Okay.. I've got OPT_EMAIL working... AWESOME! But your never quite finished with ZM.. there's always a "hmmm.. can I do this?.. or let me try that now?"... rolling around in my head..
So.. I've got both OPT_MESSAGE and OPT_EMAIL flagged. OPT_EMAIL works awesome! How 'bout OPT_MESSAGE??
I know I can receive sms messages at, "01234567@att.text.att.net" for example. I've tested it by sending an email via CLI. I've got OPT_MESSAGE checked of course.. I've flagged it and deflagged it and restarted in between to know effect. I'm watching maillog and seeing the OPT_EMAIL address going out... I checked zmfilter.pl and theres code in their relating to OPT_MESSAGE.
Anyone point me in the right direction? Is it an EITHER / OR option? Or, can I get both?
Thanks!
jbmia
[SOLVED] OPT_MESSAGE?
Re: OPT_MESSAGE?
Must be a typo but text to att = XXXXXXXXXX@txt.att.net and video = XXXXXXXXXX@mms.att.net, good luck (.jpg is supported @mms.att.net)
Re: OPT_MESSAGE?
I should add for Verizon: @vtext.com for text and @vzwpix.com for video (.jpg is supported)
Re: OPT_MESSAGE?
Sorry.. yeah.. that was a typo in the post only.. sorry to confuse things.. I have it correct in the OPT_MESSAGE field and have tested it via command line..
Any advice?
jbmia
Any advice?
jbmia
Re: OPT_MESSAGE?
Nevermind... I see the separate check box on for OPT_MESSAGE on the event filter window now... &*^^&%!!
jbmia
jbmia
Re: OPT_MESSAGE?
Were you able to send both email/text at the same time? to separate email/text addresses? My HDD-installed of ZMLArch 1.24.2 would only send BOTH email/text messages to the same EMAIL_ADDRESS (ignores the entry within MESSAGE_ADDRESS field) for some unknown reason. My event filters are working fine for email, text, and FTP. The problem is ZM doesn't use the MESSAGE_ADDRESS box at all!jbmia wrote:Nevermind... I see the separate check box on for OPT_MESSAGE on the event filter window now... &*^^&%!!
jbmia
Re: [SOLVED] OPT_MESSAGE?
Yes, I can send to separate email and messaging accounts...
Under options/email.. populate both addresses with different addresses.. for email I use and email address for message I use my at&t cell email address that routes it as a text message... Make sure opt_email and opt_message are flagged.
Then under filters check either box to test.
Once you get email to work, they both should work. Hope this helps..
good luck..
jbmia
good luck..
jbmia
Thanks for the reply. I did exactly as described yet when the opt_message box is populated with my Sprint's address, text doesn't get routed at all. If I were to populate both fields with their corresponding addresses, enable both email/txt options and filter them correctly, I'd get BOTH messages under the same Gmail account. I have to rely on filters within Gmail to re-direct/forward the shorter text message to the Sprint address in order to get both email/text as originally planned.jbmia wrote:Yes, I can send to separate email and messaging accounts...
good luck..
jbmia
