Hi there,
i am having trouble while setting up my CCTV solution.
I have install Zoneminder on Ubuntu Desktop 11.10.
I can see the image when i open guvcview and xawtv.
But i cannot get the image to display on zoneminder, i have pointed it to /dev/video0 but seems to be only one source and not all four.
Here is the result of: zmu -d /dev/video0 -q -v
Video Device: /dev/video0
General Capabilities
Driver: easycap
Card: EasyCAP DC60
Bus: usb-0000:00:1d.7-4
Version: 0.9.1
Type: 0x5020001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Has audio in and/or out
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
PAL_BGHIN
NTSC_N_443
PAL_Nc
NTSC_N
SECAM
NTSC_M
NTSC_M_JP
PAL_60
NTSC_443
PAL_M
PAL_BGHIN_SLOW
NTSC_N_443_SLOW
PAL_Nc_SLOW
NTSC_N_SLOW
SECAM_SLOW
NTSC_M_SLOW
NTSC_M_JP_SLOW
PAL_60_SLOW
NTSC_443_SLOW
PAL_M_SLOW
Formats:
uyvy (UYVY)
yuy2 (YUYV)
rgb24 (RGB3)
rgb32 (RGB4)
bgr24 (BGR3)
bgr32 (BGR4)
Crop Capabilities
Bounds: 360 x 288
Default: 360 x 288
Inputs: 6
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffb0ff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffb0ff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffb0ff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffb0ff
Power on (X)
Signal detected (X)
Input 4
Type: Camera
Audioset: 00000001
Standards: 0xffb0ff
Power on (X)
Signal detected (X)
Input 5
Type: Camera
Audioset: 00000001
Standards: 0xffb0ff
Power on (X)
Signal detected (X)
Can someone please help?
EasyCap STK1160 input problem!
Re: EasyCap STK1160 input problem!
Anyone?
I am pulling my hair out here.
Does anyone use the EasyCap to have four inputs?
