how to move from http to https?
Just wondering if there is an easy way to move ZM from just using http to https? Self-signed cert would be enough. I don't like using clear text for login, as my site does get probed pretty frequently, and I'm sure it will be compromised at some point.
Re: how to move from http to https?
I use Amahi server which sits on top of Fedora... I can't post a link (cause the forum rules think it's too spammy), but if you google "Amahi SSL" , there's a full set of instructions the third google result down (at least today anyway). They don't appear to be too amahi specific... I set mine up and created my certificate last week with success. That said, I implemented openvpn. I think it's a more complete solution, especially if you're accessing anything beyond 80 & 443... good luck. jbmia
Thanks. I'm also running Fedora Core (14 or 15, can't remember), so this should work.
