Montage problems using native firefox mjpeg but not cambozol
somepdguy
Post by somepdguy »
Hi
I have two installations suffering from the same problem after upgrading to the 1.20.1 verison of ZM.
The montage will only ever bring up 2 of the 4 cameras, and it varies which ones. If I right click on one of the images that doesn't appear and try show image it comes up with a message saying something like "this stream/image cannot be displayed because it contains errors" then quickly redirects off to just showing that one camera, or rather just a still frame of the camera. I have enabled random strings to prevent caching but that doesn't help.
Both boxes are around 1 gig celerons or Durons, 1 gig ram, one box has 4 wireless cams and one box has 4 wired cams via a BT848 card. I can't see any errors in the logs in /var/log/messages just normal detecting events and /tmp/zm* doesn't move at all when I bring up the montage!
I notice lots of posts about montage problems but I can't see any the same as this. :\
All help appriciated as ever.
Pete
cordel
Post by cordel »
Check this thread. It should clear that up.
http://www.zoneminder.com/forums/viewto ... wser.cache
cheers,
Cordel
somepdguy
Sorted
Post by somepdguy »
Sorry I was only reading the 1.20.x posts - it didn't do it for me in 1.19.x ?!
In have changed as per these FYI (for anyone else being blonde like me ;) ):
QUOTE
Open firefoe and type in the URL box
about:config
scrolll down to
Code:
browser.cache.check_doc_frequency 3
change to
browser.cache.check_doc_frequency 1
I 'also changed just to be sure.
Code:
browser.cache.disk.enable True
to
browser.cache.disk.enable False
That will get rid of your broken image problem
Cordel
ENDQUOTE
and
QUOTE
n case of mozilla do the following :
type about:config in the text area
search for and change :
network.http.max-connections-per-server -> put a value of 100
network.http.max-persistent-connections-per-proxy -> 100 again
network.http.max-persistent-connections-per-server -> 100 again
browser.cache.check_doc_frequency -> change to 1
this all should fix it. just close the browser and open it again.
see you !
Victor Diago
ENDQUOTE
and it fixed my firefox montage problem
Thanks guys
Pete
cordel
Post by cordel »
NP,
I was blond on this issue as well one time :wink: Luckly the bleach job was boched, Thank someone for roots :lol:
Cheers,
Cordel
