Hi ,
i recently installed in a debian box a zoneminder, looks so nice..my question, if possible storage videos making with motion in a dir for access to user using samba? i see video can be generated from jpg captures, but i wanna do it automaticly , and send to a dir for access via network, possible?
thx !!!
Video Storage Possible?
Re: Video Storage Possible?
hello,
it's possible to share with samba the stockage dir of ZoneMinder (safe with read only)
But give us viewer access directly to zoneminder
- nightcrawler
yes it's posible.
take a look here:
it's from an other forumboard (homeseer), for home domotica software. 2 members here, ZEN en Pete made an 24H alarm script. that generates an video of all events in the last 24 hour. works well and you probably can alter it in an 1-hour or event trigger video script if you know some basic scripting.
copy&past from the homeseer board and code:
@*#() can't past the URL because i'm an user with less post...stupid rule...
take a look here:
# !/bin/bash
# Use this script for creating alarm video-files
# Modded by -Mike- aka Zap
# Enumerate existing ZoneMinder Monitors
cameraList=(`ls /var/cache/zoneminder/events/ | grep '[A-z]'`)
cameraNum=${#cameraList[@]}
eventsFolder=/var/cache/zoneminder/events/
echo Number of detected ZoneMinder Monitors: ${#cameraList[@]}
# Start working through all detected ZoneMinder Monitors
for (( i=0; i<${cameraNum}; i++ ));
do
echo Doing ZoneMinder Monitor: ${cameraList[$i]}
# Get a list of images for the last 24 hours from each of the detected ZoneMinder Monitors.
find $eventsFolder${cameraList[$i]} -follow -mtime -1 -name \*capture.jpg > /tmp/alarmvideos/${cameraList[$i]}.list
# Sort output file for a consistent movie
sort /tmp/alarmvideos/${cameraList[$i]}.list -o /tmp/alarmvideos/${cameraList[$i]}-sorted.list
# Encode each 24hr events into a movie
mencoder mf://@/tmp/alarmvideos/${cameraList[$i]}-sorted.list -mf w=640:h=480:fps=10:type=jpg -ovc lavc -lavcopts vcodec=mpeg4 -ofps 10 -oac copy -o /tmp/alarmvideos/${cameraList[$i]}-`date +%F`.avi
# Find avi's with actual events-move to new dir
cd /tmp/alarmvideos
find *.avi -size +5k -exec mv {} /tmp/zmvideos \;
# Cleanup
rm -rf /tmp/alarmvideos/*.list
rm -rf /tmp/alarmvideos/*.avi
done
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
thx a lot for the reply, now i try to analyze the script you give, btw, possible send me via private message the link of the board, where the script was posted? thx!!
i discovered this script, for generate the video made in url in section make in video format, to move to a dir , and works..
How to store all recordings as video files in a common folder
url wiki. mikeality. com / Zoneminder
My question is make run the script like in crontab , the script zmvideo.pl for auto detect events, and made the files...
greets
greets
Useful info. Thanks very much
