2011-12-01 13:09:42.267420 zmcontrol 3056 INF Control server 1/AxisV2 starting at 11/12/01 13:09:42 zmcontrol.pl
2011-12-01 13:09:42.219420 zmcontrol 3052 INF Starting control server 1/AxisV2 zmcontrol.pl
2011-12-01 13:09:42.219420 zmfix 2713 ERR Can't stat axis-cgi/com/ptz.cgi: No such file or directory zmfix.cpp 86
Source:
HTTP
Simple
user:pass@ipaddr
port 80
host path: /axis-cgi/mjpg/video.cgi?resolution=640x480&req_fps=7
24bit / 640 / 480
Control Tab:
Controllable, Axis API v2
Control Device: axis-cgi/com/ptz.cgi
Control Address: ipaddr:80
0, uncheck, 0, none, 0
Side note, even though the controls are not working within the ZM, I can browse to the following address and actually move the camera...
http://ipaddr/axis-cgi/com/ptz.cgi?camera=1&move=left
So I know the camera is accepting remote PTZ controls. So I think it must be something on the server not sending the right string to the URL. I'm not sure what the "Can't stat axis-cgi/com/ptz.cgi: No such file or directory" error is meaning. Does it think that the cgi file is on the local server? I found a reference to installing a perl module called libmodule-load-perl on another writeup for Axis cameras, but I cannot find that module for CentOS. Not sure if that might be causing the problem.
Also, firewall and SELinux is disabled.
