/dev/video* Quits Storing To DB After 99 Events: SQL Error
Go3Team
Post by Go3Team »
I've performed multiple reinstalls and each time it craps the bed when it hits 100 events. Everything performs flawlessly up until then, but after that it quits storing the events.
I have a few IP cams that are working ok beyond the 100 event limit. I changed the databases from MyISAM to InnoDB as I read in another thread, and that didn't help. I've repaired / optimized etc the databases, and that didn't help. I've deleted the monitor and recreated it, and that didn't help. I am at a loss.
/var/log/syslog:
var/log/syslog:
Aug 26 20:51:42 zoneminder zmdc[7325]: INF ['zmc -d /dev/video0' already running at 11/08/26 20:51:30, pid = 9112]
Aug 26 20:51:43 zoneminder zmdc[7325]: INF ['zma -m 5' starting at 11/08/26 20:51:43, pid = 9149]
Aug 26 20:51:43 zoneminder zmdc[9149]: INF ['zma -m 5' started at 11/08/26 20:51:43]
Aug 26 20:51:56 zoneminder zma_m5[9149]: INF [Monitor-5: 498 - Gone into prealarm state]
Aug 26 20:51:56 zoneminder zma_m5[9149]: INF [Monitor-5: 499 - Gone into alarm state]
Aug 26 20:52:01 zoneminder zma_m5[9195]: INF [Monitor-5: 027 - Opening new event 109, alarm start]
Aug 26 20:52:05 zoneminder zmc_dvideo0[9112]: INF [Monitor-5: 1000 - Capturing at 29.41 fps]
Aug 26 20:52:07 zoneminder zma_m5[9195]: ERR [Can't insert frames: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1]
Aug 26 20:52:07 zoneminder zmdc[7325]: ERR ['zma -m 5' exited abnormally, exit status 40]
Aug 26 20:52:07 zoneminder zmwatch[7368]: INF [Restarting analysis daemon for Monitor-5, time since last analysis 6 seconds (1314406327-1314406321)]
Aug 26 20:52:07 zoneminder zmdc[7325]: INF ['zma -m 5' starting at 11/08/26 20:52:07, pid = 9208]
Aug 26 20:52:07 zoneminder zmwatch[7368]: INF ['zma -m 5' starting at 11/08/26 20:52:07, pid = 9208]
Aug 26 20:52:07 zoneminder zmdc[9208]: INF ['zma -m 5' started at 11/08/26 20:52:07]
Aug 26 20:52:07 zoneminder zma_m5[9208]: INF [Debug Level = 0, Debug Log = <none>]
Aug 26 20:52:07 zoneminder zma_m5[9208]: INF [In mode 3/1, warming up]
Aug 26 20:52:37 zoneminder zma_m5[9208]: INF [Monitor-5: 1000 - Processing at 33.33 fps]
Aug 26 20:52:38 zoneminder zmc_dvideo0[9112]: INF [Monitor-5: 2000 - Capturing at 30.30 fps]
Aug 26 20:53:11 zoneminder zma_m5[9208]: INF [Monitor-5: 2000 - Processing at 29.41 fps]
Aug 26 20:53:44 zoneminder zma_m5[9208]: INF [Monitor-5: 3000 - Processing at 30.30 fps]
Go3Team
Re: /dev/video* Quits Storing To DB After 99 Events
Post by Go3Team »
From debug log:
08/27/11 01:17:28.145534 zma_m5[-1].INF-zm_debug.c/292 [New Debug Level = 4, New Debug Log = /tmp/zm_debug.log.04235]
08/27/11 01:17:28.145781 zma_m5[-1].DB1-zm_monitor.cpp/2262 [Got 1 monitors]
08/27/11 01:17:28.148549 zma_m5[-1].DB1-zm_monitor.cpp/338 [monitor purpose=2]
08/27/11 01:17:28.148590 zma_m5[-1].DB1-zm_monitor.cpp/345 [mem.size=230404884]
08/27/11 01:17:28.148907 zma_m5[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
08/27/11 01:17:28.160613 zma_m5[-1].DB1-zm_monitor.cpp/458 [Monitor Monitor-5 has function 3]
08/27/11 01:17:28.160630 zma_m5[-1].DB1-zm_monitor.cpp/459 [Monitor Monitor-5 LBF = '%N - %B %d %Y %H:%M:%S.%f', LBX = 0, LBY = 0]
08/27/11 01:17:28.160641 zma_m5[-1].DB1-zm_monitor.cpp/460 [Monitor Monitor-5 IBC = 250, WUC = 50, pEC = 225, PEC = 300, EAF = 2, FRI = 1000, RBP = 7, FM = 0]
08/27/11 01:17:28.161903 zma_m5[-1].DB1-zm_monitor.cpp/1587 [Reloading linked monitors for monitor Monitor-5, '']
08/27/11 01:17:28.162133 zma_m5[-1].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Monitor-5]
08/27/11 01:17:28.162161 zma_m5[-1].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 639,0 639,479 0,479']
08/27/11 01:17:28.162181 zma_m5[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
08/27/11 01:17:28.162196 zma_m5[-1].DB3-zm_zone.cpp/796 [Got coordinate 639,0 from polygon string]
08/27/11 01:17:28.162207 zma_m5[-1].DB3-zm_zone.cpp/796 [Got coordinate 639,479 from polygon string]
08/27/11 01:17:28.162217 zma_m5[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,479 from polygon string]
08/27/11 01:17:28.162233 zma_m5[-1].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
08/27/11 01:17:28.162246 zma_m5[-1].DB1-zm_zone.cpp/50 [Initialised zone 5/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:9216, MxAP:230400, FB:3x3, MnFP:9216, MxFP:230400, MnBS:6144, MxBS:0, MnB:1, MxB:0, OF: 0]
08/27/11 01:17:28.175519 zma_m5[-1].DB1-zm_monitor.cpp/2459 [Loaded monitor 5(Monitor-5), 1 zones]
08/27/11 01:17:28.175647 zma_m5[-1].INF-zma.cpp/101 [In mode 3/1, warming up]
08/27/11 01:17:28.175825 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:74, WI: 169, PF = 95, RM = 155, Step = 2]
08/27/11 01:17:28.190713 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:76, WI: 169, PF = 93, RM = 157, Step = 2]
08/27/11 01:17:28.196869 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:78, WI: 170, PF = 92, RM = 158, Step = 2]
08/27/11 01:17:28.203377 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:80, WI: 170, PF = 90, RM = 160, Step = 2]
08/27/11 01:17:28.210060 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:82, WI: 170, PF = 88, RM = 162, Step = 2]
08/27/11 01:17:28.219261 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:84, WI: 170, PF = 86, RM = 164, Step = 2]
08/27/11 01:17:28.225227 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:86, WI: 170, PF = 84, RM = 166, Step = 2]
08/27/11 01:17:28.231441 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:88, WI: 170, PF = 82, RM = 168, Step = 2]
08/27/11 01:17:28.237912 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:90, WI: 170, PF = 80, RM = 170, Step = 2]
08/27/11 01:17:28.246714 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:92, WI: 171, PF = 79, RM = 171, Step = 2]
08/27/11 01:17:28.253333 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:94, WI: 171, PF = 77, RM = 173, Step = 2]
08/27/11 01:17:28.259296 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:96, WI: 171, PF = 75, RM = 175, Step = 2]
08/27/11 01:17:28.265277 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:98, WI: 171, PF = 73, RM = 177, Step = 2]
08/27/11 01:17:28.271293 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:100, WI: 171, PF = 71, RM = 179, Step = 2]
08/27/11 01:17:28.277281 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:102, WI: 171, PF = 69, RM = 181, Step = 2]
08/27/11 01:17:28.283362 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:104, WI: 171, PF = 67, RM = 183, Step = 2]
08/27/11 01:17:28.289782 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:106, WI: 171, PF = 65, RM = 185, Step = 2]
08/27/11 01:17:28.296249 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:108, WI: 171, PF = 63, RM = 187, Step = 2]
08/27/11 01:17:28.306519 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:110, WI: 172, PF = 62, RM = 188, Step = 2]
08/27/11 01:17:28.313577 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:112, WI: 172, PF = 60, RM = 190, Step = 2]
08/27/11 01:17:28.328862 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:114, WI: 172, PF = 58, RM = 192, Step = 2]
08/27/11 01:17:28.334808 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:116, WI: 172, PF = 56, RM = 194, Step = 2]
08/27/11 01:17:28.340771 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:118, WI: 172, PF = 54, RM = 196, Step = 2]
08/27/11 01:17:28.346726 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:120, WI: 172, PF = 52, RM = 198, Step = 2]
08/27/11 01:17:28.352800 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:122, WI: 172, PF = 50, RM = 200, Step = 2]
08/27/11 01:17:28.359570 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:124, WI: 173, PF = 49, RM = 201, Step = 2]
08/27/11 01:17:28.366473 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:126, WI: 173, PF = 47, RM = 203, Step = 2]
08/27/11 01:17:28.375515 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:128, WI: 173, PF = 45, RM = 205, Step = 2]
08/27/11 01:17:28.382036 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:130, WI: 173, PF = 43, RM = 207, Step = 2]
08/27/11 01:17:28.391283 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:132, WI: 173, PF = 41, RM = 209, Step = 2]
08/27/11 01:17:28.397201 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:134, WI: 173, PF = 39, RM = 211, Step = 2]
08/27/11 01:17:28.403187 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:136, WI: 173, PF = 37, RM = 213, Step = 2]
08/27/11 01:17:28.409203 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:138, WI: 173, PF = 35, RM = 215, Step = 2]
08/27/11 01:17:28.415373 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:140, WI: 174, PF = 34, RM = 216, Step = 2]
08/27/11 01:17:28.421907 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:142, WI: 174, PF = 32, RM = 218, Step = 2]
08/27/11 01:17:28.428912 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:144, WI: 174, PF = 30, RM = 220, Step = 2]
08/27/11 01:17:28.437841 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:146, WI: 174, PF = 28, RM = 222, Step = 2]
08/27/11 01:17:28.444332 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:148, WI: 174, PF = 26, RM = 224, Step = 2]
08/27/11 01:17:28.450839 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:150, WI: 174, PF = 24, RM = 226, Step = 1]
08/27/11 01:17:28.460493 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:151, WI: 174, PF = 23, RM = 227, Step = 1]
08/27/11 01:17:28.466454 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:152, WI: 174, PF = 22, RM = 228, Step = 1]
08/27/11 01:17:28.472685 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:153, WI: 175, PF = 22, RM = 228, Step = 1]
08/27/11 01:17:28.479121 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:154, WI: 175, PF = 21, RM = 229, Step = 1]
08/27/11 01:17:28.486129 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:155, WI: 175, PF = 20, RM = 230, Step = 1]
08/27/11 01:17:28.497897 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:156, WI: 175, PF = 19, RM = 231, Step = 1]
08/27/11 01:17:28.504944 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:157, WI: 175, PF = 18, RM = 232, Step = 1]
08/27/11 01:17:28.510899 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:158, WI: 175, PF = 17, RM = 233, Step = 1]
08/27/11 01:17:28.516825 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:159, WI: 175, PF = 16, RM = 234, Step = 1]
08/27/11 01:17:28.522814 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:160, WI: 175, PF = 15, RM = 235, Step = 1]
08/27/11 01:17:28.528888 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:161, WI: 176, PF = 15, RM = 235, Step = 1]
08/27/11 01:17:28.534824 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:162, WI: 176, PF = 14, RM = 236, Step = 1]
08/27/11 01:17:28.540770 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:163, WI: 176, PF = 13, RM = 237, Step = 1]
08/27/11 01:17:28.546187 zma_m5[-1].DB3-zm_monitor.cpp/2704 [Checking active zone All]
08/27/11 01:17:28.546565 zma_m5[-1].DB4-zm_zone.cpp/150 [Checking alarms for zone 5/All in lines 0 -> 479]
08/27/11 01:17:28.548445 zma_m5[-1].INF-zm_monitor.cpp/1326 [Monitor-5: 051 - Gone into prealarm state]
08/27/11 01:17:28.559045 zma_m5[-1].DB4-zm_monitor.cpp/1055 [RI:164, WI: 176, PF = 12, RM = 238, Step = 1]
08/27/11 01:17:28.566458 zma_m5[-1].DB3-zm_monitor.cpp/2704 [Checking active zone All]
08/27/11 01:17:28.566792 zma_m5[-1].DB4-zm_zone.cpp/150 [Checking alarms for zone 5/All in lines 0 -> 479]
08/27/11 01:17:28.568707 zma_m5[-1].INF-zm_monitor.cpp/1295 [Monitor-5: 052 - Gone into alarm state]
08/27/11 01:17:28.637096 zma_m5[-1].INF-zm_monitor.cpp/1308 [Monitor-5: 052 - Opening new event 179, alarm start]
08/27/11 01:17:28.637203 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 1]
08/27/11 01:17:28.660650 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 2]
08/27/11 01:17:28.686982 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 3]
08/27/11 01:17:28.706126 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 4]
08/27/11 01:17:28.728620 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 5]
08/27/11 01:17:28.745403 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 6]
08/27/11 01:17:28.768425 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 7]
08/27/11 01:17:28.789847 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 8]
08/27/11 01:17:28.808684 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 9]
08/27/11 01:17:28.825817 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 10]
08/27/11 01:17:28.846567 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 11]
08/27/11 01:17:28.864939 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 12]
08/27/11 01:17:28.881686 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 13]
08/27/11 01:17:28.899168 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 14]
08/27/11 01:17:28.916783 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 15]
08/27/11 01:17:28.937954 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 16]
08/27/11 01:17:28.955859 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 17]
08/27/11 01:17:28.973199 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 18]
08/27/11 01:17:28.995061 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 19]
08/27/11 01:17:29.011824 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 20]
08/27/11 01:17:29.028727 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 21]
08/27/11 01:17:29.050666 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 22]
08/27/11 01:17:29.067964 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 23]
08/27/11 01:17:29.086015 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 24]
08/27/11 01:17:29.107293 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 25]
08/27/11 01:17:29.124084 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 26]
08/27/11 01:17:29.142435 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 27]
08/27/11 01:17:29.163385 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 28]
08/27/11 01:17:29.181429 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 29]
08/27/11 01:17:29.199201 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 30]
08/27/11 01:17:29.220737 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 31]
08/27/11 01:17:29.237548 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 32]
08/27/11 01:17:29.254258 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 33]
08/27/11 01:17:29.272441 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 34]
08/27/11 01:17:29.290970 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 35]
08/27/11 01:17:29.312053 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 36]
08/27/11 01:17:29.328873 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 37]
08/27/11 01:17:29.347899 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 38]
08/27/11 01:17:29.368353 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 39]
08/27/11 01:17:29.385098 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 40]
08/27/11 01:17:29.403948 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 41]
08/27/11 01:17:29.420752 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 42]
08/27/11 01:17:29.437539 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 43]
08/27/11 01:17:29.455717 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 44]
08/27/11 01:17:29.472469 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 45]
08/27/11 01:17:29.489206 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 46]
08/27/11 01:17:29.506921 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 47]
08/27/11 01:17:29.523725 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 48]
08/27/11 01:17:29.541838 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 49]
08/27/11 01:17:29.558603 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 50]
08/27/11 01:17:29.575363 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 51]
08/27/11 01:17:29.593786 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 52]
08/27/11 01:17:29.610557 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 53]
08/27/11 01:17:29.627263 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 54]
08/27/11 01:17:29.646206 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 55]
08/27/11 01:17:29.663646 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 56]
08/27/11 01:17:29.681663 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 57]
08/27/11 01:17:29.698799 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 58]
08/27/11 01:17:29.715540 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 59]
08/27/11 01:17:29.733459 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 60]
08/27/11 01:17:29.750248 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 61]
08/27/11 01:17:29.768139 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 62]
08/27/11 01:17:29.784991 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 63]
08/27/11 01:17:29.801820 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 64]
08/27/11 01:17:29.820015 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 65]
08/27/11 01:17:29.836779 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 66]
08/27/11 01:17:29.853563 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 67]
08/27/11 01:17:29.871464 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 68]
08/27/11 01:17:29.888192 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 69]
08/27/11 01:17:29.906545 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 70]
08/27/11 01:17:29.923304 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 71]
08/27/11 01:17:29.940055 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 72]
08/27/11 01:17:29.958049 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 73]
08/27/11 01:17:29.976249 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 74]
08/27/11 01:17:29.994790 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 75]
08/27/11 01:17:30.013038 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 76]
08/27/11 01:17:30.029935 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 77]
08/27/11 01:17:30.047927 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 78]
08/27/11 01:17:30.064716 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 79]
08/27/11 01:17:30.081496 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 80]
08/27/11 01:17:30.099662 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 81]
08/27/11 01:17:30.116433 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 82]
08/27/11 01:17:30.134445 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 83]
08/27/11 01:17:30.151413 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 84]
08/27/11 01:17:30.168177 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 85]
08/27/11 01:17:30.186171 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 86]
08/27/11 01:17:30.203096 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 87]
08/27/11 01:17:30.219845 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 88]
08/27/11 01:17:30.237739 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 89]
08/27/11 01:17:30.254567 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 90]
08/27/11 01:17:30.272831 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 91]
08/27/11 01:17:30.289651 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 92]
08/27/11 01:17:30.306496 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 93]
08/27/11 01:17:30.324471 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 94]
08/27/11 01:17:30.341239 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 95]
08/27/11 01:17:30.358297 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 96]
08/27/11 01:17:30.376139 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 97]
08/27/11 01:17:30.392946 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 98]
08/27/11 01:17:30.411005 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 99]
08/27/11 01:17:30.427760 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 100]
08/27/11 01:17:30.444625 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 101]
08/27/11 01:17:30.462757 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 102]
08/27/11 01:17:30.479530 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 103]
08/27/11 01:17:30.497717 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 104]
08/27/11 01:17:30.514860 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 105]
08/27/11 01:17:30.531630 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 106]
08/27/11 01:17:30.549680 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 107]
08/27/11 01:17:30.566559 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 108]
08/27/11 01:17:30.583305 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 109]
08/27/11 01:17:30.601224 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 110]
08/27/11 01:17:30.618069 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 111]
08/27/11 01:17:30.635977 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 112]
08/27/11 01:17:30.652800 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 113]
08/27/11 01:17:30.669707 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 114]
08/27/11 01:17:30.687918 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 115]
08/27/11 01:17:30.704742 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 116]
08/27/11 01:17:30.721459 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 117]
08/27/11 01:17:30.739517 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 118]
08/27/11 01:17:30.756291 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 119]
08/27/11 01:17:30.774203 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 120]
08/27/11 01:17:30.791077 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 121]
08/27/11 01:17:30.807836 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 122]
08/27/11 01:17:30.825760 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 123]
08/27/11 01:17:30.842696 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 124]
08/27/11 01:17:30.859807 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 125]
08/27/11 01:17:30.877482 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 126]
08/27/11 01:17:30.894441 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 127]
08/27/11 01:17:30.912524 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 128]
08/27/11 01:17:30.929230 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 129]
08/27/11 01:17:30.946176 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 130]
08/27/11 01:17:30.964188 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 131]
08/27/11 01:17:30.980961 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 132]
08/27/11 01:17:30.998840 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 133]
08/27/11 01:17:31.015761 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 134]
08/27/11 01:17:31.032511 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 135]
08/27/11 01:17:31.050800 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 136]
08/27/11 01:17:31.067589 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 137]
08/27/11 01:17:31.084390 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 138]
08/27/11 01:17:31.102221 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 139]
08/27/11 01:17:31.118965 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 140]
08/27/11 01:17:31.136469 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 141]
08/27/11 01:17:31.153344 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 142]
08/27/11 01:17:31.169734 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 143]
08/27/11 01:17:31.188147 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 144]
08/27/11 01:17:31.204799 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 145]
08/27/11 01:17:31.221572 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 146]
08/27/11 01:17:31.239306 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 147]
08/27/11 01:17:31.256199 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 148]
08/27/11 01:17:31.273791 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 149]
08/27/11 01:17:31.291012 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 150]
08/27/11 01:17:31.307519 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 151]
08/27/11 01:17:31.325435 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 152]
08/27/11 01:17:31.341876 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 153]
08/27/11 01:17:31.358808 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 154]
08/27/11 01:17:31.376637 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 155]
08/27/11 01:17:31.393410 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 156]
08/27/11 01:17:31.411357 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 157]
08/27/11 01:17:31.428253 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 158]
08/27/11 01:17:31.444672 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 159]
08/27/11 01:17:31.463000 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 160]
08/27/11 01:17:31.479580 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 161]
08/27/11 01:17:31.496456 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 162]
08/27/11 01:17:31.514115 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 163]
08/27/11 01:17:31.531021 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 164]
08/27/11 01:17:31.548596 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 165]
08/27/11 01:17:31.565310 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 166]
08/27/11 01:17:31.581749 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 167]
08/27/11 01:17:31.599766 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 168]
08/27/11 01:17:31.616182 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 169]
08/27/11 01:17:31.632983 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 170]
08/27/11 01:17:31.650720 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 171]
08/27/11 01:17:31.667513 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 172]
08/27/11 01:17:31.685191 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 173]
08/27/11 01:17:31.701992 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 174]
08/27/11 01:17:31.718343 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 175]
08/27/11 01:17:31.736417 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 176]
08/27/11 01:17:31.752872 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 177]
08/27/11 01:17:31.769673 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 178]
08/27/11 01:17:31.787408 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 179]
08/27/11 01:17:31.804208 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 180]
08/27/11 01:17:31.821828 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 181]
08/27/11 01:17:31.838776 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 182]
08/27/11 01:17:31.855177 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 183]
08/27/11 01:17:31.873119 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 184]
08/27/11 01:17:31.889631 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 185]
08/27/11 01:17:31.906455 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 186]
08/27/11 01:17:31.924142 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 187]
08/27/11 01:17:31.940950 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 188]
08/27/11 01:17:31.958676 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 189]
08/27/11 01:17:31.975441 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 190]
08/27/11 01:17:31.991874 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 191]
08/27/11 01:17:32.009915 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 192]
08/27/11 01:17:32.026334 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 193]
08/27/11 01:17:32.043320 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 194]
08/27/11 01:17:32.061005 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 195]
08/27/11 01:17:32.077802 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 196]
08/27/11 01:17:32.095627 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 197]
08/27/11 01:17:32.112506 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 198]
08/27/11 01:17:32.128891 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 199]
08/27/11 01:17:32.146727 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 200]
08/27/11 01:17:32.163351 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 201]
08/27/11 01:17:32.180416 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 202]
08/27/11 01:17:32.197938 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 203]
08/27/11 01:17:32.214716 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 204]
08/27/11 01:17:32.232440 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 205]
08/27/11 01:17:32.249201 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 206]
08/27/11 01:17:32.265607 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 207]
08/27/11 01:17:32.283927 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 208]
08/27/11 01:17:32.300349 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 209]
08/27/11 01:17:32.317261 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 210]
08/27/11 01:17:32.334872 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 211]
08/27/11 01:17:32.351705 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 212]
08/27/11 01:17:32.369427 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 213]
08/27/11 01:17:32.385963 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 214]
08/27/11 01:17:32.402333 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 215]
08/27/11 01:17:32.420012 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 216]
08/27/11 01:17:32.436535 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 217]
08/27/11 01:17:32.453029 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 218]
08/27/11 01:17:32.471107 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 219]
08/27/11 01:17:32.487612 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 220]
08/27/11 01:17:32.505217 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 221]
08/27/11 01:17:32.521625 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 222]
08/27/11 01:17:32.538143 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 223]
08/27/11 01:17:32.555903 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 224]
08/27/11 01:17:32.572310 zma_m5[-1].DB1-zm_event.cpp/487 [Writing pre-capture frame 225]
08/27/11 01:17:32.588784 zma_m5[-1].DB1-zm_event.cpp/497 [Adding 225 frames to DB]
08/27/11 01:17:32.589852 zma_m5[-1].ERR-zm_event.cpp/501 [Can't insert frames: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1]
sysctl.conf: (system has 6GB installed)
kernel.shmall = 1024000
kernel.shmmax = 4194304000
Maximum FPS: 18
Alert FPS: 22
Image Buffer Size: 250
Pre Event: 225
Post Event: 300
top:
top - 01:35:07 up 45 min,  1 user,  load average: 0.00, 0.07, 0.06
Tasks: 140 total,   3 running, 137 sleeping,   0 stopped,   0 zombie
Cpu(s): 27.6%us,  3.6%sy,  1.7%ni, 66.7%id,  0.0%wa,  0.0%hi,  0.4%si,  0.0%st
Mem:   6124996k total,  1690592k used,  4434404k free,   105232k buffers
Swap: 19598332k total,        0k used, 19598332k free,  1204848k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 4238 www-data  20   0  405m 226m 222m R   29  3.8   4:35.66 zma
 1604 www-data  20   0  273m  94m  90m S   25  1.6   9:12.67 zma
 1602 www-data  20   0  273m  94m  90m S   11  1.6   4:25.24 zmc
 1600 www-data  20   0  273m  94m  90m S   10  1.6   4:16.58 zma
 5942 munin     30  10  107m  12m 3136 R    9  0.2   0:00.28 munin-graph
 1606 www-data  20   0  221m  42m  38m S    7  0.7   2:57.11 zmc
 1598 www-data  20   0  273m  94m  90m S    6  1.6   2:27.47 zmc
 1680 www-data  20   0  412m 233m 229m S    6  3.9   2:07.17 zmc
   34 root      20   0     0    0    0 S    0  0.0   0:01.04 kblockd/3
 5589 user     20   0 19276 1400 1028 R    0  0.0   0:00.05 top
    1 root      20   0 23752 1884 1280 S    0  0.0   0:00.91 init
