 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Cache-Control: no-cache
07/29/11 13:44:36.305240 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Length: 41310
07/29/11 13:44:36.305245 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/663 [Got content length header 'Content-Length: 41310
07/29/11 13:44:36.305253 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/717 [Got status '200' (OK), http version 1.1]
07/29/11 13:44:36.305259 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/724 [Got connection 'Close']
07/29/11 13:44:36.305265 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/730 [Got content length '41310']
07/29/11 13:44:36.305270 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/758 [Got content type 'image/jpeg']
07/29/11 13:44:36.307546 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.307568 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.307755 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.307770 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.308254 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.308267 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.309274 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.309289 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.309487 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.309498 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.312279 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.312301 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.312479 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.312492 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.313095 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.313109 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.313417 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.313430 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.313582 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.313633 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.316813 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.316839 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.317035 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.317048 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.317657 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.317673 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.317908 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.317921 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.318520 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.318536 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.321624 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.321652 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.321846 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.321861 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.322091 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 207 bytes]
07/29/11 13:44:36.322104 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 207 bytes]
07/29/11 13:44:36.325665 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.325693 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.325890 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.325905 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.326133 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1253 bytes]
07/29/11 13:44:36.326148 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1253 bytes]
07/29/11 13:44:36.328941 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.328973 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.329166 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.329180 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.330034 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.330051 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.330267 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.330280 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.330506 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.330519 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.332646 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.332669 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.332857 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.332871 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.336987 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1890 bytes]
07/29/11 13:44:36.337024 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1890 bytes]
07/29/11 13:44:36.337042 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/978 [Got end of image by length, content-length = 41310]
07/29/11 13:44:36.337070 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/114 [Disconnected from host]
07/29/11 13:44:36.337077 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/1053 [Returning 41310 (41310) bytes of captured content]
07/29/11 13:44:36.345700 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/106 [Connected to host, socket = 4]
07/29/11 13:44:36.345781 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/128 [Request sent]
07/29/11 13:44:36.364368 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 17 bytes]
07/29/11 13:44:36.364394 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 17 bytes]
07/29/11 13:44:36.364402 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [HTTP/1.1 200 OK
07/29/11 13:44:36.767039 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/653 [Got http header 'HTTP/1.1 200 OK
07/29/11 13:44:36.767045 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/806 [Unable to extract entire header from stream, continuing]
07/29/11 13:44:36.771014 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 7498 bytes]
07/29/11 13:44:36.771045 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 7498 bytes]
07/29/11 13:44:36.771055 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
Content-Length: 41326
ÿØÿþ]
07/29/11 13:44:36.771063 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:36.771069 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Server: ver2.4 rev0
Connection: Close
ÿØÿþ]
07/29/11 13:44:36.771075 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:36.771081 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Connection: Close
ÿØÿþ]
07/29/11 13:44:36.771087 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/658 [Got connection header 'Connection: Close
ÿØÿþ']
07/29/11 13:44:36.771093 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Type: image/jpeg
ÿØÿþ]
07/29/11 13:44:36.771102 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/668 [Got content type header 'Content-Type: image/jpeg
ÿØÿþ']
07/29/11 13:44:36.771107 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Set-Cookie: Session=0
ÿØÿþ]
07/29/11 13:44:36.771113 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Set-Cookie: Session=0
ÿØÿþ']
07/29/11 13:44:36.771167 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Accept-Ranges: bytes
ÿØÿþ]
07/29/11 13:44:36.771174 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Accept-Ranges: bytes
ÿØÿþ']
07/29/11 13:44:36.771180 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Cache-Control: no-cache
ÿØÿþ]
07/29/11 13:44:36.771186 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Cache-Control: no-cache
ÿØÿþ']
07/29/11 13:44:36.771192 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Length: 41326
ÿØÿþ]
07/29/11 13:44:36.771212 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/663 [Got content length header 'Content-Length: 41326
ÿØÿþ']
07/29/11 13:44:36.771221 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/717 [Got status '200' (OK), http version 1.1]
07/29/11 13:44:36.771227 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/724 [Got connection 'Close']
07/29/11 13:44:36.771233 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/730 [Got content length '41326']
07/29/11 13:44:36.771239 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/758 [Got content type 'image/jpeg']
07/29/11 13:44:36.773272 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 4380 bytes]
07/29/11 13:44:36.773297 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 4380 bytes]
07/29/11 13:44:36.774186 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 2920 bytes]
07/29/11 13:44:36.774203 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 2920 bytes]
07/29/11 13:44:36.777136 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.777161 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.777614 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.777627 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.778110 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.778123 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.779102 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.779118 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.779337 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.779349 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.780830 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.780848 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.781052 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.781066 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.781297 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 207 bytes]
07/29/11 13:44:36.781309 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 207 bytes]
07/29/11 13:44:36.785944 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.785980 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.786299 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.786315 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.786559 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1253 bytes]
07/29/11 13:44:36.786572 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1253 bytes]
07/29/11 13:44:36.789340 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.789370 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.789586 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.789599 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.789880 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.789931 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.790413 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.790427 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.790647 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.790660 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.793243 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.793267 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.793592 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.793605 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.793966 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.793979 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.794200 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 446 bytes]
07/29/11 13:44:36.794217 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 446 bytes]
07/29/11 13:44:36.794224 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/978 [Got end of image by length, content-length = 41326]
07/29/11 13:44:36.794245 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/114 [Disconnected from host]
07/29/11 13:44:36.794252 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/1053 [Returning 41326 (41326) bytes of captured content]
07/29/11 13:44:36.945641 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/106 [Connected to host, socket = 4]
07/29/11 13:44:36.945680 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/128 [Request sent]
07/29/11 13:44:36.966982 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 215 bytes]
07/29/11 13:44:36.967010 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 215 bytes]
07/29/11 13:44:36.967018 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [HTTP/1.1 200 OK
Server: ver2.4 rev0
Connection: Close
Content-Length: 41330
ÿØÿþ]
07/29/11 13:44:36.967025 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/653 [Got http header 'HTTP/1.1 200 OK
Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:36.967032 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿØÿþ]
07/29/11 13:44:36.967038 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:36.967044 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Server: ver2.4 rev0
Connection: Close
ÿØÿþ]
07/29/11 13:44:36.967050 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:36.967056 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Connection: Close
ÿØÿþ]
07/29/11 13:44:36.967062 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/658 [Got connection header 'Connection: Close
ÿØÿþ']
07/29/11 13:44:36.967103 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Type: image/jpeg
ÿØÿþ]
07/29/11 13:44:36.967111 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/668 [Got content type header 'Content-Type: image/jpeg
ÿØÿþ']
07/29/11 13:44:36.967117 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Set-Cookie: Session=0
ÿØÿþ]
07/29/11 13:44:36.967123 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Set-Cookie: Session=0
ÿØÿþ']
07/29/11 13:44:36.967129 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Accept-Ranges: bytes
ÿØÿþ]
07/29/11 13:44:36.967135 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Accept-Ranges: bytes
ÿØÿþ']
07/29/11 13:44:36.967141 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Cache-Control: no-cache
ÿØÿþ]
07/29/11 13:44:36.967147 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Cache-Control: no-cache
ÿØÿþ']
07/29/11 13:44:36.967153 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Length: 41330
ÿØÿþ]
07/29/11 13:44:36.967159 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/663 [Got content length header 'Content-Length: 41330
ÿØÿþ']
07/29/11 13:44:36.967166 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/717 [Got status '200' (OK), http version 1.1]
07/29/11 13:44:36.967172 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/724 [Got connection 'Close']
07/29/11 13:44:36.967178 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/730 [Got content length '41330']
07/29/11 13:44:36.967184 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/758 [Got content type 'image/jpeg']
07/29/11 13:44:36.970657 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 4380 bytes]
07/29/11 13:44:36.970679 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 4380 bytes]
07/29/11 13:44:36.972083 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.972104 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.972561 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.972574 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.974417 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.974434 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.974937 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.974951 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.975179 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 2920 bytes]
07/29/11 13:44:36.975193 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 2920 bytes]
07/29/11 13:44:36.975909 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.975922 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.978643 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.978666 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.979360 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 2920 bytes]
07/29/11 13:44:36.979374 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 2920 bytes]
07/29/11 13:44:36.979979 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.979992 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.980223 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.980235 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.982326 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:36.982352 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:36.983044 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1667 bytes]
07/29/11 13:44:36.983058 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1667 bytes]
07/29/11 13:44:36.991198 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 5633 bytes]
07/29/11 13:44:36.991224 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 5633 bytes]
07/29/11 13:44:36.995552 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 10670 bytes]
07/29/11 13:44:36.995600 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 10670 bytes]
07/29/11 13:44:36.995611 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/978 [Got end of image by length, content-length = 41330]
07/29/11 13:44:36.995635 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/114 [Disconnected from host]
07/29/11 13:44:36.995642 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/1053 [Returning 41330 (41330) bytes of captured content]
07/29/11 13:44:37.145220 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/106 [Connected to host, socket = 4]
07/29/11 13:44:37.145260 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/128 [Request sent]
07/29/11 13:44:37.171591 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 4595 bytes]
07/29/11 13:44:37.171617 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 4595 bytes]
07/29/11 13:44:37.171626 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [HTTP/1.1 200 OK
Server: ver2.4 rev0
Connection: Close
Content-Length: 41304
ÿØÿþ]
07/29/11 13:44:37.171634 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/653 [Got http header 'HTTP/1.1 200 OK
Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:37.171640 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿØÿþ]
07/29/11 13:44:37.171647 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:37.171653 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Server: ver2.4 rev0
Connection: Close
ÿØÿþ]
07/29/11 13:44:37.171659 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:37.171668 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Connection: Close
ÿØÿþ]
07/29/11 13:44:37.171675 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/658 [Got connection header 'Connection: Close
ÿØÿþ']
07/29/11 13:44:37.171681 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Type: image/jpeg
ÿØÿþ]
07/29/11 13:44:37.171686 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/668 [Got content type header 'Content-Type: image/jpeg
ÿØÿþ']
07/29/11 13:44:37.171730 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Set-Cookie: Session=0
ÿØÿþ]
07/29/11 13:44:37.171738 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Set-Cookie: Session=0
ÿØÿþ']
07/29/11 13:44:37.171744 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Accept-Ranges: bytes
ÿØÿþ]
07/29/11 13:44:37.171750 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Accept-Ranges: bytes
ÿØÿþ']
07/29/11 13:44:37.171756 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Cache-Control: no-cache
ÿØÿþ]
07/29/11 13:44:37.171762 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Cache-Control: no-cache
ÿØÿþ']
07/29/11 13:44:37.171768 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Length: 41304
ÿØÿþ]
07/29/11 13:44:37.171773 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/663 [Got content length header 'Content-Length: 41304
ÿØÿþ']
07/29/11 13:44:37.171781 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/717 [Got status '200' (OK), http version 1.1]
07/29/11 13:44:37.171787 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/724 [Got connection 'Close']
07/29/11 13:44:37.171793 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/730 [Got content length '41304']
07/29/11 13:44:37.171815 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/758 [Got content type 'image/jpeg']
07/29/11 13:44:37.171826 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.171835 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.172482 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.172497 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.176412 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.176434 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.177012 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.177027 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.177259 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 2920 bytes]
07/29/11 13:44:37.177274 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 2920 bytes]
07/29/11 13:44:37.177505 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.177518 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.178621 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.178637 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.178981 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.178996 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.179470 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.179482 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.179723 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.179735 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.180573 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.180590 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.183435 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.183461 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.184403 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1667 bytes]
07/29/11 13:44:37.184419 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1667 bytes]
07/29/11 13:44:37.192185 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 5633 bytes]
07/29/11 13:44:37.192214 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 5633 bytes]
07/29/11 13:44:37.193154 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 4380 bytes]
07/29/11 13:44:37.193178 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 4380 bytes]
07/29/11 13:44:37.193492 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.193505 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.195336 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.195355 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.195614 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.195627 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.195890 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.195903 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.196146 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 424 bytes]
07/29/11 13:44:37.196179 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 424 bytes]
07/29/11 13:44:37.196191 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/978 [Got end of image by length, content-length = 41304]
07/29/11 13:44:37.196232 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/114 [Disconnected from host]
07/29/11 13:44:37.196245 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/1053 [Returning 41304 (41304) bytes of captured content]
07/29/11 13:44:37.345537 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/106 [Connected to host, socket = 4]
07/29/11 13:44:37.345574 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/128 [Request sent]
07/29/11 13:44:37.370989 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 215 bytes]
07/29/11 13:44:37.371016 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 215 bytes]
07/29/11 13:44:37.371024 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [HTTP/1.1 200 OK
Server: ver2.4 rev0
Connection: Close
Content-Length: 41404
ÿØÿþ]
07/29/11 13:44:37.371031 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/653 [Got http header 'HTTP/1.1 200 OK
Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:37.371037 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿØÿþ]
07/29/11 13:44:37.371043 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:37.371049 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Server: ver2.4 rev0
Connection: Close
ÿØÿþ]
07/29/11 13:44:37.371055 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Server: ver2.4 rev0
Connection: Close
ÿØÿþ']
07/29/11 13:44:37.371061 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Connection: Close
ÿØÿþ]
07/29/11 13:44:37.371066 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/658 [Got connection header 'Connection: Close
ÿØÿþ']
07/29/11 13:44:37.371108 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Type: image/jpeg
ÿØÿþ]
07/29/11 13:44:37.371115 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/668 [Got content type header 'Content-Type: image/jpeg
ÿØÿþ']
07/29/11 13:44:37.371121 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Set-Cookie: Session=0
ÿØÿþ]
07/29/11 13:44:37.371127 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Set-Cookie: Session=0
ÿØÿþ']
07/29/11 13:44:37.371132 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Accept-Ranges: bytes
ÿØÿþ]
07/29/11 13:44:37.371137 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Accept-Ranges: bytes
ÿØÿþ']
07/29/11 13:44:37.371143 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Cache-Control: no-cache
ÿØÿþ]
07/29/11 13:44:37.371148 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Cache-Control: no-cache
ÿØÿþ']
07/29/11 13:44:37.371154 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Length: 41404
ÿØÿþ]
07/29/11 13:44:37.371159 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/663 [Got content length header 'Content-Length: 41404
ÿØÿþ']
07/29/11 13:44:37.371167 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/717 [Got status '200' (OK), http version 1.1]
07/29/11 13:44:37.371173 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/724 [Got connection 'Close']
07/29/11 13:44:37.371178 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/730 [Got content length '41404']
07/29/11 13:44:37.371184 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/758 [Got content type 'image/jpeg']
07/29/11 13:44:37.374996 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 7300 bytes]
07/29/11 13:44:37.375021 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 7300 bytes]
07/29/11 13:44:37.375842 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.375855 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.376825 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 2920 bytes]
07/29/11 13:44:37.376848 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 2920 bytes]
07/29/11 13:44:37.376977 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.376991 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.377384 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.377412 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.380269 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.380297 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.380495 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 2920 bytes]
07/29/11 13:44:37.380509 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 2920 bytes]
07/29/11 13:44:37.381480 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.381494 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.381717 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.381731 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.384294 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.384319 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.384536 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1667 bytes]
07/29/11 13:44:37.384589 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1667 bytes]
07/29/11 13:44:37.389001 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 4173 bytes]
07/29/11 13:44:37.389033 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 4173 bytes]
07/29/11 13:44:37.391777 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.391800 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.392026 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.392038 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.392376 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.392389 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.392628 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.392642 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.392890 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.392904 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.395106 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.395126 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.395392 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.395404 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.395642 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 1460 bytes]
07/29/11 13:44:37.395655 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 1460 bytes]
07/29/11 13:44:37.395890 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 524 bytes]
07/29/11 13:44:37.395902 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 524 bytes]
07/29/11 13:44:37.395909 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/978 [Got end of image by length, content-length = 41404]
07/29/11 13:44:37.395931 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/114 [Disconnected from host]
07/29/11 13:44:37.395938 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/1053 [Returning 41404 (41404) bytes of captured content]
07/29/11 13:44:37.547335 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/106 [Connected to host, socket = 4]
07/29/11 13:44:37.547370 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/128 [Request sent]
07/29/11 13:44:37.569611 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 17 bytes]
07/29/11 13:44:37.569640 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 17 bytes]
07/29/11 13:44:37.569647 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [HTTP/1.1 200 OK
07/29/11 13:44:37.569654 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/653 [Got http header 'HTTP/1.1 200 OK
07/29/11 13:44:37.569660 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/806 [Unable to extract entire header from stream, continuing]
07/29/11 13:44:37.570709 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 198 bytes]
07/29/11 13:44:37.570723 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 198 bytes]
07/29/11 13:44:37.570730 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
Content-Length: 41388
ÿÀ]
07/29/11 13:44:37.570736 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Date: Fri, 29 Jul 2011 20:00:50 GMT
Server: ver2.4 rev0
Connection: Close
ÿÀ']
07/29/11 13:44:37.570742 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Server: ver2.4 rev0
Connection: Close
ÿÀ]
07/29/11 13:44:37.570748 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Server: ver2.4 rev0
Connection: Close
ÿÀ']
07/29/11 13:44:37.570792 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Connection: Close
ÿÀ]
07/29/11 13:44:37.570800 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/658 [Got connection header 'Connection: Close
ÿÀ']
07/29/11 13:44:37.570806 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Type: image/jpeg
ÿÀ]
07/29/11 13:44:37.570812 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/668 [Got content type header 'Content-Type: image/jpeg
ÿÀ']
07/29/11 13:44:37.570818 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Set-Cookie: Session=0
ÿÀ]
07/29/11 13:44:37.570825 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Set-Cookie: Session=0
ÿÀ']
07/29/11 13:44:37.570831 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Accept-Ranges: bytes
ÿÀ]
07/29/11 13:44:37.570840 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Accept-Ranges: bytes
ÿÀ']
07/29/11 13:44:37.570846 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Cache-Control: no-cache
ÿÀ]
07/29/11 13:44:37.570852 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/672 [Got ignored header 'Cache-Control: no-cache
ÿÀ']
07/29/11 13:44:37.570858 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Content-Length: 41388
ÿÀ]
07/29/11 13:44:37.570863 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/663 [Got content length header 'Content-Length: 41388
ÿÀ']
07/29/11 13:44:37.570871 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/717 [Got status '200' (OK), http version 1.1]
07/29/11 13:44:37.570877 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/724 [Got connection 'Close']
07/29/11 13:44:37.570883 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/730 [Got content length '41388']
07/29/11 13:44:37.570889 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/758 [Got content type 'image/jpeg']
07/29/11 13:44:40.072989 zmc_m1000[-1].WAR-zm_remote_camera_http.cpp/143 [Select timed out]
07/29/11 13:44:40.073104 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/114 [Disconnected from host]
07/29/11 13:44:40.073113 zmc_m1000[-1].ERR-zm_remote_camera_http.cpp/969 [Connection dropped by remote end]
07/29/11 13:44:40.073126 zmc_m1000[-1].WAR-zm_remote_camera_http.cpp/1092 [Unable to capture image, retrying]
07/29/11 13:44:40.075452 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/106 [Connected to host, socket = 4]
07/29/11 13:44:40.075484 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/128 [Request sent]
07/29/11 13:44:40.089229 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 17 bytes]
07/29/11 13:44:40.089259 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 17 bytes]
07/29/11 13:44:40.089267 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [HTTP/1.1 200 OK
Date: Fri, 29 Jul 2011 20:00:50 GMT]
07/29/11 13:44:40.089274 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/653 [Got http header 'HTTP/1.1 200 OK
Date: Fri, 29 Jul 2011 20:00:50 GMT']
07/29/11 13:44:40.089281 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/806 [Unable to extract entire header from stream, continuing]
07/29/11 13:44:40.090875 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/174 [Expecting 198 bytes]
07/29/11 13:44:40.090894 zmc_m1000[-1].DB3-zm_remote_camera_http.cpp/199 [Read 198 bytes]
07/29/11 13:44:40.090945 zmc_m1000[-1].DB6-zm_remote_camera_http.cpp/645 [Date: Fri, 29 Jul 2011 20:00:53 GMT
I hope it isn't too long.
cu
NokSuKao
zoneminder
Site Admin
This seems to be a different issue, the lines
would appear to suggest that your camera sends the headers for the image but then fails to actually send the image and ZM times out after it's configured interval of 2.5 seconds. You can increase this but it's quite a long time to be waiting for the image. I don't think this is a ZM issue as such though I have been wrong before.
Phil
NokSuKao
Post by NokSuKao »
the problem only exists with the PANASONIC WV-NF302. With the AXIS 1011 camera i could record jpegs in RECORD mode! In version 1.24.2 everthink works fine.
I did not change the options of the camera!
cu
NokSuKao
bukowski
Post by bukowski »
patch work for me!!!! thanx
zoneminder
Site Admin
NokSuKao wrote:Hi,
cu
NokSuKao
If you still have a 1.24.2 system available I would be interested to see what the similar debug on that system shows.
Phil
NokSuKao
Post by NokSuKao »
i've tested the ZM 1.24.4 in an other warehouse and everything works! So i think there has to be something with the camera options or
the cable/switch etc.Next week i will take a look at this.
NokSuKao
scanto
Post by scanto »
have updated the file with the patch ZoneMinder-1.24.4.tar.gz? FreeBSD does not work. I have the old file so I apply the patch? because it worked before
scanto
Post by scanto »
fix for freebsd:
used to compile the old version of ZoneMinder 1.24.2 zm_remote_camera_http.cpp
byeee
NokSuKao
Post by NokSuKao »
for me it looks like there i too much traffic on the switch. i have 20 panaconic ip cameras running on one poe switch. If i turn half of the cameras off everyting runs well. If i turn them on the signal is lost in version 1.24.4. In version 1.24.2 (another server) everything works fine also with all cameras on. I will install a second siwtch to solve the problem.
thx for help
NokSukao
nabetse_x
Post by nabetse_x »
Hi all,
how do i apply the patch mentioned above ???
i've the same problem with vivotek 7330 , and can't fix it.
i've installed zoneminder on Ubuntu with .deb package (apt-get)
thanks for your help!
