my zoneminder is running since 6 Months without problems.
But i want to know how to reset the event number to 0 ... ?
Next "Problem" is:
I have 3 Monitors and i have also the prob that Monitor 3 is called montior 5
in ZM and when i add a new montior it is number 6 but i have only 3 .
How to reset that numbers? I made something wrong by setup ZM?
How to reset Event Number
Re: How to reset Event Number
does not have anything wrong, it's normal.
ZoneMinder uses a counter ID to call the monitor and the folders where the events are saved (usually in / usr / share / ZoneMinder / events). If you created a monitor and then you deleted the ID counter is incremented by one.
To reset the counter ID and change the ID of the monitor that you have already configured you must open the database mysql of zm. I have used phpmyadmin but the operation is very delicate because it can affect the operation of the system.
sorry for my bad English.
