I have a Zoneminder 1.24.4 installation and I created a filter to automatically archive events that happen during night time. The filter works like expected when run with the "Execute" button but it is not automatically executed.
I did not find anything interesting in the /var/log/zm/ logfiles.
What should I check next?
-Cg
[SOLVED] Filter(s) not run automatically
Re: Filter(s) not run automatically
Unsure on 1.24.4 but in previous versions you need to check the "run in background" box and save the filter for it to execute automatically.
Ohh, I see... The checkbox was hidden in a menu behind the save button.
Thanks!
Thanks!
Re: [SOLVED] Filter(s) not run automatically
Got that fix from hard knocks university also on 1.21.3 (quite a while a go) but never forgot.
