[SOLVED] CentOS 6.2 64 bit: make error: [zm_local_camera.o]
neuropa
Post by neuropa »
I am getting a compile error, installing Zoneminder 1.25.0 on CentOS 6.2 64 bit.
Ffmpeg version: N-37454-gd76864d
Here is the error after 'make':
In file included from zm_local_camera.cpp:24:
zm_local_camera.h:101: error: ‘PixelFormat’ does not name a type
zm_local_camera.h:102: error: ‘PixelFormat’ does not name a type
zm_local_camera.h:103: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_local_camera.h:103: error: expected ‘;’ before ‘*’ token
zm_local_camera.cpp:44: error: ‘PixelFormat’ does not name a type
zm_local_camera.cpp:259: error: expected constructor, destructor, or type conversion before ‘*’ token
zm_local_camera.cpp: In constructor ‘LocalCamera::LocalCamera(int, const std::string&, int, int, const std::string&, int, int, int, int, int, int, int, bool)’:
zm_local_camera.cpp:324: error: ‘imagePixFormat’ was not declared in this scope
zm_local_camera.cpp:324: error: ‘PIX_FMT_GRAY8’ was not declared in this scope
zm_local_camera.cpp:324: error: ‘PIX_FMT_RGB24’ was not declared in this scope
zm_local_camera.cpp:325: error: ‘capturePixFormat’ was not declared in this scope
zm_local_camera.cpp:325: error: ‘getFfPixFormatFromV4lPalette’ was not declared in this scope
zm_local_camera.cpp: In member function ‘void LocalCamera::Initialise()’:
zm_local_camera.cpp:341: error: ‘AV_LOG_DEBUG’ was not declared in this scope
zm_local_camera.cpp:341: error: ‘av_log_set_level’ was not declared in this scope
zm_local_camera.cpp:343: error: ‘AV_LOG_QUIET’ was not declared in this scope
zm_local_camera.cpp:343: error: ‘av_log_set_level’ was not declared in this scope
zm_local_camera.cpp:464: error: ‘capturePictures’ was not declared in this scope
zm_local_camera.cpp:464: error: expected type-specifier before ‘AVFrame’
zm_local_camera.cpp:464: error: expected ‘;’ before ‘AVFrame’
zm_local_camera.cpp:488: error: ‘imagePixFormat’ was not declared in this scope
zm_local_camera.cpp:488: error: ‘capturePixFormat’ was not declared in this scope
zm_local_camera.cpp:490: error: ‘avcodec_alloc_frame’ was not declared in this scope
zm_local_camera.cpp:493: error: ‘AVPicture’ was not declared in this scope
zm_local_camera.cpp:493: error: expected primary-expression before ‘)’ token
zm_local_camera.cpp:493: error: ‘avpicture_fill’ was not declared in this scope
zm_local_camera.cpp:631: error: ‘capturePictures’ was not declared in this scope
zm_local_camera.cpp:631: error: expected type-specifier before ‘AVFrame’
zm_local_camera.cpp:631: error: expected ‘;’ before ‘AVFrame’
zm_local_camera.cpp:639: error: ‘imagePixFormat’ was not declared in this scope
zm_local_camera.cpp:639: error: ‘capturePixFormat’ was not declared in this scope
zm_local_camera.cpp:641: error: ‘avcodec_alloc_frame’ was not declared in this scope
zm_local_camera.cpp:644: error: ‘AVPicture’ was not declared in this scope
zm_local_camera.cpp:644: error: expected primary-expression before ‘)’ token
zm_local_camera.cpp:644: error: ‘avpicture_fill’ was not declared in this scope
zm_local_camera.cpp: In static member function ‘static bool LocalCamera::GetCurrentSettings(const char*, char*, int, bool)’:
zm_local_camera.cpp:774: error: ‘PATH_MAX’ was not declared in this scope
zm_local_camera.cpp:779: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:781: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:782: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:799: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:801: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:811: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:936: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:961: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp:1086: error: ‘queryDevice’ was not declared in this scope
zm_local_camera.cpp: In member function ‘virtual int LocalCamera::Capture(Image&)’:
zm_local_camera.cpp:1643: error: expected initializer before ‘*’ token
zm_local_camera.cpp:1645: error: ‘imagePixFormat’ was not declared in this scope
zm_local_camera.cpp:1645: error: ‘capturePixFormat’ was not declared in this scope
zm_local_camera.cpp:1649: error: ‘SWS_BICUBIC’ was not declared in this scope
zm_local_camera.cpp:1649: error: ‘sws_getCachedContext’ was not declared in this scope
zm_local_camera.cpp:1653: error: ‘tmpPicture’ was not declared in this scope
zm_local_camera.cpp:1653: error: ‘avcodec_alloc_frame’ was not declared in this scope
zm_local_camera.cpp:1656: error: ‘avpicture_get_size’ was not declared in this scope
zm_local_camera.cpp:1657: error: ‘av_malloc’ was not declared in this scope
zm_local_camera.cpp:1660: error: ‘AVPicture’ was not declared in this scope
zm_local_camera.cpp:1660: error: expected primary-expression before ‘)’ token
zm_local_camera.cpp:1660: error: ‘avpicture_fill’ was not declared in this scope
zm_local_camera.cpp:1662: error: ‘capturePictures’ was not declared in this scope
zm_local_camera.cpp:1662: error: ‘tmpPicture’ was not declared in this scope
zm_local_camera.cpp:1662: error: ‘sws_scale’ was not declared in this scope
make[2]: *** [zm_local_camera.o] Error 1
make[2]: Leaving directory `/usr/src/ZoneMinder-1.25.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/ZoneMinder-1.25.0'
make: *** [all] Error 2
Any suggestion?
Thanks...
butlerm1977
Re: CentOS 6.2 64 bit: make[2]: *** [zm_local_camera.o] Erro
Post by butlerm1977 »
I got past a very similar build / make issue on CentOS 5.6 x64 installing ZM 1.25. Looks like the git version of ffmpeg has something going on right now, version change or something. This error just started cropping up within the last week or so. I used to have no problems following the CentOS wiki.
To get around this, I did make uninstall to remove ffmpeg. Then installed ffmpeg (0.6.5) and ffmpeg-devel using yum. After that, the ./configure and make ran with no errors.
neuropa
Post by neuropa »
So, do you think that compiling a previous release of ffmpeg will solve the problem?
I've got a working installation with CentOS 6.0 and Zoneminder 1.25.0 several months ago...
butlerm1977
Sounds like a good plan. Let us know which version works for you.
rdctaylor
Post by rdctaylor »
I had the same issue with CentOS 6.2 and the ffmpeg from git. I followed the suggestion in this thread by uninstalling the git version and yum installing both ffmpeg and the devel and the compile worked.
Thank you!
neuropa
Post by neuropa »
I tried with ffmpeg version N-35287-g7076967 from git and works!
