No Video on Monitor after configuration
Hi, to all
after configuring I cannot see anything,
my webcam is working with Cheese
see attached files for configuration.
zmu -d /dev/video0 -q -v
Video Device: /dev/video0
General Capabilities
Driver: uvcvideo
Card: Laptop_Integrated_Webcam_2M
Bus: usb-0000:00:1a.7-6
Version: 1.0.0
Type: 0x4000001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Does not support read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
Formats:
YUV 4:2:2 (YUYV) (YUYV)
MJPEG (MJPG)
Crop Capabilities
Bounds: 320 x 240
Default: 320 x 240
Current: Cropping is not supported
Inputs: 1
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Driver: uvcvideo
Version: 1.0.0
Type: 0x4000001
Does not have tuner
Does not have radio
Standards:
Formats:
MJPEG (MJPG)
Crop Capabilities
Bounds: 320 x 240
Default: 320 x 240
Inputs: 1
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
- zm-2.png (28.6 KiB) Viewed 7161 times
- zm-1.png (28.54 KiB) Viewed 7161 times
Re: No Video on Monitor after configuration
Start by lowering resolution to 320*240.
... no progress also with 320*240...
- zm-3.png (26.6 KiB) Viewed 7155 times
Did you restart ZM after the resolution change?
Cheers,
Mattt.
Cheers,
Mattt.
Shared memory settings?. Post the /var/log/syslog when restarting the application.
it's working with 160x120 .
cat /proc/sys/kernel/shmall
2097152
do i need to increase shared memory ?
2097152
I wouldn't mess with it if your happy with the resolution and buffer settings. If you know the resolution should be higher and are sure the shared memory settings are the problem then you might have to. This explains how to tell in the logs and how to calculate the settings: http://www.zoneminder.com/wiki/index.ph ... esolutions
Now...No Video on motion detect
maybe no experience...
I cannot see the area to define a zone....
can you help me ?
can you help me ?
- md1.png (18.49 KiB) Viewed 7095 times
- md2.png (19.13 KiB) Viewed 7095 times
Have you clicked in the 'All' link of the Zones window?
if i click on All I have the following :
wrong parameters ?
wrong parameters ?
- md4.png (30.58 KiB) Viewed 7084 times
no improvement !!!!
help me !!
- md5.png (40.82 KiB) Viewed 7076 times
no any idea ?
pls help me !!
try using different browser
Had the same problem a couple of times, was somehow related to moving the zm events to different folder which broke things. Make sure paths are correct and file permissions are ok. If you are building a new surveillance system so there is no data you want to save, purging zoneminder, removing related files and re-installing solved for me.
