Have an odd issue video works for up to 1 hour, no errors in the logs that I can see. The source shows green, when I click on the name it looks to have a freezed frame. If I restart ZoneMinder it shows a green screen. If I reboot the server everything is good for about an hour.
DVR Card Camsecure 5008 PCIe card
ZoneMinder v1.25.0
Syslog server is clean
Events from zoneminder logs show that it is processing and capturing but it isnt really doing it.
2012-03-11 14:27:04.475712 zma_m1 4407 INF FrontDoor: 3000 - Processing at 2.00 fps zm_monitor.cpp 1055
2012-03-11 14:27:03.450069 zmc_dvideo0 4405 INF FrontDoor: 3000 - Capturing at 2.00 fps zm_monitor.cpp 2598
2012-03-11 14:26:52.104163 zms 4640 INF Got signal 15 (Terminated), exiting zm_signal.cpp 44
2012-03-11 14:18:44.468181 zma_m1 4407 INF FrontDoor: 2000 - Processing at 2.00 fps zm_monitor.cpp 1055
2012-03-11 14:18:43.450051 zmc_dvideo0 4405 INF FrontDoor: 2000 - Capturing at 2.00 fps zm_monitor.cpp 2598
2012-03-11 14:17:41.579925 zms 4624 INF Got signal 15 (Terminated), exiting zm_signal.cpp 44
2012-03-11 14:13:29.064564 zms 4605 INF Got signal 15 (Terminated), exiting zm_signal.cpp 44
2012-03-11 14:10:24.456980 zma_m1 4407 INF FrontDoor: 1000 - Processing at 2.00 fps zm_monitor.cpp 1055
2012-03-11 14:10:23.450064 zmc_dvideo0 4405 INF FrontDoor: 1000 - Capturing at 2.00 fps zm_monitor.cpp 2598
Video stops working, more like freeze frame after 1hour
- ZoneMinder Feed (Green)
- zoneminder_feed.jpg (70.51 KiB) Viewed 4019 times
- Zoneminder Console
- zoneminder_console.jpg (88.98 KiB) Viewed 4019 times
Re: Video stops working, more like freeze frame after 1hour
Try heatsinks. You have the classic symptoms.
first, try update your kernel to 3.0 version ...
I had the same problem. After updating the kernel the problem did not reappear.
Just upgraded to 12.04 will see if that helps out.
3.2.0-18-generic-pae #29-Ubuntu SMP Mon Mar 12 00:42:23 UTC 2012
So the upgrade didnt help, but I am seeing an odd error.. Going to do a little google search on this one. But this seems to be my true issue it seems to be looping.
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808011] saa7130[0]/irq[10,4297971747]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
2 DONE_RA3 AR PE PWR_ON RDCAP INTL FIDT MMC TRIG_ERR CONF_ERR LOAD_ERR GPIO16 GPIO18 GPIO22 GPIO23 | RA0=vbi,b,odd,15
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808030] saa7130[0]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808186] saa7130[2]/irq[10,4297971747]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808204] saa7130[2]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808360] saa7130[4]/irq[10,4297971747]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808377] saa7130[4]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808533] saa7130[6]/irq[10,4297971747]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808550] saa7130[6]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808711] saa7130[0]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808728] saa7130[0]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808882] saa7130[2]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.808899] saa7130[2]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809053] saa7130[4]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809070] saa7130[4]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809224] saa7130[6]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809241] saa7130[6]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809399] saa7130[0]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809416] saa7130[0]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809570] saa7130[2]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809587] saa7130[2]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809740] saa7130[4]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809757] saa7130[4]/irq: looping -- clearing PE (parity error!) enable bit
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809911] saa7130[6]/irq[10,4297971748]: r=0xffffffff s=0xffffffff DONE_RA0 DONE_RA1 DONE_RA
Mar 13 02:41:02 LinuxSec01 kernel: [12317.809928] saa7130[6]/irq: looping -- clearing PE (parity error!) enable bit
OK updated the Kernel and still having issues:
chris@Sec01:~$ uname -a
Linux Sec01 3.0.0-16-generic-pae #29-Ubuntu SMP Tue Feb 14 13:56:31 UTC 2012 i686 i686 i386 GNU/Linux
bb99 Are you saying heatsinks on the board? You think this is an heat issue?
Thanks for the help by the way.. I am wishing I used IP Camera's..
I removed the case and put a fan on it. I am also checking heat via SNMP, so I am thinking this is not the issue.
I am really thinking it is card related issue but a little lost as to what to look at next.
