Path for Chinese IP cameras?
algenon
Re: Path for Chinese IP cameras?
Post by algenon »
Flasheart wrote:Suggestions:
Use the ie ui to see if there's a snapshot or similar button to a static jpg.
View the source on the camera's http pages, something might be hidden in there.
Try some random paths in desperation.
I have been trying most of your suggestions on and off all weekend.
These are a number of calls to jpg images in the HTML code but they may all be calls to display the mouseover graphics.
I can send you the source HTML if you are of a mind to look at it. There is no great urgency but it would be nice to get it going.
I was tempted to purchase this Blue Iris software and see if it gave any clues as it seems to be able to use that camera.
http://www.ipcam-central.com/
I shall persevere however.
Thanks Flasheart .... Algenon
algenon
Post by algenon »
Hmm ... minor update.
I have the camera working but only at 320 x 240 res, which I think is the setting for mobile phones. It has a mobile phone view utility.
Would have been helpful if a manual had been provided. Who here is a HTML code guru 'cos I'm surely not?
Algenon
EDIT: The scource path is /tmpfs/auto.jpg
anton_pr
Post by anton_pr »
algenon wrote: The two camers are;
www_dealextr....
This has a VERY good image at 1280 x 720 pixels.
and
www_dealext....
This is about equal to an Axis 205.
There is writing the protocol of these cameras, but I also received - "HTTP/1.1 400 Bad Request"
H basic protocol.rar
H Series IP Camera basic communication protocol
(19.31 KiB) Downloaded 198 times
