Logitech webcam won't show display
Hello.
sorry if this been posted before but im desperate!
i've installed zoneminder on ubuntu 11.04, fedora15 & centos5.6 successfully
and now im trying zoneminder virtual appliance.
im using Logitech Pro 4000
the Webcam is working FINE with Cheese and Camorama
added the camera in the "add new monitor" option and its always Black\Blank screen!
been googleing about it for DAYSSS but cant find any solution for this
thanks for ANY help
thanks for ANY help
Re: Logitech webcam won't show display
Might be of some help: http://www.zoneminder.com/forums/viewto ... 2500+089d+
thanks for your reply.
after following the instructions... still no success!
and now i cant load the zoneminder webpage at all !
ok just 1 mistake
after a reboot i can login to the zoneminder webpage again
but still after adding the camera its just Black\Blank screen!
Have a look to your logs (/var/log/syslog) and check if it complains about shared memory settings.
ok not really sure what im suppose to look inside the file
but i posted a screenshot of what look to me the most relevant lines!
is this the right part?
p.s
forgot to mention im running the machine inside VMware Workstation8
p.s
- zm.jpg (161.62 KiB) Viewed 7122 times
Create a file called checksharedmemory.sh with these lines and chmod +x:
Run the script and get the values, copy the values at the end of the file /etc/sysctl.conf, for instance:
kernel.shmall = 128350
kernel.shmmax = 473149440
Reload the values using sysctl -p , or reboot
Hope it helps,
PacoLM
#!/bin/sh
# Copyright (C) 2010 Chris "Pada" Kistner
# Modified by PacoLM to check only shared memory settings
# if you find errors, check that coreutils are installed, if not, run the command below
# apt-get -y install coreutils bc
echo "--- Checking memory setting..."
page_size=$(getconf PAGE_SIZE)
mem_bytes=$(awk '/MemTotal:/ { printf "%0.f",$2 * 1024}' /proc/meminfo)
mb=1048576
mem_bytes_mb=$(expr $mem_bytes / $mb)
shmmax=$(echo "$mem_bytes * 0.90" | bc | cut -f 1 -d '.')
shmmax_mb=$(expr $shmmax / $mb)
shmall=$(expr $mem_bytes / $page_size)
shmmax_cur=$(sysctl -n kernel.shmmax)
shmmax_cur_mb=$(expr $shmmax_cur / $mb)
shmall_cur=$(sysctl -n kernel.shmall)
echo "-- Total memory = $mem_bytes B = $mem_bytes_mb MB"
echo "-- Page size = $page_size B"
echo "-- Current kernel.shmmax = $shmmax_cur B = $shmmax_cur_mb MB"
echo "-- Current kernel.shmall = $shmall_cur pages"
if [ "$shmmax" -eq "$shmmax_cur" ] && [ "$shmall" -eq "$shmall_cur" ]; then
echo "-- Recommended shm values already set"
else
echo "-- Recommended: kernel.shmmax = $shmmax B = $shmmax_mb MB"
echo "-- Recommended: kernel.shmall = $shmall pages"
fi
# Done
echo "--- Done."
Hope it helps,
PacoLM
thanks
been following the instructions... but cannot run the script!
was trying also chmod u+x
please check my screenshot
- script.jpg (43.74 KiB) Viewed 7106 times
Here's attached, I think you removed the #.
- checksharedmemory.zip
- (818 Bytes) Downloaded 482 times
ok finally was able to run the script!
copied the values
(as you can see in the screenshot the sysctl.conf already had values so i added # to them)
anyway i tried adding the camera again with PAL\NTSC
and still Black screen
whats wrong with that ?
copied the values
- sysctl.jpg (33.82 KiB) Viewed 7096 times
I just got a Logitech Quickcam E 3500 going, albeit at a low resolution. I'd recommend starting with the lowest resolution. Once picture is working, then you can graduate to higher resolutions.
The pdf at this link came in handy: http://www.google.com/url?sa=t&rct=j&q= ... NQ&cad=rja
I opened terminal and ran "lsusb". The last four digits of my ID corresponded with some of the info in the pdf.
