Problem with installation - archlinux
TheTester
Post by TheTester »
Hello
I need some help with installing zoneminder on archlinux. There is package in AUR but at the end of install process I got this:
==> You must edit /etc/httpd/conf/httpd.conf and uncomment/add the line
==> LoadModule php5_module modules/libphp5.so
==> You must also add these lines:
==> Include conf/extra/php5_module.conf
==> Include /etc/httpd/conf/extra/httpd-zm.conf
touch: cannot touch `/var/lib/zm/zm_backup.sql': No such file or directory
error: command failed to execute correctly
When I try to execute installation again script finds previous installation and try to upgrade but without success:
Proceed with installation? [Y/n]
(1/1) checking package integrity                   [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
(1/1) upgrading zoneminder                         [######################] 100%
/tmp/alpm_bhwugV/.INSTALL: line 53: /usr/lib/zm/bin/zmupdate.pl: No such file or directory
Could you tell me what should I do to find what is causing those problems?
I've also noticed this at begging of installation:
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
pwd: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
chdir: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
TheTester
Re: Problem with installation - archlinux
Post by TheTester »
It's seems that there was problem with /var/lib/zm beacuse this dir wasn't present at the time of installation and touch can't create dirs.
Installation was successful...now I had to check if it works...
TheTester
Post by TheTester »
Now, whenever I try to execute /etc/rc.d/zm start, I get this:
Upgrade %s database:  ZoneMinder
DBD::mysql::st execute failed: Table 'zoneminder.Logs' doesn't exist at /usr/share/perl5/site_perl/ZoneMinder/Logger.pm line 609.
I have DB installed and I changed zm.conf so I have no idea what's going on. :(
TheTester
Post by TheTester »
Blah...my fault. I had DB installed from previous attempts and it didn't contained all tables.
But right now I get:
:: Starting ZoneMinder                                              [BUSY]
/etc/rc.d/zm: line 111: /usr/lib/zm/bin/zmpkg.pl: No such file or directory        [FAIL]
Which is correct in a way that this..hm...file really doesn't exist. Why? Shouldn't it be there after installation? Can I copy it from src?
PacoLM
Post by PacoLM »
Find where do you have zmpkg.pl, then modify your zm startup script for the path where the zm python scripts are.
Hope it helps,
PacoLM
TheTester
Post by TheTester »
The funny thing is...I can't find it anywhere...So what should I do? There is no zmpkg.pl in src either but it probably correct as it's not compiled. Any suggestions?
PacoLM
Post by PacoLM »
If these scripts are not anywhere, I believe the installation has not been made properly, or you are searching the file from another user, not root.
