Saving video rather than images to network drive
adamjseed
Post by adamjseed »
Hello all,
Currently I have a few Foscam cameras running in zoneminder. I have a issue which im trying to solve:
Im trying to address the issue of clearing down old recordings to allow for new ones. I have tried using the filters but not quite worked it out yet. so im currently doing manually, deleting the events (via fast delete) then clearing the hardrive as the images never get purged.
so...
At present my disk is full of a massive amount of images and takes ages to delete. is there anyway I can get zoneminder to recored these in a video format?
TylerSchwend
Re: Saving video rather than images to network drive
Post by TylerSchwend »
Do you see a filter called "PurgeWhenFull?"
leeroybrown
Post by leeroybrown »
You can do an export to the format and dir of your choice, could take a while. Select view all then select them all and do an export, then delete ....
