I have made a DVR system using a KDC-8800 clone (it has 8 bt878 chips and anoher bigger chip which I guess is a PCI-bridge) with some (cheap) CCTV cameras of different brands.
I originally set-up all the (PAL) cameras to capture at 720x576 pixels @ 10 fps, BGR24. However, it soon revealed a bad choice since I was getting highly interlaced pictures.
The strange fact was I was getting very "ghosty" artifacts: the resulting images seemed to be an interlace of distant frames in time, not consecutive ones, as I expected them to be. I tried to play with V4L_MULTI_BUFFER and CAPTURES_PER_FRAME options with no success. Even trying to rise or lower the capture frame rate did not bring to any success.
Anyway, I decided to switch (all the cameras) to 384x288 resolution (still to 10 fps) to get rid of interlacing.
But, surprisingly, I am still getting interlaced images (on all the cameras). Now the interlace seems more "sequential", but yes it is absolutely perceptible and annoying (see the attached image).
Any hints?
I attach you some details of my sw/hw configuration:
--- bttv-option ---
options i2c-algo-bit bit_test=1
options bttv gbuffers=32 card=77,77,77,77,77,77,77,77 tuner=-1,-1,-1,-1,-1,-1,-1,-1 radio=0 coring=1 full_luma_range=1 chroma_agc=1 pll=1 combfilter=1 autoload=0 triton1=0
(I have tried also with card=102.... with no success)
-- lspci ---
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
00:02.0 VGA compatible controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 01)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation 82801GB/GR/GH (ICH7 Family) SATA IDE Controller (rev 01)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
03:00.0 PCI bridge: Hint Corp HiNT HB4 PCI-PCI Bridge (PCI6150) (rev 04)
04:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
--- cat /proc/interrupts ---
CPU0 CPU1 CPU2 CPU3
0: 624998263 19015 18869 19004 IO-APIC-edge timer
1: 0 0 2 2 IO-APIC-edge i8042
3: 6566626 22095440 5300174 1107347 IO-APIC-edge serial
8: 1 1 0 1 IO-APIC-edge rtc
9: 0 0 0 0 IO-APIC-level acpi
50: 2846889 5973116 54555941 17397424 IO-APIC-level bttv0, bttv4
169: 19018 41474 78733775 20161040 IO-APIC-level uhci_hcd:usb5, HDA Intel, bttv3, bttv7
209: 176745 260550 77344457 22497212 IO-APIC-level uhci_hcd:usb4, bttv2, bttv6
217: 0 1 0 2 IO-APIC-level ehci_hcd:usb1, uhci_hcd:usb2
225: 10228 10167 70829516 23168986 IO-APIC-level uhci_hcd:usb3, ata_piix, bttv1, bttv5
233: 33 0 0 13979142 PCI-MSI eth0
NMI: 0 0 0 0
LOC: 625054912 625054913 625054891 625054910
ERR: 0
MIS: 0
Primiano
