ZoneMinder 1.25.0 - preview
- zoneminder
- Site Admin
- Contact:
Re: ZoneMinder 1.25.0 - preview
Ok. I am going to have to set up a VM with the same distro as you and investigate further.
Phil
i'm using the Ubuntu 10.04 LTSzoneminder wrote:Ok. I am going to have to set up a VM with the same distro as you and investigate further.
Kind regards
JuVeNaL
- zoneminder
- Site Admin
- Contact:
Ok. You said 11 originally. Can you just confirm which?
I have just built on 11.04 with no problems and previously built on 10 also. Have you tried doing a 'make clean' first?
Phil
it's on a ubuntu 10.04 LTS and i made a 'make clean' .... and then make ... and same error ...zoneminder wrote:Ok. You said 11 originally. Can you just confirm which?
- zoneminder
- Site Admin
- Contact:
Just built from scratch on 10.04 LTS without issues. There must be something odd about your system. Can you grep for PATH_MAX in /usr/include/*.h and /usr/include/*/*.h and see where it shows up.
Phil
Sorry but i'm not a expert in linux ... how can i do a grep in those files ?zoneminder wrote:Just built from scratch on 10.04 LTS without issues. There must be something odd about your system. Can you grep for PATH_MAX in /usr/include/*.h and /usr/include/*/*.h and see where it shows up.
i have this error now:
zm_user.cpp: In constructor ‘User::User(char**&)’:
zm_user.cpp:38: error: ‘strncpy’ was not declared in this scope
zm_user.cpp:40: error: ‘atoi’ was not declared in this scope
zm_user.cpp:50: error: ‘strlen’ was not declared in this scope
zm_user.cpp: In function ‘User* zmLoadUser(const char*, const char*)’:
zm_user.cpp:117: error: ‘exit’ was not declared in this scope
zm_user.cpp:124: error: ‘exit’ was not declared in this scope
zm_user.cpp: In function ‘User* zmLoadAuthUser(const char*, bool)’:
zm_user.cpp:161: error: ‘getenv’ was not declared in this scope
zm_user.cpp:176: error: ‘exit’ was not declared in this scope
zm_user.cpp:183: error: ‘exit’ was not declared in this scope
zm_user.cpp:220: error: ‘strlen’ was not declared in this scope
zm_user.cpp:228: error: ‘strcmp’ was not declared in this scope
make[2]: *** [zm_user.o] Error 1
make[2]: Leaving directory `/usr/src/ZoneMinder-1.25.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/ZoneMinder-1.25.0'
make: *** [all] Error 2
here the resultzoneminder wrote:Just built from scratch on 10.04 LTS without issues. There must be something odd about your system. Can you grep for PATH_MAX in /usr/include/*.h and /usr/include/*/*.h and see where it shows up.
/usr/include/stdlib.h: PATH_MAX chars or more, returns null with `errno' set to
/usr/include/stdlib.h: ENAMETOOLONG; if the name fits in fewer than PATH_MAX chars,
/usr/include/tic.h:#define MAX_ALIAS 32 /* smaller than POSIX minimum for PATH_MAX */
/usr/include/unistd.h: BUF and return NULL. BUF should be at least PATH_MAX bytes long. */
root@pascal-desktop:/usr/src/ZoneMinder-1.25.0# grep PATH_MAX /usr/include/*/*.h
/usr/include/bits/confname.h: _PC_PATH_MAX,
/usr/include/bits/confname.h:#define _PC_PATH_MAX _PC_PATH_MAX
/usr/include/bits/posix1_lim.h:#define _POSIX_PATH_MAX 256
/usr/include/bits/stdlib.h: "least PATH_MAX bytes long buffer");
/usr/include/bits/stdlib.h:#if defined _LIBC_LIMITS_H_ && defined PATH_MAX
/usr/include/bits/stdlib.h: if (__bos (__resolved) < PATH_MAX)
/usr/include/linux/limits.h:#define PATH_MAX 4096 /* # chars in a path name including nul */
/usr/include/linux/nfs3.h:#define NFS3_MAXPATHLEN PATH_MAX
/usr/include/linux/nfs4.h:#define NFS4_MAXPATHLEN PATH_MAX
/usr/include/linux/sysctl.h: NET_SCTP_PATH_MAX_RETRANS = 8,
/usr/include/linux/un.h:#define UNIX_PATH_MAX 108
/usr/include/linux/un.h: char sun_path[UNIX_PATH_MAX]; /* pathname */
/usr/include/sysfs/libsysfs.h:#define SYSFS_PATH_MAX 256
/usr/include/sysfs/libsysfs.h: char path[SYSFS_PATH_MAX];
/usr/include/sys/param.h:#define MAXPATHLEN PATH_MAX
/usr/include/X11/InitialI.h:#ifndef PATH_MAX
/usr/include/X11/InitialI.h:#define PATH_MAX 512
/usr/include/X11/InitialI.h:#define PATH_MAX MAXPATHLEN
/usr/include/X11/InitialI.h:#define PATH_MAX 1024
/usr/include/X11/Xosdefs.h:# ifndef PATH_MAX
/usr/include/X11/Xosdefs.h:# define PATH_MAX 4096
/usr/include/X11/Xosdefs.h:# define PATH_MAX 1024
/usr/include/X11/Xos.h:# define PATH_MAX 4096
/usr/include/X11/Xos_r.h:# ifdef _POSIX_PATH_MAX
/usr/include/X11/Xos_r.h: char buf[_POSIX_PATH_MAX];
/usr/include/X11/Xos_r.h:# elif defined(_POSIX_PATH_MAX)
/usr/include/X11/Xwindows.h:#if defined(WIN32) && (!defined(PATH_MAX) || PATH_MAX < 1024)
/usr/include/X11/Xwindows.h:# undef PATH_MAX
/usr/include/X11/Xwindows.h:# define PATH_MAX 1024
- zoneminder
- Site Admin
- Contact:
I am at a bit of a loss then as it is defined in limits.h. PATH_MAX is used in zm_event.cpp, zm_monitor.cpp and zm_zone.cpp. Do those all compile ok? You could try copying some of the include directives from those into zm_local_camera.cpp to see if any of that fixes it but it should not be necessary.
Phil
i receive now the following error
make all-recursive
mv -f .deps/zm_timer.Tpo .deps/zm_timer.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -D__STDC_CONSTANT_MACROS -march=native -O2 -pipe -march=native -O2 -pipe -MT zm_user.o -MD -MP -MF .deps/zm_user.Tpo -c -o zm_user.o zm_user.cpp
zm_user.cpp:33:19: warning: extra tokens at end of #include directive
zm_user.cpp:58: error: ‘atoi’ was not declared in this scope
zm_user.cpp:135: error: ‘exit’ was not declared in this scope
zm_user.cpp:142: error: ‘exit’ was not declared in this scope
zm_user.cpp:179: error: ‘getenv’ was not declared in this scope
zm_user.cpp:194: error: ‘exit’ was not declared in this scope
zm_user.cpp:201: error: ‘exit’ was not declared in this scope
@zoneminder.
Please add to the zm_user.cpp in the SVN, after "#include <stdio.h>" the follow include lines
#include <string.h>
#include <stdlib.h>
these changes solve compilation issue of 1.25.0.
BR
- Pierluigi
#include <string.h>
#include <stdlib.h>
BR
- Pierluigi
- zoneminder
- Site Admin
- Contact:
Thanks. These are included in the current 1.25.0 tarball so it is probably worth redownloading if anyone is hitting this issue.
Phil
It work now .. but another error ... i have no image with my Foscam ( i use the same configuration that work on another zoneminder 1.24.3 installation ... and in the logs i see error "Socket_sendto (/tmp/zm/zms-300837s.sock ) failed : No such file or directory ...zoneminder wrote:Thanks. These are included in the current 1.25.0 tarball so it is probably worth redownloading if anyone is hitting this issue.
Kind regards
JuVeNaL
I'm little bit confused because SVN trunk is less update than tar.gz in post #1 (3487 vs 3492).
Which source code I refer to have latest preview ?
Regrads,
- Pierluigi
Regrads,
- Pierluigi
- zoneminder
- Site Admin
- Contact:
The public SVN is a read-only mirror of the main repository and so lags a bit behind sometimes. I have updated it so it should be in sync now.
Phil
- zoneminder
- Site Admin
- Contact:
