Hi all,
I'm running ZM version 1.24.4 on Ubuntu 11.10. I recently had to reinstall my Linux box (previoulsy 11.04) and I had to re-configure Zoneminder from scratch. I was able to replicate most of the settings and the same network camera worked instantly but something is unfortunately not working properly. The camera "source" link (e.g. 192.168.1.254) stays in "orange" color instead of turning "green" when Zoneminder is started. And normally, when Zoneminder is stopped, the same source link turns "red", which is normal.
What does "orange" means? In my previous setup, this same "source" link was always "green" and everything worked like a charm, I had events logged, etc. Currently, I can see the video stream if I click on the camena "name" but I can't define zones and I don't see any events logged, etc. Instead of seeing a video feed, all I see is an "unknown image" icon (see attached pictures). Something is definitely wrong somewhere. Can it be related to ffmpeg? Or mySQL?
Under Options --> Images there was something different from my previous settings for OPT_FFMPEG. It was previously selected and now, by default, it is not? Should I enable this "optional" setting? If so, what should be entered in that box? /usr/bin/ffmpeg? The problem is that I don't have such a folder in my file system?! Where should ffmpeg be located? It looks like there is a folder in /usr/local/bin/ffmpeg though, is that the right one?
If it has nothing to do with "ffmpeg", can it be related to a mySQL problem? How can I troubleshoot that part?
Thank you all for your time, all the best for 2012 and regards,
highmighty
Source is "orange"?!
- Source stays "orange" ?!
- ZM.png (11.97 KiB) Viewed 4381 times
- Unknown image icon ?!
- Zones.png (6.99 KiB) Viewed 4381 times
- No events logged ?!
- Name.png (132.86 KiB) Viewed 4381 times
Re: Source is "orange"?!
Post the log (/var/log/syslog) after restart the application (service zoneminder restart). I bet it's the shared memory problem.
I just restarted ZM and here's the most recent part of the syslog file.
And if it's the "shared memory" problem, how can I fix this?
Also, I wanted to look at the mySQL server to see if I could find something relevant in there but I wasn't granted access
What are the default username/password for mySQL? Should I use ZM specific ones? In that case, what would it be? ZM_USER/ZM_PASS ?
Thanks again for your time,
highmighty
highmighty
Jan 19 13:01:04 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:01:05 lab-linux zmc_m1[21080]: INF [NSC15-WG: 165000 - Capturing at 12.82 fps]
Jan 19 13:01:14 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:02:23 zmwatch[21089]: last message repeated 13 times
Jan 19 13:02:23 lab-linux zmc_m1[21080]: INF [NSC15-WG: 166000 - Capturing at 12.99 fps]
Jan 19 13:02:24 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:03:03 zmwatch[21089]: last message repeated 7 times
Jan 19 13:03:03 lab-linux kernel: [53276.033988] usb 2-2.2: new low speed USB device number 7 using ohci_hcd
Jan 19 13:03:03 lab-linux mtp-probe: checking bus 2, device 7: "/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2"
Jan 19 13:03:03 lab-linux kernel: [53276.156699] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input8
Jan 19 13:03:03 lab-linux kernel: [53276.156870] generic-usb 0003:045E:0040.0006: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:03.0-2.2/input0
Jan 19 13:03:03 lab-linux mtp-probe: bus: 2, device: 7 was not an MTP device
Jan 19 13:03:04 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:03:40 zmwatch[21089]: last message repeated 7 times
Jan 19 13:03:40 lab-linux zmc_m1[21080]: INF [NSC15-WG: 167000 - Capturing at 12.99 fps]
Jan 19 13:03:42 lab-linux dbus[893]: [system] Activating service name='org.debian.apt' (using servicehelper)
Jan 19 13:03:43 lab-linux AptDaemon: INFO: Initializing daemon
Jan 19 13:03:43 lab-linux dbus[893]: [system] Successfully activated service 'org.debian.apt'
Jan 19 13:03:43 lab-linux AptDaemon: INFO: UpgradeSystem() was called with safe mode: 1
Jan 19 13:03:43 lab-linux AptDaemon.Trans: INFO: Simulate was called
Jan 19 13:03:43 lab-linux AptDaemon.Worker: INFO: Simulating trans: /org/debian/apt/transaction/cc7f3dd5e992485d8d71af462e77200e
Jan 19 13:03:44 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:03:49 lab-linux AptDaemon.Worker: INFO: Upgrade system with safe mode: 1
Jan 19 13:03:54 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:04:06 zmwatch[21089]: last message repeated 3 times
Jan 19 13:04:06 lab-linux zmdc[21057]: INF [Starting pending process, zma -m 1]
Jan 19 13:04:06 lab-linux zmdc[21057]: INF ['zma -m 1' starting at 12/01/19 13:04:06, pid = 26375]
Jan 19 13:04:06 lab-linux zmdc[26375]: INF ['zma -m 1' started at 12/01/19 13:04:06]
Jan 19 13:04:06 lab-linux zma_m1[26375]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:04:06 lab-linux zma_m1[26375]: ERR [Can't make events/1: Permission denied]
Jan 19 13:04:06 lab-linux zma_m1[26375]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 13:04:06 lab-linux zmdc[21057]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 13:04:14 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:04:37 zmwatch[21089]: last message repeated 5 times
Jan 19 13:04:37 lab-linux kernel: [53370.314858] usb 2-2.2: USB disconnect, device number 7
Jan 19 13:04:44 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:04:57 zmwatch[21089]: last message repeated 3 times
Jan 19 13:04:57 lab-linux zmc_m1[21080]: INF [NSC15-WG: 168000 - Capturing at 12.99 fps]
Jan 19 13:05:04 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:06:09 zmwatch[21089]: last message repeated 13 times
Jan 19 13:06:14 lab-linux zmc_m1[21080]: INF [NSC15-WG: 169000 - Capturing at 12.99 fps]
Jan 19 13:06:14 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:07:24 zmwatch[21089]: last message repeated 14 times
Jan 19 13:07:24 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:07:32 lab-linux zmc_m1[21080]: INF [NSC15-WG: 170000 - Capturing at 12.82 fps]
Jan 19 13:07:34 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:08:39 zmwatch[21089]: last message repeated 13 times
Jan 19 13:08:50 zmwatch[21089]: last message repeated 2 times
Jan 19 13:08:50 lab-linux zmc_m1[21080]: INF [NSC15-WG: 171000 - Capturing at 12.82 fps]
Jan 19 13:08:54 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:09:01 lab-linux CRON[26459]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Jan 19 13:09:04 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:09:43 zmwatch[21089]: last message repeated 7 times
Jan 19 13:09:43 lab-linux AptDaemon: INFO: Quitting due to inactivity
Jan 19 13:09:43 lab-linux AptDaemon: INFO: Quitting was requested
Jan 19 13:09:44 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:10:07 zmwatch[21089]: last message repeated 5 times
Jan 19 13:10:07 lab-linux zmc_m1[21080]: INF [NSC15-WG: 172000 - Capturing at 12.99 fps]
Jan 19 13:10:14 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:11:15 zmwatch[21089]: last message repeated 12 times
Jan 19 13:11:25 zmwatch[21089]: last message repeated 3 times
Jan 19 13:11:25 lab-linux zmc_m1[21080]: INF [NSC15-WG: 173000 - Capturing at 12.82 fps]
Jan 19 13:11:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:12:01 zmwatch[21089]: last message repeated 5 times
Jan 19 13:12:01 lab-linux kernel: [53814.057926] usb 2-2.2: new low speed USB device number 8 using ohci_hcd
Jan 19 13:12:01 lab-linux mtp-probe: checking bus 2, device 8: "/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2"
Jan 19 13:12:01 lab-linux kernel: [53814.180531] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input9
Jan 19 13:12:01 lab-linux kernel: [53814.180679] generic-usb 0003:045E:0040.0007: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:03.0-2.2/input0
Jan 19 13:12:01 lab-linux mtp-probe: bus: 2, device: 8 was not an MTP device
Jan 19 13:12:03 lab-linux kernel: [53816.379678] usb 2-2.2: USB disconnect, device number 8
Jan 19 13:12:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:12:42 zmwatch[21089]: last message repeated 7 times
Jan 19 13:12:42 lab-linux zmc_m1[21080]: INF [NSC15-WG: 174000 - Capturing at 12.99 fps]
Jan 19 13:12:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:13:55 zmwatch[21089]: last message repeated 14 times
Jan 19 13:13:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:14:00 lab-linux zmc_m1[21080]: INF [NSC15-WG: 175000 - Capturing at 12.82 fps]
Jan 19 13:14:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:14:06 lab-linux zmdc[21057]: INF [Starting pending process, zma -m 1]
Jan 19 13:14:06 lab-linux zmdc[21057]: INF ['zma -m 1' starting at 12/01/19 13:14:06, pid = 26506]
Jan 19 13:14:06 lab-linux zmdc[26506]: INF ['zma -m 1' started at 12/01/19 13:14:06]
Jan 19 13:14:06 lab-linux zma_m1[26506]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:14:06 lab-linux zma_m1[26506]: ERR [Can't make events/1: Permission denied]
Jan 19 13:14:06 lab-linux zma_m1[26506]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 13:14:06 lab-linux zmdc[21057]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 13:14:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:15:17 zmwatch[21089]: last message repeated 13 times
Jan 19 13:15:17 lab-linux zmc_m1[21080]: INF [NSC15-WG: 176000 - Capturing at 12.99 fps]
Jan 19 13:15:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:16:35 zmwatch[21089]: last message repeated 14 times
Jan 19 13:16:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:16:35 lab-linux zmc_m1[21080]: INF [NSC15-WG: 177000 - Capturing at 12.82 fps]
Jan 19 13:16:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:17:01 zmwatch[21089]: last message repeated 3 times
Jan 19 13:17:01 lab-linux CRON[26528]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 19 13:17:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:17:52 zmwatch[21089]: last message repeated 9 times
Jan 19 13:17:52 lab-linux zmc_m1[21080]: INF [NSC15-WG: 178000 - Capturing at 12.99 fps]
Jan 19 13:17:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:17:58 lab-linux zms[26554]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:17:58 lab-linux zms[26554]: INF [Authenticated user 'admin']
Jan 19 13:18:03 lab-linux zms[26564]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:18:03 lab-linux zms[26564]: INF [Authenticated user 'admin']
Jan 19 13:18:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:18:08 lab-linux zms[26571]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:18:08 lab-linux zms[26571]: INF [Authenticated user 'admin']
Jan 19 13:18:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:18:41 zmwatch[21089]: last message repeated 5 times
Jan 19 13:18:41 lab-linux zmu[26588]: ERR [Can't open Zones1.jpg: Permission denied]
Jan 19 13:18:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:18:54 lab-linux zmu[26590]: ERR [Can't open Zones1.jpg: Permission denied]
Jan 19 13:18:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:19:10 zmwatch[21089]: last message repeated 3 times
Jan 19 13:19:10 lab-linux zmc_m1[21080]: INF [NSC15-WG: 179000 - Capturing at 12.82 fps]
Jan 19 13:19:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:20:02 zmwatch[21089]: last message repeated 9 times
Jan 19 13:20:02 lab-linux zms[26603]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:02 lab-linux zms[26603]: INF [Authenticated user 'admin']
Jan 19 13:20:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:20:07 lab-linux zms[26613]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:07 lab-linux zms[26613]: INF [Authenticated user 'admin']
Jan 19 13:20:13 lab-linux zms[26618]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:13 lab-linux zms[26618]: INF [Authenticated user 'admin']
Jan 19 13:20:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:20:17 lab-linux zms[26627]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:17 lab-linux zms[26627]: INF [Authenticated user 'admin']
Jan 19 13:20:22 lab-linux zms[26636]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:22 lab-linux zms[26636]: INF [Authenticated user 'admin']
Jan 19 13:20:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:20:27 lab-linux zmc_m1[21080]: INF [NSC15-WG: 180000 - Capturing at 12.99 fps]
Jan 19 13:20:27 lab-linux zms[26641]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:27 lab-linux zms[26641]: INF [Authenticated user 'admin']
Jan 19 13:20:32 lab-linux zms[26657]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:32 lab-linux zms[26657]: INF [Authenticated user 'admin']
Jan 19 13:20:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:20:37 lab-linux zms[26662]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:38 lab-linux zms[26662]: INF [Authenticated user 'admin']
Jan 19 13:20:42 lab-linux zms[26671]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:42 lab-linux zms[26671]: INF [Authenticated user 'admin']
Jan 19 13:20:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:20:47 lab-linux zms[26680]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:20:47 lab-linux zms[26680]: INF [Authenticated user 'admin']
Jan 19 13:20:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:21:44 zmwatch[21089]: last message repeated 9 times
Jan 19 13:21:44 lab-linux zmc_m1[21080]: INF [NSC15-WG: 181000 - Capturing at 12.99 fps]
Jan 19 13:21:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:22:55 zmwatch[21089]: last message repeated 14 times
Jan 19 13:22:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:23:03 lab-linux zmc_m1[21080]: INF [NSC15-WG: 182000 - Capturing at 12.66 fps]
Jan 19 13:23:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:24:06 zmwatch[21089]: last message repeated 13 times
Jan 19 13:24:06 lab-linux zmdc[21057]: INF [Starting pending process, zma -m 1]
Jan 19 13:24:06 lab-linux zmdc[21057]: INF ['zma -m 1' starting at 12/01/19 13:24:06, pid = 26720]
Jan 19 13:24:06 lab-linux zmdc[26720]: INF ['zma -m 1' started at 12/01/19 13:24:06]
Jan 19 13:24:06 lab-linux zma_m1[26720]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:24:06 lab-linux zma_m1[26720]: ERR [Can't make events/1: Permission denied]
Jan 19 13:24:06 lab-linux zma_m1[26720]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 13:24:06 lab-linux zmdc[21057]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 13:24:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:24:20 lab-linux zmc_m1[21080]: INF [NSC15-WG: 183000 - Capturing at 12.99 fps]
Jan 19 13:24:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:25:35 zmwatch[21089]: last message repeated 14 times
Jan 19 13:25:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:25:36 lab-linux zmc_m1[21080]: INF [NSC15-WG: 184000 - Capturing at 13.16 fps]
Jan 19 13:25:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:26:53 zmwatch[21089]: last message repeated 13 times
Jan 19 13:26:53 lab-linux zmc_m1[21080]: INF [NSC15-WG: 185000 - Capturing at 12.99 fps]
Jan 19 13:26:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:28:05 zmwatch[21089]: last message repeated 14 times
Jan 19 13:28:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:28:09 lab-linux zmc_m1[21080]: INF [NSC15-WG: 186000 - Capturing at 13.16 fps]
Jan 19 13:28:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:29:25 zmwatch[21089]: last message repeated 14 times
Jan 19 13:29:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:29:26 lab-linux zmc_m1[21080]: INF [NSC15-WG: 187000 - Capturing at 12.99 fps]
Jan 19 13:29:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:30:40 zmwatch[21089]: last message repeated 13 times
Jan 19 13:30:41 lab-linux zmc_m1[21080]: INF [NSC15-WG: 188000 - Capturing at 13.33 fps]
Jan 19 13:30:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:31:55 zmwatch[21089]: last message repeated 14 times
Jan 19 13:31:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:31:57 lab-linux zmc_m1[21080]: INF [NSC15-WG: 189000 - Capturing at 13.16 fps]
Jan 19 13:32:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:32:15 zmwatch[21089]: last message repeated 3 times
Jan 19 13:32:15 lab-linux zms[26793]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:32:15 lab-linux zms[26793]: INF [Authenticated user 'admin']
Jan 19 13:32:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:33:14 zmwatch[21089]: last message repeated 9 times
Jan 19 13:33:14 lab-linux zmc_m1[21080]: INF [NSC15-WG: 190000 - Capturing at 12.99 fps]
Jan 19 13:33:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:34:06 zmwatch[21089]: last message repeated 11 times
Jan 19 13:34:06 lab-linux zmdc[21057]: INF [Starting pending process, zma -m 1]
Jan 19 13:34:06 lab-linux zmdc[21057]: INF ['zma -m 1' starting at 12/01/19 13:34:06, pid = 26836]
Jan 19 13:34:06 lab-linux zmdc[26836]: INF ['zma -m 1' started at 12/01/19 13:34:06]
Jan 19 13:34:06 lab-linux zma_m1[26836]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:34:06 lab-linux zma_m1[26836]: ERR [Can't make events/1: Permission denied]
Jan 19 13:34:06 lab-linux zma_m1[26836]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 13:34:06 lab-linux zmdc[21057]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 13:34:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:34:30 zmwatch[21089]: last message repeated 3 times
Jan 19 13:34:30 lab-linux zmc_m1[21080]: INF [NSC15-WG: 191000 - Capturing at 13.16 fps]
Jan 19 13:34:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:35:40 zmwatch[21089]: last message repeated 13 times
Jan 19 13:35:48 zmwatch[21089]: last message repeated 2 times
Jan 19 13:35:48 lab-linux zmc_m1[21080]: INF [NSC15-WG: 192000 - Capturing at 12.82 fps]
Jan 19 13:35:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:37:04 zmwatch[21089]: last message repeated 13 times
Jan 19 13:37:04 lab-linux zmc_m1[21080]: INF [NSC15-WG: 193000 - Capturing at 13.16 fps]
Jan 19 13:37:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:38:10 zmwatch[21089]: last message repeated 13 times
Jan 19 13:38:20 zmwatch[21089]: last message repeated 2 times
Jan 19 13:38:20 lab-linux zmc_m1[21080]: INF [NSC15-WG: 194000 - Capturing at 13.16 fps]
Jan 19 13:38:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:38:57 zmwatch[21089]: last message repeated 7 times
Jan 19 13:38:57 lab-linux kernel: [55429.921455] usb 2-2.2: new low speed USB device number 9 using ohci_hcd
Jan 19 13:38:57 lab-linux mtp-probe: checking bus 2, device 9: "/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2"
Jan 19 13:38:57 lab-linux kernel: [55430.044061] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input10
Jan 19 13:38:57 lab-linux kernel: [55430.044212] generic-usb 0003:045E:0040.0008: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:03.0-2.2/input0
Jan 19 13:38:57 lab-linux mtp-probe: bus: 2, device: 9 was not an MTP device
Jan 19 13:39:01 lab-linux CRON[26942]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Jan 19 13:39:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:39:22 zmwatch[21089]: last message repeated 3 times
Jan 19 13:39:22 lab-linux dbus[893]: [system] Activating service name='org.debian.apt' (using servicehelper)
Jan 19 13:39:23 lab-linux AptDaemon: INFO: Initializing daemon
Jan 19 13:39:23 lab-linux dbus[893]: [system] Successfully activated service 'org.debian.apt'
Jan 19 13:39:23 lab-linux AptDaemon: INFO: UpgradeSystem() was called with safe mode: 1
Jan 19 13:39:23 lab-linux AptDaemon.Trans: INFO: Simulate was called
Jan 19 13:39:23 lab-linux AptDaemon.Worker: INFO: Simulating trans: /org/debian/apt/transaction/ac3aa68777f8451bb53bf6ec2c1b18b2
Jan 19 13:39:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:39:26 lab-linux AptDaemon.Worker: INFO: Upgrade system with safe mode: 1
Jan 19 13:39:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:39:37 lab-linux zmc_m1[21080]: INF [NSC15-WG: 195000 - Capturing at 12.99 fps]
Jan 19 13:39:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:40:29 zmwatch[21089]: last message repeated 9 times
Jan 19 13:40:29 lab-linux AptDaemon: INFO: CommitPackages() was called: dbus.Array([dbus.String(u'phpmyadmin')], signature=dbus.Signature('s')), dbus.Array([dbus.String(u'')], signature=dbus.Signature('s')), dbus.Array([dbus.String(u'')], signature=dbus.Signature('s')), dbus.Array([dbus.String(u'')], signature=dbus.Signature('s')), dbus.Array([dbus.String(u'')], signature=dbus.Signature('s')), dbus.Array([dbus.String(u'')], signature=dbus.Signature('s'))
Jan 19 13:40:29 lab-linux AptDaemon.Trans: INFO: Queuing transaction /org/debian/apt/transaction/8f8c228f1a5a402da190b2820bd6ea0d
Jan 19 13:40:33 lab-linux AptDaemon.Worker: INFO: Simulating trans: /org/debian/apt/transaction/8f8c228f1a5a402da190b2820bd6ea0d
Jan 19 13:40:34 lab-linux AptDaemon.Worker: INFO: Committing packages: dbus.Array([dbus.String(u'phpmyadmin')], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s'))
Jan 19 13:40:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:40:36 lab-linux AptDaemon.Worker: INFO: Processing transaction /org/debian/apt/transaction/8f8c228f1a5a402da190b2820bd6ea0d
Jan 19 13:40:37 lab-linux AptDaemon.Worker: INFO: Committing packages: dbus.Array([dbus.String(u'phpmyadmin')], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s'))
Jan 19 13:40:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:40:52 lab-linux zmc_m1[21080]: INF [NSC15-WG: 196000 - Capturing at 13.33 fps]
Jan 19 13:40:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:41:19 zmwatch[21089]: last message repeated 5 times
Jan 19 13:41:19 lab-linux kernel: [55571.778166] usb 2-2.2: USB disconnect, device number 9
Jan 19 13:41:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:42:09 zmwatch[21089]: last message repeated 9 times
Jan 19 13:42:09 lab-linux zmc_m1[21080]: INF [NSC15-WG: 197000 - Capturing at 12.99 fps]
Jan 19 13:42:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:42:16 lab-linux kernel: [55629.481053] usb 2-2.2: new low speed USB device number 10 using ohci_hcd
Jan 19 13:42:17 lab-linux mtp-probe: checking bus 2, device 10: "/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2"
Jan 19 13:42:17 lab-linux kernel: [55629.608648] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input11
Jan 19 13:42:17 lab-linux kernel: [55629.608793] generic-usb 0003:045E:0040.0009: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:03.0-2.2/input0
Jan 19 13:42:17 lab-linux mtp-probe: bus: 2, device: 10 was not an MTP device
Jan 19 13:42:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:43:26 zmwatch[21089]: last message repeated 13 times
Jan 19 13:43:25 lab-linux zmc_m1[21080]: INF [NSC15-WG: 198000 - Capturing at 12.99 fps]
Jan 19 13:43:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:44:06 zmwatch[21089]: last message repeated 7 times
Jan 19 13:44:06 lab-linux zmdc[21057]: INF [Starting pending process, zma -m 1]
Jan 19 13:44:06 lab-linux zmdc[21057]: INF ['zma -m 1' starting at 12/01/19 13:44:06, pid = 28048]
Jan 19 13:44:06 lab-linux zmdc[28048]: INF ['zma -m 1' started at 12/01/19 13:44:06]
Jan 19 13:44:06 lab-linux zma_m1[28048]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:44:06 lab-linux zma_m1[28048]: ERR [Can't make events/1: Permission denied]
Jan 19 13:44:06 lab-linux zma_m1[28048]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 13:44:06 lab-linux zmdc[21057]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 13:44:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:44:16 lab-linux AptDaemon.Worker: CRITICAL: phpmyadmin: subprocess installed post-installation script returned error exit status 10
Jan 19 13:44:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:44:36 zmwatch[21089]: last message repeated 3 times
Jan 19 13:44:36 lab-linux AptDaemon.Worker: INFO: Finished transaction /org/debian/apt/transaction/8f8c228f1a5a402da190b2820bd6ea0d
Jan 19 13:44:42 lab-linux zmc_m1[21080]: INF [NSC15-WG: 199000 - Capturing at 13.16 fps]
Jan 19 13:44:43 lab-linux AptDaemon: INFO: RemovePackages() was called: 'dbus.Array([dbus.String(u'phpmyadmin')], signature=dbus.Signature('s'))'
Jan 19 13:44:43 lab-linux AptDaemon.Trans: INFO: Queuing transaction /org/debian/apt/transaction/7d9c1c9db5fe4ec586ce4f703c950d4a
Jan 19 13:44:43 lab-linux AptDaemon.Worker: INFO: Simulating trans: /org/debian/apt/transaction/7d9c1c9db5fe4ec586ce4f703c950d4a
Jan 19 13:44:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:44:48 lab-linux AptDaemon.Worker: INFO: Committing packages: dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([dbus.String(u'phpmyadmin')], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s'))
Jan 19 13:44:51 lab-linux AptDaemon.Worker: INFO: Processing transaction /org/debian/apt/transaction/7d9c1c9db5fe4ec586ce4f703c950d4a
Jan 19 13:44:51 lab-linux AptDaemon.Worker: INFO: Committing packages: dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([dbus.String(u'phpmyadmin')], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s')), dbus.Array([], signature=dbus.Signature('s'))
Jan 19 13:44:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:45:24 zmwatch[21089]: last message repeated 5 times
Jan 19 13:45:24 lab-linux AptDaemon.Worker: INFO: Finished transaction /org/debian/apt/transaction/7d9c1c9db5fe4ec586ce4f703c950d4a
Jan 19 13:45:24 lab-linux AptDaemon: INFO: UpgradeSystem() was called with safe mode: 1
Jan 19 13:45:24 lab-linux AptDaemon.Trans: INFO: Simulate was called
Jan 19 13:45:24 lab-linux AptDaemon.Worker: INFO: Simulating trans: /org/debian/apt/transaction/5691ba441eeb43af8eff5603edade3bd
Jan 19 13:45:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:45:27 lab-linux AptDaemon.Worker: INFO: Upgrade system with safe mode: 1
Jan 19 13:45:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:45:57 zmwatch[21089]: last message repeated 5 times
Jan 19 13:45:57 lab-linux zmc_m1[21080]: INF [NSC15-WG: 200000 - Capturing at 13.33 fps]
Jan 19 13:46:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:46:44 zmwatch[21089]: last message repeated 7 times
Jan 19 13:46:44 lab-linux kernel: [55897.024230] usb 2-2.2: USB disconnect, device number 10
Jan 19 13:46:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:47:13 zmwatch[21089]: last message repeated 5 times
Jan 19 13:47:13 lab-linux zmc_m1[21080]: INF [NSC15-WG: 201000 - Capturing at 13.16 fps]
Jan 19 13:47:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:48:25 zmwatch[21089]: last message repeated 14 times
Jan 19 13:48:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:48:29 lab-linux zmc_m1[21080]: INF [NSC15-WG: 202000 - Capturing at 13.16 fps]
Jan 19 13:48:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:49:41 zmwatch[21089]: last message repeated 13 times
Jan 19 13:49:45 zmwatch[21089]: last message repeated 2 times
Jan 19 13:49:45 lab-linux zmc_m1[21080]: INF [NSC15-WG: 203000 - Capturing at 13.16 fps]
Jan 19 13:49:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:51:02 zmwatch[21089]: last message repeated 13 times
Jan 19 13:51:02 lab-linux zmc_m1[21080]: INF [NSC15-WG: 204000 - Capturing at 12.99 fps]
Jan 19 13:51:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:51:23 zmwatch[21089]: last message repeated 3 times
Jan 19 13:51:23 lab-linux AptDaemon: INFO: Quitting due to inactivity
Jan 19 13:51:23 lab-linux AptDaemon: INFO: Quitting was requested
Jan 19 13:51:23 lab-linux dbus[893]: [system] Activating service name='org.debian.apt' (using servicehelper)
Jan 19 13:51:24 lab-linux AptDaemon: INFO: Initializing daemon
Jan 19 13:51:24 lab-linux dbus[893]: [system] Successfully activated service 'org.debian.apt'
Jan 19 13:51:24 lab-linux AptDaemon: INFO: UpgradeSystem() was called with safe mode: 1
Jan 19 13:51:24 lab-linux AptDaemon.Trans: INFO: Simulate was called
Jan 19 13:51:24 lab-linux AptDaemon.Worker: INFO: Simulating trans: /org/debian/apt/transaction/dd99b8f9f5e64732bb2a3dccd727ad8f
Jan 19 13:51:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:51:25 lab-linux AptDaemon.Worker: INFO: Upgrade system with safe mode: 1
Jan 19 13:51:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:52:17 zmwatch[21089]: last message repeated 9 times
Jan 19 13:52:17 lab-linux zmc_m1[21080]: INF [NSC15-WG: 205000 - Capturing at 13.33 fps]
Jan 19 13:52:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:53:33 zmwatch[21089]: last message repeated 13 times
Jan 19 13:53:33 lab-linux zmc_m1[21080]: INF [NSC15-WG: 206000 - Capturing at 13.16 fps]
Jan 19 13:53:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:54:06 zmwatch[21089]: last message repeated 7 times
Jan 19 13:54:06 lab-linux zmdc[21057]: INF [Starting pending process, zma -m 1]
Jan 19 13:54:06 lab-linux zmdc[21057]: INF ['zma -m 1' starting at 12/01/19 13:54:06, pid = 29080]
Jan 19 13:54:06 lab-linux zmdc[29080]: INF ['zma -m 1' started at 12/01/19 13:54:06]
Jan 19 13:54:06 lab-linux zma_m1[29080]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 13:54:06 lab-linux zma_m1[29080]: ERR [Can't make events/1: Permission denied]
Jan 19 13:54:06 lab-linux zma_m1[29080]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 13:54:06 lab-linux zmdc[21057]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 13:54:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:54:49 zmwatch[21089]: last message repeated 7 times
Jan 19 13:54:49 lab-linux zmc_m1[21080]: INF [NSC15-WG: 207000 - Capturing at 13.16 fps]
Jan 19 13:54:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:55:12 zmwatch[21089]: last message repeated 3 times
Jan 19 13:55:12 lab-linux kernel: [56404.857590] usb 2-2.2: new low speed USB device number 11 using ohci_hcd
Jan 19 13:55:12 lab-linux mtp-probe: checking bus 2, device 11: "/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2"
Jan 19 13:55:12 lab-linux kernel: [56404.980284] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input12
Jan 19 13:55:12 lab-linux kernel: [56404.980457] generic-usb 0003:045E:0040.000A: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:03.0-2.2/input0
Jan 19 13:55:12 lab-linux mtp-probe: bus: 2, device: 11 was not an MTP device
Jan 19 13:55:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:56:02 zmwatch[21089]: last message repeated 9 times
Jan 19 13:56:02 lab-linux kernel: [56455.300253] usb 2-2.2: USB disconnect, device number 11
Jan 19 13:56:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:56:06 lab-linux zmc_m1[21080]: INF [NSC15-WG: 208000 - Capturing at 12.99 fps]
Jan 19 13:56:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:56:24 lab-linux AptDaemon: INFO: Quitting due to inactivity
Jan 19 13:56:24 lab-linux AptDaemon: INFO: Quitting was requested
Jan 19 13:56:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:57:21 zmwatch[21089]: last message repeated 11 times
Jan 19 13:57:21 lab-linux zmc_m1[21080]: INF [NSC15-WG: 209000 - Capturing at 13.33 fps]
Jan 19 13:57:25 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:58:35 zmwatch[21089]: last message repeated 14 times
Jan 19 13:58:35 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:58:37 lab-linux zmc_m1[21080]: INF [NSC15-WG: 210000 - Capturing at 13.16 fps]
Jan 19 13:58:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 13:59:54 zmwatch[21089]: last message repeated 13 times
Jan 19 13:59:54 lab-linux zmc_m1[21080]: INF [NSC15-WG: 211000 - Capturing at 12.99 fps]
Jan 19 13:59:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 14:00:44 zmwatch[21089]: last message repeated 9 times
Jan 19 14:00:44 lab-linux kernel: [56736.533539] usb 2-2.2: new low speed USB device number 12 using ohci_hcd
Jan 19 14:00:44 lab-linux mtp-probe: checking bus 2, device 12: "/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2"
Jan 19 14:00:44 lab-linux kernel: [56736.656186] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input13
Jan 19 14:00:44 lab-linux kernel: [56736.656335] generic-usb 0003:045E:0040.000B: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:03.0-2.2/input0
Jan 19 14:00:44 lab-linux mtp-probe: bus: 2, device: 12 was not an MTP device
Jan 19 14:00:45 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 14:01:11 zmwatch[21089]: last message repeated 5 times
Jan 19 14:01:11 lab-linux zmc_m1[21080]: INF [NSC15-WG: 212000 - Capturing at 12.99 fps]
Jan 19 14:01:15 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 14:01:49 zmwatch[21089]: last message repeated 7 times
Jan 19 14:01:49 lab-linux kernel: [56802.111560] usb 2-2.2: USB disconnect, device number 12
Jan 19 14:01:55 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 14:01:56 lab-linux kernel: [56808.781949] usb 2-2.2: new low speed USB device number 13 using ohci_hcd
Jan 19 14:01:56 lab-linux mtp-probe: checking bus 2, device 13: "/sys/devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2"
Jan 19 14:01:56 lab-linux kernel: [56808.904447] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:03.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input14
Jan 19 14:01:56 lab-linux kernel: [56808.904600] generic-usb 0003:045E:0040.000C: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:03.0-2.2/input0
Jan 19 14:01:56 lab-linux mtp-probe: bus: 2, device: 13 was not an MTP device
Jan 19 14:02:05 lab-linux zmwatch[21089]: ERR [Shared data size conflict in shared_data for monitor NSC15-WG, expected 328, got 316]
Jan 19 14:02:23 zmwatch[21089]: last message repeated 3 times
Jan 19 14:02:23 lab-linux zmpkg[29345]: INF [Command: restart]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmupdate.pl -c' stopping at 12/01/19 14:02:23]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmupdate.pl -c' exited, signal 14]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmwatch.pl ' stopping at 12/01/19 14:02:23]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmwatch.pl ' exited, signal 14]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmaudit.pl -c' stopping at 12/01/19 14:02:23]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmaudit.pl -c' exited, signal 14]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmfilter.pl ' stopping at 12/01/19 14:02:23]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmfilter.pl ' exited, signal 14]
Jan 19 14:02:23 lab-linux zmdc[21057]: INF ['zmc -m 1' stopping at 12/01/19 14:02:23]
Jan 19 14:02:23 lab-linux zmc_m1[21080]: INF [Got signal 15 (Terminated), exiting]
Jan 19 14:02:23 lab-linux zmc_m1[21080]: ERR [Select error: Interrupted system call]
Jan 19 14:02:23 lab-linux zmc_m1[21080]: ERR [Unable to read content]
Jan 19 14:02:23 lab-linux zmc_m1[21080]: ERR [Unable to get response]
Jan 19 14:02:23 lab-linux zmc_m1[21080]: ERR [Failed to capture image from monitor 1 (0/1)]
Jan 19 14:02:23 lab-linux zmdc[21057]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jan 19 14:02:33 lab-linux zmdc[21057]: INF [Server shutdown at 12/01/19 14:02:33]
Jan 19 14:02:34 lab-linux zmdc[29383]: INF [Server starting at 12/01/19 14:02:34]
Jan 19 14:02:37 lab-linux zmdc[29383]: INF ['zmc -m 1' starting at 12/01/19 14:02:37, pid = 29406]
Jan 19 14:02:37 lab-linux zmdc[29406]: INF ['zmc -m 1' started at 12/01/19 14:02:37]
Jan 19 14:02:37 lab-linux zmc_m1[29406]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 14:02:38 lab-linux zmc_m1[29406]: INF [Starting Capture]
Jan 19 14:02:38 lab-linux zmdc[29383]: INF ['zma -m 1' starting at 12/01/19 14:02:38, pid = 29408]
Jan 19 14:02:38 lab-linux zmdc[29408]: INF ['zma -m 1' started at 12/01/19 14:02:38]
Jan 19 14:02:38 lab-linux zma_m1[29408]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 14:02:38 lab-linux zma_m1[29408]: ERR [Can't make events/1: Permission denied]
Jan 19 14:02:38 lab-linux zma_m1[29408]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 14:02:38 lab-linux zmdc[29383]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 14:02:38 lab-linux zmdc[29383]: INF [Starting pending process, zma -m 1]
Jan 19 14:02:38 lab-linux zmdc[29383]: INF ['zma -m 1' starting at 12/01/19 14:02:38, pid = 29410]
Jan 19 14:02:38 lab-linux zmdc[29410]: INF ['zma -m 1' started at 12/01/19 14:02:38]
Jan 19 14:02:38 lab-linux zma_m1[29410]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 14:02:38 lab-linux zma_m1[29410]: ERR [Can't make events/1: Permission denied]
Jan 19 14:02:38 lab-linux zma_m1[29410]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 14:02:38 lab-linux zmdc[29383]: INF ['zmfilter.pl' starting at 12/01/19 14:02:38, pid = 29411]
Jan 19 14:02:38 lab-linux zmdc[29411]: INF ['zmfilter.pl' started at 12/01/19 14:02:38]
Jan 19 14:02:38 lab-linux zmdc[29383]: INF ['zmaudit.pl -c' starting at 12/01/19 14:02:38, pid = 29413]
Jan 19 14:02:38 lab-linux zmdc[29413]: INF ['zmaudit.pl -c' started at 12/01/19 14:02:38]
Jan 19 14:02:39 lab-linux zmfilter[29411]: INF [Scanning for events]
Jan 19 14:02:39 lab-linux zmdc[29383]: INF ['zmwatch.pl' starting at 12/01/19 14:02:39, pid = 29415]
Jan 19 14:02:39 lab-linux zmdc[29415]: INF ['zmwatch.pl' started at 12/01/19 14:02:39]
Jan 19 14:02:39 lab-linux zmwatch[29415]: INF [Watchdog starting]
Jan 19 14:02:39 lab-linux zmdc[29383]: INF ['zmupdate.pl -c' starting at 12/01/19 14:02:39, pid = 29417]
Jan 19 14:02:39 lab-linux zmwatch[29415]: INF [Watchdog pausing for 30 seconds]
Jan 19 14:02:39 lab-linux zmdc[29417]: INF ['zmupdate.pl -c' started at 12/01/19 14:02:39]
Jan 19 14:02:43 lab-linux zmdc[29383]: INF [Starting pending process, zma -m 1]
Jan 19 14:02:43 lab-linux zmdc[29383]: INF ['zma -m 1' starting at 12/01/19 14:02:43, pid = 29429]
Jan 19 14:02:43 lab-linux zmdc[29429]: INF ['zma -m 1' started at 12/01/19 14:02:43]
Jan 19 14:02:43 lab-linux zma_m1[29429]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 14:02:43 lab-linux zma_m1[29429]: ERR [Can't make events/1: Permission denied]
Jan 19 14:02:43 lab-linux zma_m1[29429]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 14:02:43 lab-linux zmdc[29383]: ERR ['zma -m 1' exited abnormally, exit status 255]
Jan 19 14:02:53 lab-linux zmdc[29383]: INF [Starting pending process, zma -m 1]
Jan 19 14:02:53 lab-linux zmdc[29383]: INF ['zma -m 1' starting at 12/01/19 14:02:53, pid = 29433]
Jan 19 14:02:53 lab-linux zmdc[29433]: INF ['zma -m 1' started at 12/01/19 14:02:53]
Jan 19 14:02:53 lab-linux zma_m1[29433]: INF [Debug Level = 0, Debug Log = <none>]
Jan 19 14:02:53 lab-linux zma_m1[29433]: ERR [Can't make events/1: Permission denied]
Jan 19 14:02:53 lab-linux zma_m1[29433]: FAT [Can't symlink '1' to 'NSC15-WG': Permission denied]
Jan 19 14:02:53 lab-linux zmdc[29383]: ERR ['zma -m 1' exited abnormally, exit status 255]
To get rid of this message:
[Shared data size conflict in shared_data for monitor Monitor, expected 328, got 316]
Replace with in
Notice that your path to the Memory.pm file could be different, to find the file use find / -name Memory.pm
Or search in the forum, I remember read something about arch being a internal variable name, so changing the name of the variable worked also.
Hope it helps,
PacoLM
Replace
$arch = int(3.2*length(~0));
$arch = 32;
/usr/local/share/perl/5.12.4/ZoneMinder/Memory.pm
Hope it helps,
PacoLM
I had similar problem and it was due to the fact that the settings in "remote hostname" was not correct.
check if this works:
from the main zoneminder console, under the option 'source'
select the link. then check settings on general and source tab.
mine are like so:
general -
name -> cameraname
sourcetype ->remote (yours would be local if the cam is locally attached)
function -> modetect
linkedmonitors -> cameraname
ref image blend %ge -> 7
source -
protocol -> http
method -> simple
remote hostname -> user: password@remote.hostname
port -> port
width -> 640
height -> 480
orientation -> normal
bear in mind im using an ip camera, but I'll bet your settings should look similar.
For me that set everything on green.... only I have no stream, no probe.
The motion detection works.. etc etc.
On probe I have the 127 error and there is where I am at.
I changed the:
arch = int(3.2*length(~0)); into arch = 32;
in /usr/local/share/perl/5.12.4/ZoneMinder/Memory.pm
but I get no stream what so ever.
mine are like so:
general -
name -> cameraname
source -
protocol -> http
method -> simple
port -> port
width -> 640
height -> 480
I changed the:
Hi MrMookey,
My camera settings are ALL OK because I can see a stream and I applied the same settings as in my previous setup, while I was running Ubuntu 11.04. The problem is that the "source" stays in "orange" color and I have no clue what that means?!
I suspect a problem with mySQL since I don't see any events being logged, etc.
How can I troubleshoot mySQL? Where to start? How can I log in to mySQL to see if there is at least a ZM user added, some tables, etc. ??
Regards,
highmighty
Regards,
highmighty
Hey there.
As I am still goofing around to get streaming I noticed that I had the same probe as you. It was orange.
I found out that I had set my ZM settings to 640*480 but in my camera I had set it to 320*240.
Everything was working only the settings of both were different.
Have you checked that??
