U Server 11.10 64bit, ZM 1.25 source, libjpeg-turbo, Cambozo
letsharehowto
Post by letsharehowto »
This is not mine. I use this: http://www.zoneminder.com/wiki/index.ph ... _Cambozola and this: http://www.zoneminder.com/wiki/index.ph ... t)_Desktop then I cut and paste. Because I cut and paste, some packets, ZM don't need it.
My dvr card like this: http://www.zoneminder.com/wiki/index.php/Kodicom_8800
Install new box with Ubuntu server 11.10 64bit. At software selection, select OpenSSH.
Create root account:
sudo passwd root
And later do everything with root too.
Set static IP:
nano /etc/network/interfaces
Cut and paste this quote into file:
# The primary network interface
auto eth0
iface eth0 inet static
address 192.168.1.10
netmask 255.255.255.0
gateway 192.168.1.1
ctrl-o to save ctrl-x to exit nano
Restart NIC:
sudo ifdown -a
sudo ifup -a
Update system software:
sudo apt-get update
sudo apt-get upgrade
Install bttv driver:
nano /etc/modprobe.d/bttv.conf
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
Reboot box:
reboot
Do something for Zoneminder:
export CFLAGS="-march=native -O2 -pipe" && export CXXFLAGS="${CFLAGS}" && export CPPFLAGS="${CFLAGS}"
aptitude install acpid build-essential linux-headers-`uname -r` automake perl libauthen-pam-perl apache2 libpam-runtime libio-pty-perl libmysqlclient-dev php5 php5-cli libapache2-mod-php5 php5-mysql libarchive-zip-perl libdate-manip-perl libdevice-serialport-perl libjpeg62 libmime-perl libstdc++6 libwww-perl zlib1g zip unzip patch ntp openssl libpcre3-dev libssl-dev libjpeg-progs libcurl4-gnutls-dev munin munin-node libmime-lite-perl netpbm libbz2-dev subversion yasm libnet-ssleay-perl libauthen-pam-perl libio-pty-perl apt-show-versions git-core mysql-server mysql-client mc htop -y
apt-get install libmysqlclient-dev libjpeg-dev libpcre3-dev build-essential -y
Install Webmin:
wget http://downloads.sourceforge.net/project/webadmin/webmin/1.570/webmin_1.570_all.deb?use_mirror=voxel
mv webmin_1.570_all.deb\?use_mirror=voxel webmin_1.570_all.deb && dpkg -i webmin_1.570_all.deb
Install libjpeg-turbo (AMD64):
wget http://downloads.sourceforge.net/project/libjpeg-turbo/1.1.1/libjpeg-turbo_1.1.1_amd64.deb?use_mirror=voxel
mv libjpeg-turbo_1.1.1_amd64.deb?use_mirror=voxel libjpeg-turbo_1.1.1_amd64.deb && dpkg -i libjpeg-turbo_1.1.1_amd64.deb
ln -s /opt/libjpeg-turbo/lib/libjpeg.a /usr/lib/libjpeg.a && ln -s /opt/libjpeg-turbo/include/jconfig.h /usr/include/jconfig.h && ln -s /opt/libjpeg-turbo/include/jerror.h /usr/include/jerror.h && ln -s /opt/libjpeg-turbo/include/jmorecfg.h /usr/include/jmorecfg.h && ln -s /opt/libjpeg-turbo/include/jpeglib.h /usr/include/jpeglib.h
Configure Lib Paths:
echo "/opt/libjpeg-turbo/lib" > /etc/ld.so.conf.d/libjpeg-turbo.conf && echo "/usr/local/lib" > /etc/ld.so.conf.d/ffmpeg.conf && echo "LD_LIBRARY_PATH=/usr/local/lib:/opt/libjpeg-turbo/lib:$LD_LIBRARY_PATH" >> /etc/bash.bashrc && echo "export LD_LIBRARY_PATH" >> /etc/bash.bashrc
ldconfig
Install Perl Modules:
perl -MCPAN -e shell
install CPAN
exit
install YAML PHP::Serialization Module::Load X10::ActiveHome
exit
install Sys::Mmap
install DBI
install DBD::mysql
install Date::Manip
install PHP::Serialization
exit
Install FFmpeg:
apt-get install ffmpeg -y
Install Zoneminder:
cd /usr/src && svn co http://svn.zoneminder.com/svn/zm/trunk zm
cd /usr/src/zm && ./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass ZM_SSL_LIB=openssl --enable-debug=no --with-webgroup=www-data --with-webuser=www-data --enable-mmap=yes CPPFLAGS="-D__STDC_CONSTANT_MACROS ${CPPFLAGS}"
autoconf
aclocal
automake
make
mysql -u root -p < db/zm_create.sql
Password that is requested is Mysql root password that was entered during install, not your ubuntu password.
mysql -u root -p
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
quit
mysqladmin -p reload
make install
Install Cambozola:
cd /usr/src && wget http://www.charliemouse.com:8080/code/cambozola/cambozola-latest.tar.gz
tar -xzvf cambozola-latest.tar.gz
cp cambozola-0.92/dist/cambozola.jar /var/www/zm
Create Zoneminder startup script:
nano -w /etc/init.d/zm
Paste everything BETWEEN the lines below.
#!/bin/sh
# description: Control ZoneMinder as a Service
# chkconfig: 2345 99 99
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/local/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
return $RETVAL
stop() {
echo -n "Stopping $prog: "
$command stop
RETVAL=$?
status() {
result=`$command status`
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
ctrl-o to save, ctrl-x to exit nano
chmod 755 /etc/init.d/zm
Zoneminder Startup:
In firefox, go to https://YOUR_ZoneMinder.IP.ADDRESS.HERE:10000 to reach the Webmin interface.(Login with Ubuntu username and password)
In left menu, select System>Bootup and Shutdown. Tick the box next to zm and click StartNow and On Boot.
In left menu, select Servers>Apache Webserver. Click virtual server under Existing virtual hosts tab. Under Virtual Server Details, change Document Root to /var/www/zm and then save.
Click apply changes at top left of page.
Go to http://YOUR_ZoneMinder.IP.ADDRESS.HERE to reach the Zoneminder interface.
If you want better quality video, cut -r 25 in Option->Images->FFMPEG_OUTPUT_OPTIONS ad replace with:
-f mp4 -r 25 -b 2048k -vcodec mpeg4
Note: If you add New Monitor by hand, when you restart box, only Monitor 1 be green, monitor 2,3,4,5,6,7,8 still red. If you add New Monitor by Presets->BTTV Video (V4L2), PAL, 320x240->Save, everything works OK.
mastertheknife
Re: U Server 11.10 64bit, ZM 1.25 source, libjpeg-turbo, Cam
Post by mastertheknife »
Nice job!
However, this particular line is not needed anymore (starting with ZM 1.24.4 and newer):
mastertheknife
Kfir Itzhak.
LWFVoo
Post by LWFVoo »
I have a 32-Bit system. Will I be OK if I just change all of the 64s to 32s (Find & Replace)? :D
mmi
Post by mmi »
i follow your tutorial and i don't have this two options: can_stream, stream_method
is this ok?
mmi
Post by mmi »
LWFVoo wrote:I have a 32-Bit system. Will I be OK if I just change all of the 64s to 32s (Find & Replace)? :D
yes, for me works for 32 bit with necessary changes
letsharehowto
mmi wrote:i follow your tutorial and i don't have this two options: can_stream, stream_method
is this ok?
can_stream, stream_method in High B/W, Low B/W, Medium B/W, Phone B/W tab
mmi
Post by mmi »
can you tell me what is doing this:
"export CFLAGS="-march=native -O2 -pipe" && export CXXFLAGS="${CFLAGS}" && export CPPFLAGS="${CFLAGS}"
letsharehowto
mmi wrote:can you tell me what is doing this:
This is not mine. I use this: http://www.zoneminder.com/wiki/index.ph ... _Cambozola and this: http://www.zoneminder.com/wiki/index.ph ... ck_Meerkat)_Desktop then I cut and paste. Because I cut and paste, some packets, somethings , ZM don't need it.
LWFVoo
Post by LWFVoo »
letsharehowto wrote:Create root account:
sudo passwd root
After success, would it be wise to remove the root account for security reasons? If so, what's the command?
Thanks.
LWFVoo
Post by LWFVoo »
For any one wondering what the necessary changes are...
64-Bit
32-Bit
wget http://downloads.sourceforge.net/project/libjpeg-turbo/1.1.1/libjpeg-turbo_1.1.1_i386.deb?use_mirror=voxel
64-Bit
32-Bit
mv libjpeg-turbo_1.1.1_i386.deb?use_mirror=voxel libjpeg-turbo_1.1.1_i386.deb && dpkg -i libjpeg-turbo_1.1.1_i386.deb
LWFVoo
Post by LWFVoo »
To add a Monitor, select the pre-set BTTV Video (V4L2), PAL, 320x240 and set the drive path to...
/dev/video0
If your camera looks like a thermal imaging camera (completely messed up colours), try changing the Capture Palette from YUV422P to YUYV. It worked for me. :D
Jim March
Post by Jim March »
OK. I've run through all of this, but I can't get to the web interface.
I've tried going to the following links:
http://192.168.0.10:1000
https://192.168.0.10:1000
https://127.0.0.1:1000
http://127.0.0.1:1000
http://localhost:1000
https://localhost:1000
No joy on any of 'em. At:
http://192.168.0.10
...I get the standard Apache default startup text, so that part is working.
The command:
sudo zmpkg.pl start
...seems to work, but doesn't change anything. Can anybody tell me what's going on here?
Jim March
Post by Jim March »
Nevermind, this works:
http://localhost/zm/
Sigh
bb99
Post by bb99 »
Mostly getting back to basics always works!
LWFVoo
Post by LWFVoo »
I have two problems...
  • The card supports 25FPS on each channel. But I can't figure out a way to view a camera at 25FPS.
  • The card is PCI. My video card is also PCI. After going through this guide, my video card now seems to be disabled. My monitor (VDU) is switched on, but there's nothing on the screen. The monitor's constantly in sleep-mode as if there's no signal. Very weird. It's not much of a problem as I can still SSH.
