Hello im wondering if anyone has any advice on what hidden ip cameras will work well with zoneminder. I need to set up a covert camera and already have 8 q-see bnc cameras so im planning on building a box for zoneminder to support several ip cameras and about 10 BNC cameras.
Any suggestions of ones that definitly work and are a descent camera for the buck?
Looking for hidden ip camera that works with zoneminder
Re: Looking for hidden ip camera that works with zoneminder
http://www.amazon.com/Q-SEE-QSMCC-Ultra ... B0002340M4
You mentioned IP cameras as well as BNC. I've used these and they work well, but they are BNC rather than IP. I just drilled a small hole in the drop ceilings and shaved the tile a bit to get the camera at the correct angle and then used some silicone to keep it in place.
