Streaming problem
omicronvt
Streaming problem
Post by omicronvt »
Running zm 1.24.2 in Ubuntu for some time with no errors. Suddenly i have no live video from monitors, events are recorded OK, but if i try to watch them: same problem ---> no video. View frame inside event is working OK. Video generation is working OK. Syslog reports no error. It is like zm refuses to stream video...
MrMookey
Re: Streaming problem
Post by MrMookey »
Here almost the same.
I run Ubuntu 10.04, having a Foscam FI8918W hooked on my modem/router.
I set up ZM, have everything on green (Modect, camera name) but no stream.
On probe I get : "Unable to probe network cameras, status is '127'"
Settings:
Remote Protocol: http
Remote Method: simple
host: user:pwd@ip-adress
port: port of the cam
hostpfad: /video.cgi
pixel: 640
480
I have been looking for hours but no avail.
I know it is working because it takes pics on detection! I see it in the "events".
How can this be solved?
It is the last step to complete it.
Any help is much appreciated!
MrMookey
Post by MrMookey »
Hey omicronvt have you found the solution yet?
I am this far that I do not have the error... i just get nothing. What about you??
PacoLM
Post by PacoLM »
Post the logs in /var/log/syslog just after starting zoneminder, it will help to determine the source of your problem. Have you checked the shared memory settings?.
MrMookey
Post by MrMookey »
@ PacoLM
ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 32768
max total shared memory (kbytes) = 8388608
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 978
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
In the sysctl.conf I have:
#kernel.shmall = 16777216
#kernel.shmmax = 268435456
as for the /var/log/syslog :
Jan 22 14:20:03 Thunder zmdc[6104]: INF [Server starting at 12/01/22 14:20:03]
Jan 22 14:20:09 Thunder zmdc[6104]: INF ['zmc -m 1' starting at 12/01/22 14:20:09, pid = 6126]
Jan 22 14:20:09 Thunder zmdc[6126]: INF ['zmc -m 1' started at 12/01/22 14:20:09]
Jan 22 14:20:09 Thunder zmc_m1[6126]: INF [Debug Level = 0, Debug Log = <none>]
Jan 22 14:20:10 Thunder zmc_m1[6126]: INF [Starting Capture]
Jan 22 14:20:10 Thunder zmdc[6128]: INF ['zma -m 1' started at 12/01/22 14:20:10]
Jan 22 14:20:10 Thunder zmdc[6104]: INF ['zma -m 1' starting at 12/01/22 14:20:10, pid = 6128]
Jan 22 14:20:11 Thunder zma_m1[6128]: INF [Debug Level = 0, Debug Log = <none>]
Jan 22 14:20:11 Thunder zma_m1[6128]: INF [In mode 3/1, warming up]
Jan 22 14:20:12 Thunder zmdc[6104]: INF ['zmtrack.pl -m 1' starting at 12/01/22 14:20:12, pid = 6130]
Jan 22 14:20:12 Thunder zmdc[6130]: INF ['zmtrack.pl -m 1' started at 12/01/22 14:20:12]
Jan 22 14:20:14 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:15 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:15 Thunder zmdc[6104]: INF ['zmfilter.pl' starting at 12/01/22 14:20:15, pid = 6132]
Jan 22 14:20:15 Thunder zmdc[6132]: INF ['zmfilter.pl' started at 12/01/22 14:20:15]
Jan 22 14:20:15 Thunder zmdc[6104]: ERR ['zmtrack.pl -m 1' exited abnormally, exit status 255]
Jan 22 14:20:15 Thunder zmdc[6104]: INF [Starting pending process, zmtrack.pl -m 1]
Jan 22 14:20:15 Thunder zmdc[6104]: INF ['zmtrack.pl -m 1' starting at 12/01/22 14:20:15, pid = 6134]
Jan 22 14:20:15 Thunder zmdc[6134]: INF ['zmtrack.pl -m 1' started at 12/01/22 14:20:15]
Jan 22 14:20:17 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:18 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:18 Thunder zmdc[6104]: INF ['zmaudit.pl -c' starting at 12/01/22 14:20:18, pid = 6135]
Jan 22 14:20:18 Thunder zmdc[6135]: INF ['zmaudit.pl -c' started at 12/01/22 14:20:18]
Jan 22 14:20:19 Thunder zmdc[6104]: ERR ['zmtrack.pl -m 1' exited abnormally, exit status 255]
Jan 22 14:20:20 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:21 Thunder zmfilter[6132]: INF [Scanning for events]
Jan 22 14:20:21 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
Jan 22 14:20:22 Thunder zmdc[6104]: INF ['zmwatch.pl' starting at 12/01/22 14:20:22, pid = 6137]
Jan 22 14:20:22 Thunder zmdc[6137]: INF ['zmwatch.pl' started at 12/01/22 14:20:22]
Jan 22 14:20:22 Thunder zmaudit[6135]: INF [Filesystem event '1/66' does not exist in database]
Jan 22 14:20:22 Thunder zmaudit[6135]: INF [deleting]
Jan 22 14:20:23 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:24 Thunder zmdc[6104]: INF [Starting pending process, zmtrack.pl -m 1]
Jan 22 14:20:24 Thunder zmdc[6104]: INF ['zmtrack.pl -m 1' starting at 12/01/22 14:20:24, pid = 6140]
Jan 22 14:20:24 Thunder zmdc[6140]: INF ['zmtrack.pl -m 1' started at 12/01/22 14:20:24]
Jan 22 14:20:24 Thunder zmwatch[6137]: INF [Watchdog starting]
Jan 22 14:20:24 Thunder zmwatch[6137]: INF [Watchdog pausing for 30 seconds]
Jan 22 14:20:26 Thunder zmdc[6104]: ERR ['zmtrack.pl -m 1' exited abnormally, exit status 255]
Jan 22 14:20:28 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:30 Thunder zmc_m1[6126]: last message repeated 3 times
Jan 22 14:20:30 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
Jan 22 14:20:33 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
Jan 22 14:20:34 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:36 Thunder zmc_m1[6126]: last message repeated 4 times
Jan 22 14:20:36 Thunder zmdc[6104]: INF [Starting pending process, zmtrack.pl -m 1]
Jan 22 14:20:36 Thunder zmdc[6104]: INF ['zmtrack.pl -m 1' starting at 12/01/22 14:20:36, pid = 6141]
Jan 22 14:20:36 Thunder zmdc[6141]: INF ['zmtrack.pl -m 1' started at 12/01/22 14:20:36]
Jan 22 14:20:37 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:39 Thunder zmdc[6104]: ERR ['zmtrack.pl -m 1' exited abnormally, exit status 255]
Jan 22 14:20:41 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:50 Thunder zmc_m1[6126]: last message repeated 7 times
Jan 22 14:20:50 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
Jan 22 14:20:51 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:20:59 Thunder zmc_m1[6126]: last message repeated 8 times
Jan 22 14:20:59 Thunder zmdc[6104]: INF [Starting pending process, zmtrack.pl -m 1]
Jan 22 14:20:59 Thunder zmdc[6104]: INF ['zmtrack.pl -m 1' starting at 12/01/22 14:20:59, pid = 6152]
Jan 22 14:20:59 Thunder zmdc[6152]: INF ['zmtrack.pl -m 1' started at 12/01/22 14:20:59]
Jan 22 14:20:59 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:21:02 Thunder zmdc[6104]: ERR ['zmtrack.pl -m 1' exited abnormally, exit status 255]
Jan 22 14:21:02 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Jan 22 14:21:03 Thunder nullmailer[890]: Rescanning queue.
Jan 22 14:21:03 Thunder nullmailer[890]: Starting delivery: protocol: smtp host: smtp.xxx...xxfile: 1327216350.4359
Jan 22 14:21:03 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
Jan 22 14:21:04 Thunder nullmailer[6153]: smtp: Failed: 553 5.1.8 <root@Thunder.Thunder>... Domain of sender address root@Thunder.Thunder does not exist
Jan 22 14:21:04 Thunder nullmailer[890]: Sending failed: Permanent error in sending the message
Jan 22 14:21:04 Thunder nullmailer[890]: Delivery complete, 1 message(s) remain.
Jan 22 14:21:04 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
Jan 22 14:21:04 Thunder zmc_m1[6126]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Well the sending of the mail is what I will pick up later but the stream is my main concern.
Can you see how and what?
I really do appreciate your time and effort in this Paco!!!
PacoLM
Post by PacoLM »
If you get the image in the events but no live stream, then for sure should be a configuration problem. Which OS and internet browser are you using to see the live stream?.
Try this, just to check that everything is fine on the ZM image & source config side:
1st: change the source path, instead of video.cgi, try snapshot.cgi instead (I believe foscam cameras support it)
2nd: try with a lower resolution, 320x240 instead of 640x480.
Don't forget to restart ZM after these changes.
PacoLM
MrMookey
Post by MrMookey »
OS = 10.04 (lucid) and the default browser = firefox
Applied the changes as suggested but no avail.
So weird as when I do http:/myip/videostream.asf?user=&pwd=
I have the streaming.
Also from the basic Foscam ip... not from ZM.
Must be a small tweak.. but damn.. where man?? 8)
Thanks for your help dude!!!
MrMookey
Post by MrMookey »
Still trying and trying :|
As mentioned. It detects everything.
The bastard even keeps on filming ;)
Now it is just the stream ...grrrrrrr
MrMookey
Post by MrMookey »
Running out of ideas and tweaks etc etc.
Any other options, suggestions???
One would be uninstalling it and try 1.25.x
But that does not guarantuee anything as well.
MrMookey
Post by MrMookey »
Finally I got it working only now the controls :lol:
Getting there!!
