Build error
Barry Jackson
Build error
Post by Barry Jackson »
Can anyone suggest what may be cause of this error building Zoneminder 1.24.4 in Mageia x86_64?
-------snip----------
x86_64-mageia-linux-gnu-g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -D__STDC_CONSTANT_MACROS  -O2 -g -pipe -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -MT zm_rtsp.o -MD -MP -MF .deps/zm_rtsp.Tpo -c -o zm_rtsp.o zm_rtsp.cpp
zm_rtsp.cpp: In member function ‘virtual int RtspThread::run()’:
zm_rtsp.cpp:314:9: error: format not a string literal and no format arguments
The source at zm_rtsp.cpp:314 is :-
    catch( const Exception &e )
        Error( e.getMessage().c_str() );                         // line 314
        return( -1 );
Yes - I have donated!
mitch
Re: Build error
Post by mitch »
Its probably a security catch:) It should be:
Error( "%s", e.getMessage().c_str() );
Barry Jackson
Re: Build error
mitch wrote:Its probably a security catch:) It should be:
Thanks for answering - I suspect you saw my IRC request looking down the nicks ;)
I just discovered the reason and patched it along with two more in zm_signal.cpp and it now almost builds.
I came back to delete my original post and found your reply.
I am attempting to package ZM for Mageia, but I'm a novice packager so it will be a long haul.
