I downloaded Cambozola ver .65 and found that I could not view more than 2 screens in the montage view. The two views were not specific to any particular source, it would just view the first two that came up.
Once I downloaded ver .50 the problem went away.
SUSE 9.2
ZM 1.20.1
Apache2
PHP4.3.8
Used Internet Explorer on XP Pro
Cambozola .65 vs. .50
The only thing I found so far is just to use the older version
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
I don't know what I've done, but Cambozola 0.65 do work with more than 2 cameras in the montage view. Normaly I use Firefox which don't need cambozola, but when I try IE is starts the applet without problems (only tried with four cameras so far).
I use MDK 10.1 OE and I've ZM_CAN_STREAM to AUTO
cheers, tord
cheers, tord
