fc3 +x10 trigerring
alexl
fc3 +x10 trigerring
Post by alexl »
Hi, Cory,
can you please explain how to make x-10 trigerring
to work with your FC3 software?
Alex
cordel
Post by cordel »
Unfortunatly I do not have any X10 equipment and there fore have not had the oppertunity to play with that feature. Hopefully some one here on the forum can better advise you on how that feature works.
Cheers,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
alexl
x10
Post by alexl »
Cory,
is x10 support included in a FC3 I got?
Alex
zoneminder
Site Admin
Post by zoneminder »
You should be able to just set ZM_OPT_X10 in the options and then fill in the detail in the relevent options and monitor tabs (which are hidden if X10 is switched off). The README explains what all the setting mean.
Phil
alexl
x10
Post by alexl »
Can't find tab "triggers" anywhere, though I
made x10 active in options.
Alex
zoneminder
Site Admin
I don't think there is a Triggers tab, but there should be an X10 tab in the Monitors config dialog.
Phil
alexl
x10
Post by alexl »
Ok,
found X10 related dialog!
There are 3 lines:
x10 activation string
x10 input alarm string
x10 output alarm string
So, what do I put in there?
Or this is in a read me?
Best regards, Alex
zoneminder
Site Admin
Yes, it's explained in the README.
Phil
