I changed the Skin type to XML. After that, I could not log in anymore - got just errors. You can get yourself back to 'normal' by using this url:
http://<your-zm-ip>/index.php?skin=classic
Problems after changing the Skin?
Re: Problems after changing the Skin?
Clearing cookies also fixes this problem (I know, I made the same mistake
