I am trying to move my image and events folder to my new hdd. But nothing that i have read tells me anything about the links over in usr/share/zoneminder/www It appears ZM cannot work without them. I can change the paths under options>paths but ZM only sees the drive and does not function as it should. Not recording events and changing the color of the ip to red.
I am using Fedora 16 my hdd is mounted under /var/lib/zoneminder/zm_1tb.
The links are over in /usr/share/zoneminder/www
The files events and images are in /var/lib/zoneminder
I have been wrestling with this problem for a week or so and am no further along than i was at the beginning. I with the help of others have changed links, modified the fstab file and other related things. Bit still no results.
Can someone tell me how ZM on Fedora 16 determins disk size and if anyone has experience how to move the files events and Images to a HDD mounted at /var/lib/zoneminder/zm_1tb
I have mounted the disk via fstab in the zoneminder directory /var/lib/zoneminder/zm_1tb. When i visit events and images via root they report the full 1tb of free space. However when i login as george they report the 30gb on my main drive. Strange, the files are stored on the 1tb drive and the system works as advertised, with the exception of free space. if i change the paths /var/lib/zoneminder/zm_1tb under options, zoneminder reports the full size but zoneminder doesn't work.
I am not sure where i am at this point. it seems to be a zoneminder problem but i cannot rule out the Fedora 16 install.
