I am using ZM 1.24.2 on a Turnkey LAMP (Ubuntu 10.04) box and trying unsuccessfully to configure it for a Launch LC-5201A3-SAR IP camera, which should stream RTSP at a resolution of 704 x 576, mjpeg or h.264 (tried both).
ZM works well otherwise with USB cameras.
i am using the following settings for the source:
Remote Protocol RTSP
Remote Method RTP/RTSP
Remote Host Name 192.168.0.19
Remote Host Port 554
Remote Host Path /0/1:1/sub
Remote Image Colours 24bit
Capture Width (pixels) 704
Capture Height (pixels) 576
which are taken from the camera's user manual that states:
When applying all settings the link colour in the console turns green with record enabled and after a time turns red. Of course ZM does not stream or record anything.The RTSP address is: rtsp:// 192.168.1.19:554/0/1:1/main, formed as below:
192.168.1.19: IP address of the IP device
554: RTSP listen port
0: Default port, cannot be changed
1:1: Common User name & password,
Please refer to:1.3.3.1.3 User Management
main: Main streaming,
In summary, the RTSP streaming is for main streaming of the
rtsp: //192.168.1.19:554/0/1:1/main. If you want to view sub streaming or third
streaming RTSP, please follow the below format to visit.
Sub streaming: rtsp: //192.168.1.19:554/0/1:1/sub
The third streaming: rtsp: //192.168.1.19:554/0/1:1/2sub
the following can be found in zm_debug.log.*
09/20/11 11:44:34.308983 zmc_m6[2139].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.02139]
09/20/11 11:44:34.311785 zmc_m6[2139].DB1-zm_monitor.cpp/2262 [Got 1 monitors]
09/20/11 11:44:34.329139 zmc_m6[2139].DB1-zm_thread.cpp/241 [Creating thread]
09/20/11 11:44:34.329272 zmc_m6[2139].DB2-zm_rtsp.cpp/187 [RTSP Local SSRC is 317b672b]
09/20/11 11:44:34.329302 zmc_m6[2139].DB1-zm_thread.cpp/280 [Starting thread]
09/20/11 11:44:34.335443 zmc_m6[2140].DB2-zm_thread.cpp/253 [Invoking thread]
09/20/11 11:44:34.335578 zmc_m6[2139].DB1-zm_thread.cpp/301 [Started thread 2140]
09/20/11 11:44:34.344159 zmc_m6[2140].DB2-zm_rtsp.cpp/46 [Sending RTSP message: DESCRIBE rtsp://192.168.0.19:554/0/1:1/sub RTSP/1.0
User-Agent: ZoneMinder/1.24.2
CSeq: 1
09/20/11 11:44:34.358836 zmc_m6[2139].DB1-zm_monitor.cpp/338 [monitor purpose=1]
09/20/11 11:44:34.358928 zmc_m6[2139].DB1-zm_monitor.cpp/345 [mem.size=12166072]
09/20/11 11:44:34.465529 zmc_m6[2139].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 704x576 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
09/20/11 11:44:34.613426 zmc_m6[2139].DB1-zm_monitor.cpp/458 [Monitor cam_3_launch has function 4]
09/20/11 11:44:34.613503 zmc_m6[2139].DB1-zm_monitor.cpp/459 [Monitor cam_3_launch LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
09/20/11 11:44:34.613540 zmc_m6[2139].DB1-zm_monitor.cpp/460 [Monitor cam_3_launch IBC = 10, WUC = 5, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 5, FM = 0]
09/20/11 11:44:34.615603 zmc_m6[2139].DB1-zm_zone.cpp/889 [Got 1 zones for monitor cam_3_launch]
09/20/11 11:44:34.615681 zmc_m6[2139].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 703,0 703,575 0,575]
09/20/11 11:44:34.615706 zmc_m6[2139].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 703,0 703,575 0,575']
09/20/11 11:44:34.615732 zmc_m6[2139].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
09/20/11 11:44:34.615756 zmc_m6[2139].DB3-zm_zone.cpp/796 [Got coordinate 703,0 from polygon string]
09/20/11 11:44:34.615778 zmc_m6[2139].DB3-zm_zone.cpp/796 [Got coordinate 703,575 from polygon string]
09/20/11 11:44:34.615801 zmc_m6[2139].DB3-zm_zone.cpp/796 [Got coordinate 0,575 from polygon string]
09/20/11 11:44:34.615833 zmc_m6[2139].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
09/20/11 11:44:34.615862 zmc_m6[2139].DB1-zm_zone.cpp/50 [Initialised zone 6/All - 1 - 704x576 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:12165, MxAP:304128, FB:3x3, MnFP:12165, MxFP:304128, MnBS:8110, MxBS:0, MnB:1, MxB:0, OF: 0]
09/20/11 11:44:34.759357 zmc_m6[2139].DB1-zm_monitor.cpp/2459 [Loaded monitor 6(cam_3_launch), 1 zones]
09/20/11 11:44:34.759459 zmc_m6[2139].INF-zmc.cpp/188 [Starting Capture]
09/20/11 11:44:34.763391 zmc_m6[2139].DB2-zm_remote_camera_rtsp.cpp/112 [Waiting for sources]
09/20/11 11:44:35.344491 zmc_m6[2140].DB2-zm_rtsp.cpp/72 [Received RTSP response: RTSP/1.0 200 OK
CSeq: 1
Server: rtsp server
Content-type: application/sdp
Content-base: rtsp://192.168.0.19:554/0/1:1/sub/
Content-length: 315
v=0
o=rtsp 1254922595 2237829591 IN IP4 0.0.0.0
s=RTSP Session
i=rtsp server
c=IN IP4 192.168.0.19
t=0 0
a=control:*
m=audio 0 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=range:npt=now-
a=control:trackID=0
m=video 0 RTP/AVP 26
a=rtpmap:26 JPEG/90000
a=range:npt=now-
a=framesize:26 704-576
a=control:trackID=1
(466 bytes)]
09/20/11 11:44:35.344752 zmc_m6[2140].DB1-zm_rtsp.cpp/304 [Processing SDP 'v=0
s=RTSP Session
i=rtsp server
t=0 0
a=control:*
m=audio 0 RTP/AVP 0
a=range:npt=now-
a=control:trackID=0
a=range:npt=now-
a=control:trackID=1
09/20/11 11:44:35.344848 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'v=0']
09/20/11 11:44:35.344882 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'o=rtsp 1254922595 2237829591 IN IP4 0.0.0.0']
09/20/11 11:44:35.344914 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 's=RTSP Session']
09/20/11 11:44:35.345120 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'i=rtsp server']
09/20/11 11:44:35.345148 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'c=IN IP4 192.168.0.19']
09/20/11 11:44:35.345197 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 't=0 0']
09/20/11 11:44:35.345222 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=control:*']
09/20/11 11:44:35.345257 zmc_m6[2140].DB3-zm_sdp.cpp/259 [Ignoring general SDP attribute 'control:*']
09/20/11 11:44:35.345282 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'm=audio 0 RTP/AVP 0']
09/20/11 11:44:35.345323 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=rtpmap:0 PCMU/8000']
09/20/11 11:44:35.345364 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=range:npt=now-']
09/20/11 11:44:35.345395 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=control:trackID=0']
09/20/11 11:44:35.345424 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'm=video 0 RTP/AVP 26']
09/20/11 11:44:35.345461 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=rtpmap:26 JPEG/90000']
09/20/11 11:44:35.345590 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=range:npt=now-']
09/20/11 11:44:35.345620 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=framesize:26 704-576']
09/20/11 11:44:35.345657 zmc_m6[2140].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=control:trackID=1']
09/20/11 11:44:35.346360 zmc_m6[2140].DB1-zm_sdp.cpp/305 [Looking for codec for audio payload type 0 / PCMU]
09/20/11 11:44:35.346582 zmc_m6[2140].DB1-zm_sdp.cpp/318 [Got static payload type 0, PCMU]
09/20/11 11:44:35.347195 zmc_m6[2140].DB1-zm_sdp.cpp/305 [Looking for codec for video payload type 26 / JPEG]
09/20/11 11:44:35.347220 zmc_m6[2140].DB1-zm_sdp.cpp/318 [Got static payload type 26, JPEG]
09/20/11 11:44:35.347263 zmc_m6[2140].DB2-zm_rtsp.cpp/46 [Sending RTSP message: SETUP rtsp://192.168.0.19:554/0/1:1/sub/trackID=1 RTSP/1.0
Transport: RTP/AVP/TCP;unicast
CSeq: 2
09/20/11 11:44:44.773667 zmc_m6[2139].FAT-zm_remote_camera_rtsp.cpp/118 [No RTSP sources]
09/20/11 11:44:44.774005 zmc_m6[2139].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
of course, camera streams great to VLC or Totem.
happy to help with more info.
thanks,
Dan
