use zm as network camera. ???
fernando
Post by fernando »
has was discuss on version 1.19.xx
i have tried with 1.20 with no luck the use of a zm has a network camera.
the idea is simple. have a zm master machine that control some small machine using the video source.
like /cgi-bin/zms?mode=jpeg&monitor=1&scale=100&maxfps=15&auth=efc03c32ae3b32d1453672c5e9eea35e"
i dont know why this dont work since is mjpeg like many network cameras out there.
any idea. ?
Fernando
zoneminder
Site Admin
Post by zoneminder »
You have to be a little careful as the 'auth' string is time sensitive and so will expire. You would need to use username and password really, certainly for testing, to ensure that the stream gets replayed.
I can get one monitor to 'mirror' another here by using the zms stream of one monitor as the input for another so there shouldn't be any problems.
Phil
fernando
Post by fernando »
i got it..
now you can get jpg source using zms. so the feature is easy to use.
Fernando
ma77hias
What setting s do you use
Post by ma77hias »
This approach really interests me.
Can you please post the details of the settings you used ?
somepdguy
How did you do it?
Post by somepdguy »
How did you both end up doing this ?
Phil - you say you have got this working at home as a demo - what settings are you using, I have been banging my head against this since version 1.19.4 ?!?!
Help _please_!
Pete
zoneminder
Site Admin
I just used opened up a jpeg stream and copied the image source path (do a 'view source' to find it) as the path of the new monitor. As I said above I think you'll probably have to use the username and password rather than auth string unfortunately if you are using authentication.
The string I used that worked was,
/cgi-bin/zms?mode=jpeg&monitor=1&scale=100&maxfps=15&user=<user>&pass=<pass>
Phil
somepdguy
Same as before
Post by somepdguy »
Hi Phillip,
Thanks for that but I am back as was.
I can see the stream if I go directly to
http://myhost.com/cgi-bin/zms?mode=jpeg ... s=password
But when I put
myhost.com
80
/cgi-bin/zms?mode=jpeg&monitor=3&scale=100&maxfps=10&user=admin&pass=password in as the config, the monitor name and myhost.com goes orange in the list of monitors and I can't see the stream when I open it up.
/tmp/zm* doesn't show anything abnormal
All help appriciated.
Pete
zoneminder
Site Admin
How about /var/log/messages? Anything in there?
Failing that you might need to increase the debug level on the capture daemon. Which version do you have?
Phil
cordel
Post by cordel »
Might want to try setting that monitor to color even if the other camera is B/W. ZM can colorize the images per a config setting on the remote so would need to be set to color for the new machine.
also if you are using any of the RPM the location for zms is /cgi-bin/zm/zms
Cheers,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
