I know some people have contributed this type of system, however I haven't had an automatic process work, I just wite a script to delete event files X days older than today and them do a ZMaudit manually. Is there anything in the works to have ZM take care of cleanup internally?
-Scott
Autoclean via Date/time or low disk space....
The built in script works. It's a little picky about how you set it up though. The "PurgeWhenFull" filter needs to be resaved and you will get a window with actions and need to check the delete checkbox. You might also want to change the disk percent to 95 or a little less. to set the filter to delete after a month set up like so
Use 2 filter expressions
Archive Status is equal to Unarchived Only
and Date/Time less than or equal to -1 month
Sort by Date/Time Assending limit to first 20 events
Click on save and give it a name and check the delete action and save.
Hope this helps,
Cordel
Hope this helps,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
- zoneminder
- Site Admin
- Contact:
Searching for PurgeWhenFull will find several references. This thread is one of the most recent and contains step by step instructions.
Phil
Phil
- zoneminder
- Site Admin
- Contact:
