new install on Ubuntu 11.10 server...... no streaming
racelife
Post by racelife »
Just installed a 1.25 on a clean install of Ubuntu 11.10 server 64 as per the wiki for 11.04 every thing went well but I cant seem to get any images or streaming. I see these errors in the logs it appears to be php related but I'm not sure where to start or what it could be. I don't know much about php
2011-10-15 19:33:36.681810	web_php	2193	ERR	socket_sendto( /tmp/zm/zms-728576s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:33.655709	web_php	3444	ERR	socket_sendto( /tmp/zm/zms-984034s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:30.621594	web_php	2193	ERR	socket_sendto( /tmp/zm/zms-806621s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:27.596022	web_php	3444	ERR	socket_sendto( /tmp/zm/zms-728576s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:24.566524	web_php	2193	ERR	socket_sendto( /tmp/zm/zms-806621s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:21.542297	web_php	3444	ERR	socket_sendto( /tmp/zm/zms-670879s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:18.518364	web_php	2193	ERR	socket_sendto( /tmp/zm/zms-984034s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:15.502669	web_php	3444	ERR	socket_sendto( /tmp/zm/zms-728576s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:15.089949	zmc_dvideo3	4158	INF	Monitor-4: 7000 - Capturing at 29.41 fps	zm_monitor.cpp	2598
2011-10-15 19:33:15.013201	zmc_dvideo2	4156	INF	Monitor-3: 7000 - Capturing at 29.41 fps	zm_monitor.cpp	2598
2011-10-15 19:33:14.870174	zmc_dvideo1	4154	INF	Monitor-2: 7000 - Capturing at 30.30 fps	zm_monitor.cpp	2598
2011-10-15 19:33:12.478654	web_php	2193	ERR	socket_sendto( /tmp/zm/zms-806621s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:33:06.922619	zms	4797	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.922085	zms	4799	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.921241	zms	4800	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.918478	zms	4798	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.853064	zms	4796	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.851181	zms	4795	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.848406	zms	4793	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.842123	zms	4792	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.841557	zms	4794	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.841290	zms	4791	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.830376	zms	4789	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.829915	zms	4790	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.827484	zms	4788	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:06.825284	zms	4787	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:33:01.985610	zmdc	4130	WAR	Can't find process with command of 'zma -m 5'	zmdc.pl
2011-10-15 19:33:01.882810	zmdc	4130	INF	Command 'zmc -d /dev/video4' removed from pending list at 11/10/15 19:33:01	zmdc.pl
2011-10-15 19:32:54.826503	web_php	1811	ERR	socket_sendto( /tmp/zm/zms-376413s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:32:51.803635	web_php	3444	ERR	socket_sendto( /tmp/zm/zms-125837s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:32:48.778624	web_php	1811	ERR	socket_sendto( /tmp/zm/zms-773276s.sock ) failed: No such file or directory	includes/functions.php	2322
2011-10-15 19:32:43.396167	zms	4767	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.394755	zms	4764	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.394403	zms	4766	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.390639	zms	4768	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.390211	zms	4765	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.352111	zms	4763	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.321659	zms	4753	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.320403	zms	4755	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.320172	zms	4754	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.318953	zms	4751	ERR	Unable to authenticate user	zms.cpp	221
2011-10-15 19:32:43.310881	zms	4752	ERR	Unable to authenticate user	zms.cpp	221
Thanks,
Stephen
gjpc
Re: new install on Ubuntu 11.10 server...... no streaming
Post by gjpc »
if
mkdir /tmp/zm
chown www-data:www-data -R /tmp/zm
fixes your problem, I would put them in /etc/init.d/zm
dogmeat206
Post by dogmeat206 »
Can you tell me why it would need to be www-data? Wouldn't you want that directory the same as apache?
The streaming issue was fixed on our end by another admin here. He said it was something to do with a config file that apache hadn't linked correctly.
racelife
Post by racelife »
it says /tmp/zm already exists and I chown but it didn't help.
thanks for the suggestion though.
racelife
Post by racelife »
Dog, can you link to that thread?
dogmeat206
Its not a post, it was something a local admin in my office did. Between the two of us, we are working on this server. When I'm not in, hes doing it, visa versa.
I will ask him when I talk to him next to see if he can tell me specifically what it was.
