Source in orange
Source in orange
What does means the ip source address in orange color?
What I have to check?
No events are acquired but I'm sure that conf is ok
Re: Source in orange
Help me please!
First of all I underline that I haven't changed nothing besides the location of events, mounting an external HD as a local filesystem folder and creating links to that folder. It appeared all ok for first hours. I checked the day after and bad surprise, I still have the source in 'orange' color, no events recorded. If I change the mode from Record to Mocord or others, it will turns for a while green. If I open zones window, no image appears, but if I open the live image by clicking on its name, I can see it.
What can I do?
What can I do?
Shared memory settings?
But previously, without having touched nothing, all worked..... I have only installed some updates of OS
What I have to check for Shared memory settings?
Well, before changing anything, why don't you post the /var/log/syslog when restarting Zoneminder?
I posted but it's too long and perhaps doesn't pass....
What can I check also?
It's strange....
Before chaging event folder to another disk it worked.....well
It's strange....
Here a part of the log file
Please help me!!!
Please help me!!!
- syslog.rar
- (28.04 KiB) Downloaded 182 times
You have a lot of these errors:
This could be fixed, replacing the following in the file /usr/local/share/perl/5.12.4/ZoneMinder/Memory.pm
with
Also have a lots of warnings:
I do not know if you described your system setup. I got this errors when my IP-Cams does not have good connection. Check if connecting a direct lan cable fixes your problem. This could confirm the bad quality of the connection, again, I am assuming that are IPCams.
Start with small buffer settings and working in monitor mode, so the troubleshooting is easier.
Hope it helps,
PacoLM
ERR [Shared data size conflict in shared_data for monitor xxxxxxx, expected 328, got 316]
$arch = int(3.2*length(~0));
$arch = 32;
WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Mar 27 00:06:36 videoserver zmc_m3[29464]: WAR [Select timed out]
Mar 27 00:06:36 videoserver zmc_m3[29464]: ERR [Connection dropped by remote end]
Mar 27 00:06:36 videoserver zmc_m3[29464]: WAR [Unable to capture image, retrying]
Hope it helps,
PacoLM
Excuse me. 2 days ago I tried to restart the PC and looking into zoneminder portal, all CAMs were in green....
I checked also yesterday, still green....
But I checked again now and ORANGE!!!
Why?
Yes, my CAMS are IP cams, someone with ethernet cable, someone with Wireless, but orange is also those with cable....
What can I do?
Why?
What can I do?
How to change buffer size?
With which values?
With which values?
Someone can help me in changing buffer size and looking for a solution for orange entries?
The buffer settings are on each of the monitors you have in your system. There's a tab called Buffers, you should have the defaults if you do not know where they were. Try lowering them to half of the settings. Also you could try to lower the resolution of your cameras. Post results and logs.
Hope it helps,
PacoLM
Hope it helps,
PacoLM
each buffer tab of each camera set to:
Image Buffer Size (frames) 20
Warmup Frames 12
Stream Replay Image Buffer 500
no way....
still orange also after stop and restart of zoneminder server.
What to try?
If you want, by PM I can send you connection data to web interface, let me know
Warmup Frames 12
no way....
What to try?
OK, send me your ip and allow another user to be admin. Don't forget the pwd!!
