EasyN FS-613B-M166 IP PTZ camera
therese
Post by therese »
Got the video to work on zoneminder but not able to control the ptz function, anyone have any experience with this camera. Thanks.
[ General ]
Name
Source Type Remote
Function Monitor
Enabled yes
Linked Monitors
Maximum FPS 10.0
Alarm Maximum FPS
Reference Image Blend %ge 7
Triggers None available
[ Source ]
Remote Protocol HTTP
Remote Method Simple
Remote Host Name 192.168.1.130
Remote Host Port 81
Remote Host Path /videostream.cgi?user=admin&pwd=(enter here if any)&resolution=8&rate=6
Remote Image Colours 24 bit colour
Capture Width (pixels) 320
Capture Height (pixels) 240
Preserve Aspect Ratio
Orientation Normal
Here is what I have found so far on this camera...
/ip address/videostream.cgi?user=admin&pwd=&resolution=8&rate=0 (remote host path)
/ip address/decoder_control.cgi?command=6 (pan right)
/ip address/decoder_control.cgi?command=1 (stop)
/ip address/decoder_control.cgi?command=4 (pan left)
/ip address/decoder_control.cgi?command=0 (up)
/ip address/decoder_control.cgi?command=2 (down)
/ip address/decoder_control.cgi?command=31 (preset 1)
/ip address/decoder_control.cgi?command=33 (preset 2)
/ip address/decoder_control.cgi?command=35 (preset 3)
/ip address/decoder_control.cgi?command=37 (preset 4)
/ip address/camera_control.cgi?param=5&value=1 (mirror vertically)
/ip address/camera_control.cgi?param=5&value=2 (mirror horizontally)
PTZ control on camera getting this message..
Control response was status = undefined
message = /usr/bin/zmcontrol.pl --autostop --command=moveConRight --id=5=>
2Psycho
Re: EasyN FS-613B-M166 IP PTZ camera
Post by 2Psycho »
Hi Therese,
I will respond into this topic :)
I created a new control in the web administration module.
Evenso I have created a new control file in the Perl directory.
In this file all actions are specifeid.
I already saw that your camera is different from mine.
But I think you have to use for example to use PTZ up
sub Up
    my $self = shift;
    Debug( "Move Up" );
    my $cmd = "decoder_control.cgi?command=0";
    $self->sendCmd( $cmd );
But I think you have to use for example to use PTZ down
Sub Down
    my $self = shift;
    Debug( "Move Down" );
    my $cmd = "decoder_control.cgi?command=2";
Togheter with this and my other post I think you will be able to create your own control
EasyN Control H serie
Let me know if you manage otherwise I will try to help.
Enjoyment Matters
therese
Post by therese »
Thank you for replying so quickly , I will try and I will keep you posted... :)
therese
Post by therese »
Created perl file and saved it as Easyn.pm @ usr/share/perl5/zoneminder/control/ but still not able to control ptz function, am I still missing something...thanks.
sub Up
my $self = shift;
Debug( "Move Up" );
sub Down
my $self = shift;
sub Left
my $self = shift;
Debug( "Move Left" );
my $cmd = "decoder_control.cgi?command=4";
sub Right
my $self = shift;
Debug( "Move Right" );
my $cmd = "decoder_control.cgi?command=6";
Checked under /tmp/zmcontrol log and this is what I was getting...
02/06/12 17:21:23.825888 zmcontrol[1482].INF [Starting control server 5/EasyN]
02/06/12 17:21:23.835769 zmcontrol[1484].INF [Control server 5/EasyN starting at 12/02/06 17:21:23]
02/06/12 17:21:33.833488 zmcontrol[1482].FAT [Can't connect: No such file or directory]
2Psycho
Post by 2Psycho »
Therese
The location you are mentioning is this also the directory where other control files are located?
Otherwise you can search for a file using the command "find / -name PanasonicIP.pm"
You system should give you the correct file location then were to put your own control file.
regards
Enjoyment Matters
therese
Post by therese »
yes that is where the other files are. I am using Ubuntu 10.04 LTS.
I am new at using Linux so not too sure. Using terminal mode and get into the file by "sudo gedit " open a new document then I copied the file and saved it as EasyN.pm in usr/share/perl5/zoneminder/control. I hope this is correct. Thank you for helping me.
file location.jpg (37.66 KiB) Viewed 10787 times
2Psycho
Post by 2Psycho »
Therese,
ZoneMinder can not find the file. Maybe you didn't have set rights to read the file?
Evenso I post some screenshots from my config maybe that will also help.
Enjoyment Matters
therese
Post by therese »
Maybe that is what I was doing wrong. How do you setup rights to read the file ? I am new on Linux and not sure how to do this. Thanks. Screen shots of my setup.
therese
Post by therese »
This is what shows up and my zmcontrol log file.
control scrn_shot.jpg (61.69 KiB) Viewed 10762 times
2Psycho
Post by 2Psycho »
Therese,
First you have to remove the "EasyN" text from the label control device.
This setting is e.q. for serial ports etc.
Second your address i would try:
username:password@192.168.1.30:81
Just fill in your username and password.
Enjoyment Matters
therese
Post by therese »
I tried that and it was still the same. The same error log.
admin:@192.168.1.30:81
there is no password for the camera just the username.
2Psycho
Post by 2Psycho »
Therese,
Try to modify the EasyN.pm file command with
my $cmd = "decoder_control.cgi?command=0&user=admin&pwd=";
The control address as specified 192.168.1.30:81
No control device
Enjoyment Matters
therese
Post by therese »
No control device
Did the changes to the my $cmd but still not working.
2Psycho
Post by 2Psycho »
Therese,
I just saw in one of your screenshots that you have the message moveConRight.
Can you post your config file?
Check also your "Control Capabilities" of EasyN "Can Move Continuous" should NOT be selected for this camera that's another configuration. I think that you have selected that on this moment
Enjoyment Matters
therese
Post by therese »
Configuration file ? is it the Easyn.pm file you wanted...
# ZoneMinder Foscam FI8908W IP Control Protocol Module, $Date: 2009-11-25 09:20:00 +0000 (Wed, 04 Nov 2009) $, $Revision: 0001 $
# Modified for use with Foscam FI8908W IP Camera by Dave Harris
# Foundation, Inc., 59 Temple Place – Suite 330, Boston, MA 02111-1307, USA.
# This module contains the implementation of the Foscam FI8908W IP camera control
# protocol
package ZoneMinder::Control::EasyN;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Foscam FI8908W IP Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
my $logindetails = “”;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $class = ref($self) || croak( “$self not object” );
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
Fatal( “Can’t access $name member of object of class $class” );
our $stop_command;
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{ua}->agent( “ZoneMinder Control Agent/”.ZM_VERSION );
$self->{state} = ‘open’;
sub close
my $self = shift;
$self->{state} = ‘closed’;
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
Debug( $msg.”[".$msg_len."]” );
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, “Tx” );
my $req = HTTP::Request->new( GET=>”http://”.$self->{Monitor}->{ControlAddress}.”/$cmd” );
if ( $res->is_success )
$result = !undef;
else
Error( “Error check failed:’”.$res->status_line().”‘” );
return( $result );
sub reset
my $self = shift;
Debug( “Camera Reset” );
my $cmd = “reboot.cgi?user=admin&pwd=”;
#Up Arrow
sub moveConUp
my $self = shift;
$stop_command = “1?;
Debug( “Move Up” );
my $cmd = “decoder_control.cgi?command=0&user=admin&pwd=”;
#Down Arrow
sub moveConDown
my $self = shift;
Debug( “Move Down” );
my $cmd = “decoder_control.cgi?command=2&user=admin&pwd=”;
#Left Arrow
sub moveConLeft
my $self = shift;
Debug( “Move Left” );
my $cmd = “decoder_control.cgi?command=4&user=admin&pwd=”;
#Right Arrow
sub moveConRight
my $self = shift;
Debug( “Move Right” );
my $cmd = “decoder_control.cgi?command=6&user=admin&pwd=”;
#Diagonally Up Right Arrow
sub moveConUpRight
my $self = shift;
Debug( “Move Diagonally Up Right” );
my $cmd = “decoder_control.cgi?command=91&user=admin&pwd=”;
#Diagonally Down Right Arrow
sub moveConDownRight
my $self = shift;
Debug( “Move Diagonally Down Right” );
my $cmd = “decoder_control.cgi?command=93&user=admin&pwd=”;
#Diagonally Up Left Arrow
sub moveConUpLeft
my $self = shift;
Debug( “Move Diagonally Up Left” );
my $cmd = “decoder_control.cgi?command=90&user=admin&pwd=”;
#Diagonally Down Left Arrow
sub moveConDownLeft
my $self = shift;
Debug( “Move Diagonally Down Left” );
my $cmd = “decoder_control.cgi?command=92&user=admin&pwd=”;
#Stop
sub moveStop
my $self = shift;
Debug( “Move Stop” );
my $cmd = “decoder_control.cgi?user=admin&pwd=&command=1?;
#Move Camera to Home Position
sub presetHome
my $self = shift;
Debug( “Home Preset” );
my $cmd = “decoder_control.cgi?command=25&user=admin&pwd=”;
1;
__END__
