Recent install via ubuntu
austeregrim
Post by austeregrim »
I've spent a few weeks setting this zoneminder install up, using ubuntu... etc.
We've let it run for a few days, and filled up the disk quickly. It's 100% full, and the sources were yellow.
I figured it needed a reboot, and now doesn't start mysql (i guess because it's 100% full)...
So I'm trying to figure out how to clean up the events so it's not full so it can run... then I need to find out why it didn't run the filters and delete events at 95%...
EDIT:
Okay, just testing this out... I deleted a 55mb log file (something zoneminder)
I was able to restart the mysql service.
Zoneminder is showing the login screen and I logged in.
I've started to run the filter, and manually deleting the events.
Now I need to know why it's not running the filter on it's own. lol
bb99
Re: Recent install via ubuntu
Post by bb99 »
Did you check the box labeled something similar to "run in the background" when you created the filter? Number one failure cause for what you're experiencing.
