Zoneminder and other DVR output
fjenou
Post by fjenou »
Hi all, greetings,
Not sure if this is the right forum to post; I Googled a lot but found no answer for this question:
I have a 4 channel DVR which is viewable on Internet with Android MEYE app. Can I capture this video stream by a remote Zoneminder installation? If possible, how?
Thanks.
nightcrawler
Re: Zoneminder and other DVR output
Post by nightcrawler »
General is possible to use this. Zoneminder can capture from MPJEG streams. so if you know an direct URL to one of your cam's streams you can use this on the "add monitor" page. It's the same way that an IP camera works. see the ZM wiki at > http://www.zoneminder.com/wiki/index.ph ... Digitizers
But you have to be sure that's an direct URL like this example from the foscam page of the wiki:
http://YOURURL.COM/videostream.cgi?user=admin&pwd=12345&resolution=32&rate=6
Zoneminder can't handle java or flash applets that stream video. only direct inputs.
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
fjenou
Post by fjenou »
Hi nightcrawler,
Thanks for your suggestion.
I used tcpdump to tap into Android MEYE and DRV traffic, but no joy, nothing identifiable as a http string.
Googled some more and arrived at this frustrating conclusion: the protocol that governs MEYE and DRV remote viewing must be the best-protected industry secret...
Before anyone asks, yes, Zoneminder installation is working (with 3 Foscam IP cameras).
Regards,
humbytheory
Post by humbytheory »
Hey fjenou, what's the DVR you're using?
fjenou
Post by fjenou »
Hi humbytheory, it´s a generic Linux-based 4channel DVR made by a Brazilian company, Tecvoz TEC-SA04.
