Has anyone had any luck running zoneminder in VirtualBox under Windows?
Especially with one of the older bttv 848 PCI capture cards?
At the moment I have a separate linux cctv box which runs 24/7, and a windows box that I switch on and off as and when required.
I now have a need to leave the windows box on 24/7, and seems silly to leave them both on so wondered about using virtualbox in the Windows machine from zoneminder.
The ZM part of it wont be an issue, I'm more concerned with how well the PCI bttv card will play.
