I'm running ZM 1.24.2 on an Ubuntu 10.04.3 "dedicated VM" installed from repository, with a couple of intellinet camera and everithing works fine except that if i try to use a dedicated storage (NAS with samba sharing) ZM cannot stop saving events/images.
i've tried to follow the instrution founded in the wiki at this address http://www.zoneminder.com/wiki/index.ph ... Hard_Drive ...and i've done some mess, but i can't understand where's the error.
i've mounted the shared storage, putting this line in my fstab:
//sharing.address/sharename /media/netDsk4Rec smbfs credentials=/home/myUsr/.credentilsFile,uid=myUsr 0 0
(note that now i've resetted the original link to have ZM work fine again the one to consider are the _new one):
lrwxrwxrwx 1 root root 28 2012-02-14 17:21 events -> /var/cache/zoneminder/events
lrwxrwxrwx 1 root root 24 2012-02-17 15:41 events_new -> /media/netDsk4Rec/events
lrwxrwxrwx 1 root root 28 2012-02-14 17:21 images -> /var/cache/zoneminder/images
lrwxrwxrwx 1 root root 24 2012-02-17 15:42 images_new -> /media/netDsk4Rec/images
So, first of all i've thought that was a permission problem, and i've checked them, and here is the thing that i can't understand.
Trying to make a "sudo chmod/chown" on the new events/images folders (the ones on the NAS) i didn't get any error, even with -v it tell's me everithing is ok, but checking the results with an "ls" i've seen that in real everithing reguarding the permissions/owners remain the same.
It seems that I can create files/folders on that storage but i cannot change their "proprieties".
I cannot understand where i've done the mess, but think that is a permission problem,so i'm here to serch for help/hints cause serching around i cannot find the information that i need (or i've found them but i haven't understood the right thing)
I'm not so skilled in linux system and in ZM (and also my english is not the best ), so i hope to have given all the information needed.
Thanks in advance for help
