Hello masterknife! this did the trick! I'm was used the default values from zoneminder...allangood wrote:Ok masterknife,
I will try these change and update the result here.
BTW, did you tried modetecion with your USB MJPEG camera? Works fine for you?
Thank you for your help.
Many, many thanks for your amazing patch and for your help!
You are my hero again! hahaha...
Regards.
