error while trying to login as admin An error has occurred
juricac
Post by juricac »
hi guys! everything worked perfectly well and today after trying to login i get msg:
An error has occurred and this operation cannot continue.
For full details check your web logs for the code '1715B1'
im wondering where can i search for logs, and wondering what the problem might be?. never expirienced such error.
thanks alot!
TucsonDirect
Re: error while trying to login as admin An error has occurr
Post by TucsonDirect »
Go to phpMyAdmin and Repair all of your tables for zoneminder, this problem will then go away,
You must have shut the system down improperly or list power witch corrupted the database.... If it still wont let you login you will have to go to the users table and (re)create a password for said user account...
