my distro is FC3
ZM ver is 1.20.1
I have an axis 206 network camera, everthing works fine. The camera support also resolution 640x480, but when I try to set this resolution to ZM camera's source tab it doesn't work. If I use 320x240 everthing is OK. Does ZM ver 1.20.1 support resolution 640x480?
When I enter in browser adress http://10.48.1.154/axis-cgi/jpg/image.c ... on=640x480 it shows me image captured to 640x480, so it seems to be OK but when I set this in ZM, it doesn't work....
this configuration works fine....
Remote Host name 10.48.1.154
Remote Host port 80
Remote Host path /axis-cgi/jpg/image.cgi?resolution=320x240
Remote Image Colours 24-bit
Capture width 320
Capture height 240
Orientation normal
this not....
Remote Host port 80
Remote Host path /axis-cgi/jpg/image.cgi?resolution=640x480
Capture width 640
Capture height 480
Orientation normal
