Scehduling
hash4all
Scehduling
Post by hash4all »
Support:
Is it possible to do scheduling of the cam to capture the image/video for n numbers of hours?
For Ex i want to capture the images/video for 5 hours between 1am to 6am.
Please let us know how we can schedule it in Zone minder.
Hash
kirk
Re: Scehduling
Post by kirk »
I'm wondering the exact same thing.
Maybe it could be done with cron jobs to stop/start zoneminder? That's the only thing I can think of - might give it a try.
kirk
Re: Scehduling
Post by kirk »
Yes, just tested it and it works fine if you put it into a crontab for a user that can restart services (like root).
Here are two lines you can use:
# Stop zoneminder every day at 6am
0 6 * * * /etc/init.d/zoneminder stop
# Start zoneminder every day at 1am
0 1 * * * /etc/init.d/zoneminder start
If you're not familiar with cron syntax there are lots of resources out there. I can't link to one (board says I'm too new of a user) but search for "cron quick reference" and you'll find something.
Note though that this shuts zoneminder down completely. I believe the web frontend will still be accessible (so you can manually start it again if you want to) and I think you can browse/view events when zm is not running since that's all apache/mysql/php. Before relying on this I'd give it a bit of testing.
